Charting a course - Page 2 - SailNet Community
 1Likes
post #11 of 22 Old 10-04-2013
Re: Charting a course
I've never tried to get my master degree in all the functionality of our chartplotter. However, altering waypoints after accepting the route has been beyond my pay grade. I can add or subtract from the end, but if I need to change something within the route, it seems tough. This happens, when I try to over plan a route and realize underway that I'm not going that way. I do know how to reset the track to the next waypoint, but changing them has been a pain. YMMV Good luck.
By the way, I'm pretty sure most devices will record speeds, distance traveled, etc, whether you enter a route or not. Mine does.
Jeanneau 54DS
Minnewaska is offline
post #12 of 22 Old 10-04-2013
chef2sail's Avatar
Many weekends I plan our route on our I PAD and synch it into the Raymarine CHartplotter when I get down to the boat.
Both use Navionics and are easy to use./
Dave
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is offline
post #13 of 22 Old 10-04-2013
TakeFive's Avatar
I do this all the time, and once you figure it out, it's easy to use a computer plotter for planning, and then transfer it into a handheld for use on the boat.
One of the benefits of using a computer program is you can download NOAA raster charts for free. The raster charts are just scans of the paper charts, and are the same files that most printers use to make on-demand charts for you. Since you're plotting with the exact same chart you'd have if you used paper, it gives you a "second opinion" vs. the electronic chart in your GPS. When you transfer the route to your GPS and see it over the electronic chart, you have added confidence knowing that the route was plotted against the actual NOAA chart.
I've used most of the programs mentioned above, but IMO the one that is by far the best of the freebies is OpenCPN (which was not mentioned above). You can plot routes, save them, change them, transfer them, etc.
My Garmin handheld GPS will record your track even if you have not plotted a course. I keep it on all the time even if I'm not using it, just so I can check where I've been.
2001 Catalina 34MkII Breakin' Away (at Rock Hall Landing Marina)
PO of 1998 Catalina 250WK Take Five (new owners relocated to Baltimore's Inner Harbor)
1991 17' Trophy (Lake Wallenpaupack)
TakeFive is offline
post #14 of 22 Old 10-06-2013 Thread Starter
First String
My GPS 78
has no maps on it ?
I need a new one just need to bite the bullet and do it...
ltgoshen is offline
post #15 of 22 Old 10-06-2013
TakeFive's Avatar
Originally Posted by ltgoshen View Post
My GPS 78
has no maps on it ?
Maybe you just need to buy a Bluechart chip.
I believe that Garmin's model numbers require a letter after the number to designate a built in chart. 78c has marine charts, 78t would have topo map, etc. If it has no letter, it only has a low-res base map, and you need to buy one of their Bluechart chips to have the built-in chart.
Don't go throwing away your 78 - it might be cheaper to buy the chip.
TakeFive is offline
post #16 of 22 Old 10-06-2013
Delezynski's Avatar
Location: Currently in Az. and trailer to various places.
I guess we approach this differently on Guenevere than most of the posters.
We normally cruise full time, or for months at a time so we are not in a hurry to get something into our plotter.
What we do is have a final destination in mind. Knowing that it might change along the way.
I then plot the route with many way points to our first destination. This is normally a days sail away in closed in water, or for open water overnight trips. Then, once at anchor we rest and I then plot the next days trip the evening before we depart. It's a relaxing exercise for me and the next trip is fresh in this old mind.
I do LOVE OpenCPN and keep it handy on a new tablet handy below. I am also excited about the Active Captain and especially the Interactive Cruising Guidebook feature!!! I am using it now to do some rough planning for our next cruise.
Greg
Greg & Jill Delezynski
Nor'Sea 27, Guenevere
Home page -
Youtube page -
Youtube Virtual Reality page -
Delezynski is offline
post #17 of 22 Old 10-06-2013
TakeFive's Avatar
Originally Posted by Delezynski View Post
...I then plot the route with many way points to our first destination. This is normally a days sail away in closed in water, or for open water overnight trips. Then, once at anchor we rest and I then plot the next days trip the evening before we depart. It's a relaxing exercise for me and the next trip is fresh in this old mind...
Pretty much what I do when we charter for a week. We decide the next day's destination while having dinner, and I plot the next day's route before going to bed.
TakeFive is offline
post #18 of 22 Old 10-06-2013 Thread Starter
First String
I use Active captain as well. It is a great tool for me to use to review in my mind befor I go sailing. I don't yet have a good understanding of the GPS on this boat. Still learning how to use it. I thank you for your help. I Would like to make sure I have what I need on this boat.
From my looking on the net this weekend, The Garmin 215 is an older unit. And the GPS 78 dont even have a map capability.
ltgoshen is offline
post #19 of 22 Old 10-06-2013
TakeFive's Avatar
...The Garmin 215 is an older unit. And the GPS 78 dont even have a map capability.
Check the Garmin website. It's exactly as I said before:
Explore
GPSMAP 78 comes with built-in worldwide basemap, so you can navigate anywhere with ease...
Add Maps
Adding more maps is easy with our wide array of detailed marine, topographic and road maps, available on microSD card. Conveniently plug in BlueChart® g2 preloaded cards for a great day on the water or City Navigator NT® map data for turn-by-turn routing on roads (see maps tab for compatible maps). The card slot is located inside the waterproof battery compartment, so you don't have to worry about getting it wet.
The 78 is a current model that Garmin still makes, and sells for $249. Like most of Garmin's marine GPSs sold today, you need to buy the charts separately.
TakeFive is offline
post #20 of 22 Old 06-30-2014
Master Mariner
capta's Avatar
I don't use routes on my GPS. I have way points in it that I can make my target destination, (or several, one after the other), but I've rarely found the weather and currents allow me to sail a route as planned, unless I'm motoring or motor sailing.
christian.hess likes this.
facebook.com/svskippingstone
Our Videos;
capta is offline
iPhone Charting App gimmellsdad General Discussion (sailing related) 9 07-14-2009 03:25 PM
Charting.. pauljohnson1222 Cruising & Liveaboard Forum 2 06-29-2009 06:48 AM
New iPhone gps/charting app! sailor25b Gear & Maintenance 9 08-13-2008 03:07 PM
charting software ekhar Gear & Maintenance 9 11-26-2002 05:54 PM
Charting Software thomsonjd Gear & Maintenance 1 01-06-2002 03:49 PM
