need help with water heater - SailNet Community
post #1 of 9 Old 10-03-2013 Thread Starter
i own a Vancouver 25 with a 1gm10 yanmar engine.
it has an external cooling system. (only sea water).
i need to know if i can use the water heater with the sea water from the engine and if there will be any bad consequences.
thanks
gal
gal ecker is offline
post #2 of 9 Old 10-03-2013
Delezynski's Avatar
Location: Currently in Az. and trailer to various places.
Re: need help with water heater
Originally Posted by gal ecker View Post
... (only sea water)...
thanks
gal
Short reply, YES! Had one, sea water ate the tubing in about a year.
Greg
Greg & Jill Delezynski
Nor'Sea 27, Guenevere
Home page -
Youtube page -
Youtube Virtual Reality page -
Delezynski is offline
post #3 of 9 Old 10-03-2013
no longer reading SailNet
Alex W's Avatar
I can't answer your exact question as my boat has a heat exchanger for the engine cooling system.
Removing the hot water heater on my Pearson 28 was one of the best upgrades yet. Tons of extra storage room, reduced weight, and removed something that was marginally useful anyway.
I can see having one on a liveaboard 35+ boat, but it's really not beneficial on a small coastal cruiser (like both of our boats that are about 29' long). It looks like your boat holds about 50 gallons, so if you took regular showers on the boat you'd probably need to visit a marina every 2 or 3 days. You might as well use their shower.
Alex W is offline
post #4 of 9 Old 10-03-2013
RWC engines often don't run hot enough to effectively heat a HW tank.. And then there's the corrosion issue already mentioned.
Good HW heaters are costly.. Probably not the upgrade I'd make on a small coastal cruiser - though I'm a solid convert to having H&C pressure water...
Faster is online now
post #5 of 9 Old 10-03-2013
Delezynski's Avatar
When deciding on a water heater or not, it depends not only on size of the boat, but your cruising grounds and how you cruise. We have one on Guenevere. We lived in the San Francisco Bay area aboard for years. It was VERY useful. We cruised tropical waters and it was hardly used. This year we returned to the Bay area for a few months and I can tell you, after crossing the bay on a summer day, dropping anchor and using the engine for 20 min. that hot shower WAS SOOOOO GOOOOOOOODDDDDD!!!!!! Well worth the space it takes up.
I am NOT saying every one should have or needs one, but if you do
Greg
Home page -
Youtube page -
post #6 of 9 Old 10-04-2013 Thread Starter
Greg
do you know if there is a way to prevent this dammage?
mayby with zinks or diffrent water heater?
post #7 of 9 Old 10-04-2013
Delezynski's Avatar
gal,
No way to prevent it that I know of. The way it works is that there is just a simple tube that runs through a tank of water. It's that tube that rots out from the hot salt water. Sorry to give you bad news.
We put one in when we had a raw water cooled engine. Did not last and I just gave up. We then had to install a new engine, and it was fresh water cooled so I put in a new water heater. That was in March of 2000, and it's still STILL working great.
Here is a photo I snatched to show the working....
You might have to go the solar shower route....
We also have a fireplace abaord and could use water heated on it for a warm (short) shower.
Hope you find a way get what you need!
Greg
Home page -
Youtube page -
post #8 of 9 Old 10-04-2013
There are higher quality (more expensive) all Stainless Steel heaters that might last longer, but I think the bigger issue is the generally lower running temp of RWC engine and the increased difficulty of putting the heater coil in the water circuit, depending on the engine.
We have H&C water, and a 'shower' in the head but we virtually never use it. Solar shower bags work great in summer, you can hang them down the hatch and still use the inside shower space if you must (we don't, don't want the added humidity and moisture below - the reason we don't use the official shower as well). I suppose it would be a different story if we lived aboard in cooler weather.
post #9 of 9 Old 10-04-2013
chef2sail's Avatar
We use our shower all the time and on our boat 34 weekends as well as a 3 week trip every year. We have an inexpensive 6 gallon HWH which I only use on the engine coolant and dont have it hooked up to use when at the dock.
It is one of the convienences which keeps the Admiral very happy. Its nice to be able to shower off using a small amount of water and feel clean.
It is one of the convienences I dont want to give up.
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is offline
cs 30 water heater timmorgan CS Yachts 1 07-21-2009 06:01 AM
new water heater ralphmacey Announcements and Suggestions Box 6 05-26-2008 01:19 PM
hot water heater sailaway50 General Discussion (sailing related) 1 01-10-2008 09:29 PM
Connecting raw water cooling to water heater Northeaster Gear & Maintenance 18 04-28-2007 06:11 PM
hot water heater firstafair General Discussion (sailing related) 12 11-09-2006 10:25 AM
