Advice on Buying a Complete Set of Sails for Islander 37 MS - SailNet Community
 1Likes
  • 1 Post By killarney_sailor
post #1 of 9 Old 10-02-2013 Thread Starter
Laugther is Good Medicine
Send a message via AIM to HighFly_27 Send a message via MSN to HighFly_27
I got my 1970 Islander M. S. over a year ago and need to buy a complete set of sails.
Islander 37 Hull Type & Sail Data:
Hull Type:Fiberglass, Fin Keel
Rig Type: Masthead Sloop
LOA: 36.5'
LWL: 28' 3"
Beam: 10' 8"
Draft: 5' 5"
Mast Height: 48'
Disp: 14000 Lbs.
Ballast: 5000 Lbs.
Rig Dimension:
I -- 43'
J -- 14.50
P -- 37.80'
E -- 15.50'
Forestay Length -- 45.38'
Sail Surface Areas
SA (Fore): 311.75 ZFt.2
SA (Main): 292.95 ft.2
Total (calc.) SA: 604.70 ft.2
I listed all the data (above) so folks would know my I-37 sail information. Feel free to chime in with a like comparison boat, or what works best or does not work.
Really, I'd like to hear from I-37 owners... what sail sets they have, forgot to mention, I have a furring system and (1) main sail set to start with, nothing else.
I'm looking to sail long distance and want a good sail set up, 5 different sail sets. I'm trying to buy... good used + to like new sails.. if available. I'm looking for a full range of sail set ups, to include light winds, 155/ 135 genoa, etc. .
Looking to hear about the best type of fabric, stitching & grommet reinforcements. Who's the top sale maker(s) for the money & not over priced and quality sails. Thinking used 1st but will buy new and ready to spend a little more for higher end quality.
Avery
HighFly_27 is offline
post #2 of 9 Old 10-03-2013
I don't discuss my member
zz4gta's Avatar
Re: Advice on Buying a Complete Set of Sails for Islander 37 MS
I'm going to go out on a limb and assume you have a sloop rig?
Main - full battens, loose foot, 2 reefs, leech and foot lines, chafe guard where the spreaders hit.
180 - don't bother. You loose efficiency after a 150% LP.
155 - material suitable up to 12 true. Dacron or cruising laminate if the budget can handle it. If you opt for dacron go with a triradial.
135 - Same as above, carry it up to 22 true.
100% or less - you need a small sail for 25 kts +. After that you're reefing down and flying whatever combo the boat likes.
It's going to be really hard to find sails in that size range that are used. There's a reason the previous owners are selling them. My suggestion would be to bite the bullet and talk to a few sailmakers and see what they can do for you.
Merit 25 # 764 "Audrey"
zz4gta is offline
post #3 of 9 Old 10-03-2013
grumpy old man
Not sure a loose foot is what will work best for his planned journey. I like loose fotted mains but on his boat it might make ther main harder to reef neatly. I would not have any genny bigger that 135% for this trip.
Bob's Blog ....
bobperry is offline
post #4 of 9 Old 10-03-2013
no longer reading SailNet
Alex W's Avatar
Headsail changes aren't very easy with most roller furling gear. I think that two headsails, a 100% and a 135% would be fine.
If you added a solent stay then having a larger headsail inventory could work well. The 135% genoa for everyday use, a 110% for heavier weather use, and a storm sail for actual storm use. A hanked on 110% will have much better shape than a rolled up 135%.
Alex W is offline
post #5 of 9 Old 10-03-2013
Freedom 39
FarCry's Avatar
I have to agree with Alex and Bob Perry. On a another thread you are suggesting sailing to the USVI and then possibly exploring the Caribbean chain. Locally the one Islander 37 that I was aware of seemed to be a pretty easily driven hull that didn't require a lot of sail area to get it moving. I can't fathom ever bothering with anything bigger that a 130ish sized sail and wouldn't feel under-canvassed with about a 120. The wind BLOWS down here, 15-20 is average. Rolled up gennys don't make very good air foils. A heavy 120-130 would cover you under 90% of the conditions you are likely to encounter. With a good main, reef early and be done. A light wind sail might be nice on the rare occasion you might need a bit more oomph but a 2nd small headsail, as Alex suggested, with two whisker poles might be easier to manage short handed. That gives you the benefit of a backup in case of a genoa catastrophe. I would invest the limited storage area of a 37 on other things than many different sails unless you intend to race.
FarCry is offline
post #6 of 9 Old 10-03-2013
Bristol 45.5 - AiniA
We have a somewhat larger boat (45', 40,000 lbs) and our 30,000 miles into a circumnavigation and I will tell you what we have and how it has worked. We have a removable inner stay.
Workhorses:
- 135% genoa that was new when we started and will get us home. Bought it from North at the Annapolis show. Their show discount was larger than anyone else's so the resulting price was lower than about six other quotes
- Hood furling main that was far from new when we bought the boat. Doesn't look much different than 30,000 miles ago. A remarkably good sail.
Others
- Asymmetric spinnaker, 1.5 oz, bought with the genoa from North. Very nice to have and used fairly often. Not really went for downwind but that is where it gets used when the wind is light and we don't want to motor. In the bag is is huge and takes up a lot of space. Not certain it justifies itself. Since you have a boat was so what limited sail area you might want something for lighter airs. Might be a good used purchase.
- 100% jib for furler. Rarely used. I see it as more of a foresail backup than anything. Changing headsails with a small crew at sea in anything worse than benign conditions is not a trivial chore.
- hank on staysail for inner stay. It is quite small and really is to be used in really snarky conditions when the course is not right for heavily furled genoa. Not used often but good to have because in 35 knots you will not be putting a smaller jib on the furler.
- storm jib for inner stay, bought used in almost new condition and never used. Not much smaller than the staysail. Perhaps not needed but it was not too costly at Bacon and does not take up too much space
- storm trysail (has its own track) Came with the boat and never used although we had it on the track on deck on our trip from Mauritius to South Africa where you can get pasted. I view it as an emergency backup for the main.
As for an ideal rig, I am very impressed with modern Solent stay setups. Some of the bigger boats and especially cats have three furled sails ready to go, something around 135, a 100, and an off-wind sail. Just pull the string of your choice. Also would be good for twins downwind I think. Combine it with a removable stay for a storm jib and away you go.
HighFly_27 likes this.
Finishing our major refit. Our trip to Newfoundland is off because it is too late. Hoping to go to the North Channel instead.
killarney_sailor is offline
The Following User Says Thank You to killarney_sailor For This Useful Post:
HighFly_27 (10-03-2013)
post #7 of 9 Old 10-03-2013
DrB
No bigger than 135(maybe a 140), but not anything larger. Get a high clew. Makes visibility easier. Your other smaller headsail should be 100 or 95%.
I did an experiment once in 20+ kt winds and put up a 95% sail instead of flying a 135 and it roller reefing it to 105. The 135 made me have too much helm (close-hauled) going slow. The 105 gave me better helm and a little improvement on speed. The 95 allowed me to have no helm and sail only 0.3 kt slower than the other two configurations. Since I was doing 5+ kts upwind and not fighting the helm constantly,it was a more pleasant sail. I thought the a reduction of 35% area in the head sail would translate to a much slower boat.
Full battens on main preferred although 2+2 would be okay. I like loose footed. Two reefs, but I make the first reef point a little deeper if you go this route, but to have a little more reefed than not enough. If you go with 3 reefs, you could make the first reef a little less deep, 2nd in it's normal spot. Leach and foot lines.
Get an asymmetric for those light downwind runs if you want. Get it with a sock.
DrB
If you liked my advice/response, give me some rep points. If you didn't......well what do you expect, it was free.
DrB is offline
post #8 of 9 Old 10-03-2013 Thread Starter
Killarney
I really liked your BlogSpot On Ainia.
I read the current and older info. as well, Great Read and read some of it twice.
Sorry to hear about your hand and time to heal delay... it could have been worst. I've had some injury's and set backs and know what it is to be in the healing up mode. I will say, that sticking any part of your body in a area that's opening & closing is risky, been there and got hammered too.
Not related but noteworthy... we have a lot of wounded soldiers on the mend from the middle east. A number of (thousands) them are wrecked for life. I see the pictures of fine troops with missing arms & legs, severe burns, maimed for life. I can ID with them because I was shot in Vietnam but only a flesh wound. A number of troops that I knew personally or knew of were severely wounded or killed, any war is stupid and takes our finest. Currently, are wounded Vet's face a tall mountain of recovery, some will never have a normal life again. My bottom line feeing's about being over there... is quite negative. It's a big time waste of American Soldiers lives & well being; unfortunately, sorry to say... nothing will change (middle east) in the end; stupid politics, like Vietnam !
Take the Best of Care,
Avery
arbakerjr@hotmail.com
post #9 of 9 Old 10-03-2013
Frozen Member
AlaskaMC's Avatar
Bob,
This may be a silly question but we are about to get a loose footed main to replace our bolt rope foot main and your comment made me pause. Could you explain for this new to loose foot guy?
Thanks! (SORRY FOR THEY HIJACK!)
AlaskaMC is offline
Circumnavigation advice for complete novices fando General Discussion (sailing related) 44 03-11-2015 06:05 PM
Need advice on buying new sails for my Venture 21 FishDragon Introduce Yourself 20 12-16-2011 07:15 PM
islander bahama 24 in need of sails skittles Boat Review and Purchase Forum 4 11-22-2010 10:07 PM
Buying new sails, need advice ajf10 General Discussion (sailing related) 31 01-23-2009 12:00 AM
Advice for a complete nOOb. bigfatguy Learning to Sail 7 09-11-2008 10:37 AM
