crack in cockpit sole of Catalina 22, how serious? - SailNet Community
 6Likes
post #1 of 14 Old 10-09-2013 Thread Starter
Not my boat (yet). Present owner has had her for several years, in this same condition. Says there is very little flexing but a small amount of water does go through.
How serious a problem are we looking at? The boat is an '87, is there a wood core under there that's going to be rotten?
Could a layer of fiberglass mat over the entire sole put the whole thing to rest?
dixiedawg is offline
post #2 of 14 Old 10-10-2013
Barquito
Barquito's Avatar
Re: crack in cockpit sole of Catalina 22, how serious?
I can't remember from my C22 if it is wood core there. If it is it will be wet. The question is why did it happen in the first place? If it is from flexing, it must have failed under the floor. I would try to figure out why it happened b/f repairing.
Valiant 32
Barquito is online now
post #3 of 14 Old 10-10-2013
If you haven't bought it yet - don't. There are lots of small boats on the market that are ready to sail. Sailing is WAY more fun than fixing stuff.
smackdaddy is offline
post #4 of 14 Old 10-10-2013
Senior Slacker
SlowButSteady's Avatar
That pic looks like someone tried to repair the crack at least once before. My bet is that water has been getting in to the wood underneath (and there is almost certainly wood core or underlayment) for years. I would be very surprised if there wasn't any rot.
Never forget them. Do something to prevent it from happening again.
Charlotte Bacon, Daniel Barden, Rachel Davino, Olivia Josephine Gay, Ana M. Marquez-Greene, Dylan Hockley, Dawn Hochsprung, Madeleine F. Hsu, Catherine V. Hubbard, Chase Kowalski, Jesse Lewis, James Mattioli , Grace McDonnell, Anne Marie Murphy, Emilie Parker, Jack Pinto, Noah Pozner, Caroline Previdi, Jessica Rekos, Avielle Richman, Lauren Rousseau, Mary Sherlach, Victoria Soto, Benjamin Wheeler, Allison N. Wyatt
SlowButSteady is offline
post #5 of 14 Old 10-10-2013
CaptainForce's Avatar
I suspect that the water intrusion occured first through an apparently insignificant crack and then, after the wood core deterioated, the big crack resulted from the flexing of the unsupported fiberglass.
The best repair, in my opinion, would be to cut out the top layer, remove and repalce the damaged core and reglass over the replaced top layer. If the resulting cosmetic surface is not perfect, a cockpit flooring matt might suffice.
Take Care and Joy, Aythya Crew
CaptainForce is offline
post #6 of 14 Old 10-10-2013
Captain Obvious
Sal Paradise's Avatar
I bought one that was rock solid last year. I got it for a song. They are plentiful.
I don't think my cockpit floor has any wood in it.
Even so, I think it shuld be a simple fix. It is accessable from the cabin so look.
Sal Paradise
Senior Researcher - Dunning Kruger
Sal Paradise is offline
post #7 of 14 Old 10-10-2013
TQA
Bombay Explorer 44
TQA's Avatar
Very active Catalina 22 owners association. I would look around there.
Or just drill a hole to see if there is rotten wood in there. I am betting solid glass.
If so it is an easy fix.
TQA is offline
post #8 of 14 Old 10-10-2013
Well, winter is coming. If you are looking for a DIY project and the guy wants to sell it to very cheap, like a nominal sum - go for it. This boat will become a serious do not wanter, hard to sell. Most buyers for the boat are low time sailors looking for their first boat, not that it isn't a great boat for any sailor. These buyers aren't looking to work on the boat, they are looking for sail away condition. This boat is not sail away. it has a serious defect. I tell you this to help you understand your correct negotiating position.
TJC45 is offline
post #9 of 14 Old 10-10-2013 Thread Starter
That's the first thing I want to do when I see it in person. I can just slither back under there from the cabin, right?
post #10 of 14 Old 10-11-2013
Captain Obvious
You should be able to put your head under the seats and look around. You may have to move the galley, or the panel between the dinette and the gas locker under the seat. But its simple. You have to see under there before you can make an offer so make sure the seller is ready with a flashlight and gives you access
Sal Paradise
The Following User Says Thank You to Sal Paradise For This Useful Post:
dixiedawg (10-11-2013)
Crack on cabin sole northoceanbeach Gear & Maintenance 5 02-23-2013 03:18 AM
Cracked Cockpit Sole jetdrvr393 Gear & Maintenance 15 04-14-2012 01:29 AM
Cockpit sole repair 1965Columbia31 Gear & Maintenance 6 06-05-2011 07:18 PM
new core for cockpit sole Grcesq Gear & Maintenance 10 11-17-2009 06:18 PM
Is the cockpit sole cored? timangiel Gear & Maintenance 10 05-11-2007 11:32 AM
