130 lb centerboard hanging up - SailNet Community
post #1 of 11 Old 10-09-2013 Thread Starter
Out single handing the lightning today(it was awesome) and ran into some sand bar....pulled the centerboard up and it didn't want to go back down,,,,clues?
mustangchef is offline
post #2 of 11 Old 10-09-2013
Master Mariner
capta's Avatar
Re: 130 lb centerboard hanging up
Centerboards will not go down if there is lateral pressure on them, like when sailing to windward. Many, like mine, will jam if brought all the way up, so we have put a mark on the cable to prevent that. You will probably have to go under there (or haul the boat) and using a screw driver pry it back out. Then, don't forget to mark the cable/lone you use to control it.
Good luck.
facebook.com/svskippingstone
Our Videos;
capta is online now
post #3 of 11 Old 10-09-2013
Tartan 27' owner
CalebD's Avatar
You could have stirred up some sand or other flotsam into the C/B trunk.
Try tapping the side of the C/B trunk.
Otherwise you are going for a swim or a haul out.
Everybody has one:
CalebD is offline
post #4 of 11 Old 10-10-2013
Asleep at the wheel
jimgo's Avatar
I've actually seen downhaul lines rigged for CB's for such purposes. I agree with Caleb, you probably have some sand stuck in there and it's keeping the CB stuck. If you can get to the top of the CB trunk, one idea would be to try to flush the area with fresh water from the top. That might dislodge the sand or other debris. On something like a lightning, it should be easy to haul her out and clean from the bottom if need be. Do you have a trailer?
- Jim
Home: Western Philly 'burbs
1980 Allmand 31
1975 Albacore 15
jimgo is offline
post #5 of 11 Old 10-10-2013
grumpy old man
It's a Lightning. This is not a stout board I presume. You may have bent it.
Is it metal?
Bob's Blog ....
bobperry is offline
post #6 of 11 Old 10-10-2013 Thread Starter
Thanks, I have always been able to kick it down, I 'm thinking it must have been debris wedging up.
post #7 of 11 Old 10-10-2013 Thread Starter
Is it metal?
Ya , it's actually a robust metal centerboard. If something were to bend it, it would make an awful noise up-top..cause they act like a needle on an old record ,when you scrape against something the sound is amplified by the hull.
post #8 of 11 Old 10-10-2013
krisscross's Avatar
You may be able to get the debris out of the centerboard box by rocking the boat vigorously for a few minutes.
Plato
krisscross is offline
post #9 of 11 Old 10-10-2013 Thread Starter
ya sailed it for 4 hours yesterday, kicked my ars, pretty sore today,, feels good.
post #10 of 11 Old 10-10-2013
Tartan 27' owner
CalebD's Avatar
did the C/B come down?
Everybody has one:
CalebD is offline
Jib hanging up huntermj General Discussion (sailing related) 18 05-25-2013 02:28 PM
Centerboard position - keel/centerboard Tartan 37 upwind cspear Racing 14 07-02-2012 12:31 PM
Hanging Tomatoes uspirate Provisioning 29 12-06-2009 09:00 PM
Hanging burgees Jotun Gear & Maintenance 8 08-10-2007 09:14 AM
Hanging with Club Med Dan Dickison Racing Articles 0 10-18-2000 08:00 PM
