Stability question - SailNet Community
 12Likes
post #1 of 32 Old 10-10-2013 Thread Starter
Stability question
I am currently boat shopping and one of my chief concerns is stability in heavy weather. Are there any other stability calculations other than Angle of Vanishing Stability and Capsize Screen Value that I could take into consideration when judging a hull form for stability?
Thanks in advance!
seafrontiersman is offline
post #2 of 32 Old 10-10-2013
Re: Stability question
Forget about Capsize Screen Value unless you are buying an old design and even so....
If you are talking about modern boats, you can ask the boat stability curves (or try to find them) but besides having to had the knowledge to read them they will tell you only a part of the history. They tell you about static stability that is important but don't say nothing about dynamic stability that is as important.
Here you have some thoughts about the issue:
Interesting Sailboats
Besides stability considerations there are other important factors regarding heavy weather sailing like the possibility of reefing the boat from the cockpit, the systems you use (regarding jamming possibility), the sails you have and can deploy from the cockpit (cutter rig) and boat motion.
It remains to be known what you call heavy weather. Many of the things that make a boat good for heavy weather sailing makes the boat less good in normal sailing conditions that are probably where you are going to use it 99% of the time. Boats are a compromise and unless you will want to sail it in extreme latitudes the right compromise for most sailors is not a boat specially set for heavy weather.
All boats in the market today of 36ft and over if well sailed and prepared with the right equipment can take some heavy weather without problems even if they are not designed taking that as main design directive. This does not mean that they are all the same: some are better than others on that situation.
post #3 of 32 Old 10-10-2013
Asleep at the wheel
jimgo's Avatar
Is this your first boat? What size are you considering? Are you planning on extended cruising most of the time? That is, are you expecting to frequently be underway while the heavy weather blows through?
If you're like many of us who mostly daysail with the occasional weekend or annual week's trip, I don't know that I'd focus TOO much on heavy weather. Yes, you want the boat to be able to survive a storm, but most boats will do that just fine, especially if you aren't underway.
- Jim
Home: Western Philly 'burbs
1980 Allmand 31
1975 Albacore 15
jimgo is offline
post #4 of 32 Old 10-10-2013
Not Finished Yet
RainDog's Avatar
Stole this from smurphny, but great presentation of stability.
www.usna.edu/Users/naome/phmiller/offshore.ppt
RainDog is offline
post #5 of 32 Old 10-10-2013
grumpy old man
Those numbers are fine and valid as references but there is a lot more to it than those static numbers. So long as you choose a "normal" boat with reasonable shape and avoid any of the extreme designs you should be fine. I think your safety in heavy weather depends a lot more on you than it does those numbers. Learn how and when to reduce sail. Would you pass on a boat that has LOPS (limit of positive stability) of 123 degrees compared to another boat with a LOPS of 126 degrees? I wouldn't. In extreme conditions I'm not sure that a LOPS of 120 degs makes any difference compared to a LOPS of 128 degs. Stick with boats that have a beam to length ratio (L/B) between 3.3 and 4.00. Avoid boats with an L/B near 3.00 or below. Pick a boat with a D/L around 220 to 270. Recognize that shoal draft will almost certainly raise your VCG and reduce righting moment (Rm)
It is very difficult to generalize about stability. I think there is a preoccupation with static stability numbers today. Probably because computers make it relatively easy to get those numbers. But they are Dependant for their accuracy on an accurate VCG and this has to come from a painstaking weight study and there is no computer short cut for that.
Years ago I worked for a very well known design office for a year. In that year we did one stability study and that was only to determine the Rm for rating purposes.
Bob's Blog ....
bobperry is offline
The Following User Says Thank You to bobperry For This Useful Post:
krisscross (10-10-2013)
post #6 of 32 Old 10-10-2013 Thread Starter
Looking for a cruising vessel to potentially circumnavigate; will start off on East coast of North America and the Carribean. Not my first boat and I am just looking for some baseline hullform numbers on vessels which would otherwise meet my specs. I am two-3 years from pulling the trigger on this so I'm just in the number crunching stage
Thanks for the prompt reply!
post #7 of 32 Old 10-10-2013 Thread Starter
Thanks rain dog!
I'll study this when I get a chance.
post #8 of 32 Old 10-10-2013
Bob's guideline numbers make a lot of sense.. and those numbers are easily arrived at. Further a large range of typically available production boats fall into those brackets.
The Catalina 30 and 36 are among the least tender boats readily available and are fine coastal cruisers - Island hopping would be fine too, but many will say they are not truly trans-ocean designs. Great place to start, though, but not the only good candidates.
Faster is online now
post #9 of 32 Old 10-10-2013
Barquito
Barquito's Avatar
I'm not in the position of choosing a circumnavigating boat at this point, however, I would suggest you attack this from the other side. Instead of starting with numbers that you would use to screen in or screen out certain boats, look for experts opinions on boats that would make good circumnavigators, then see if they fit your idea of a good offshore boat. In the end, you will probably be limited somewhat by budget and geography anyway.
Valiant 32
Barquito is offline
post #10 of 32 Old 10-11-2013
Old as Dirt!
svHyLyte's Avatar
Ted Brewer's "Comfort Ratio" seems to be a useful indicator of yacht performance in our experience. For more information see (click on) Crunching Numbers.
svHyLyte is offline
Morgan 41 OI stability ern-n-jo Boat Review and Purchase Forum 42 10-09-2015 09:05 PM
Capsize and Stability casey1999 Seamanship & Navigation 10 07-28-2011 09:29 PM
Stability simplified E32Strider Sailboat Design and Construction 3 07-17-2009 09:56 PM
