Genoa Track cars and things - SailNet Community
post #1 of 12 Old 10-11-2013 Thread Starter
Dave_E's Avatar
Hi All,
After researching for awhile and not coming up with much, I thought I'd ask the experts. My Allmand 31's first PO was a sailing nut who installed about every piece of running rigging you could, all lines lead aft etc.. I have 2 geanoa tracks on each side, a long one on the rail and a short one next to the cabin structure.
The outside rail had 3 cars on it. One was your basic block (that opens up with a turning, locking pin), then there was one with a springy pulley on it, then there is one with a metal loop on it.
I have never used anything but a basic block to run jib sheets through on their way to the winch. Can someone please explain what the other 2 are for. (I can guess the sringy pulley was for the spinaker)? Thanks.
Dave
Allmand Sail 31 #15 "Traveler"
GOD, Family, career
Dave_E is offline
post #2 of 12 Old 10-11-2013
grumpy old man
Re: Genoa Track cars and things
Hmmmmm:
You would not lead a spin sheet that far forward. It could be for the spin guy if you are flying a sym spin with pole.
Othere than that I don' know.It's great you have an outboard track for reaching but you only need one block on it. I'm not sure what you mean by "basic block" and " springy pulley". "Metal loop on it" ? No idea what that is.
Maybe you should post a pic. Can't imagine why you will need more than one block on that outboard track. It would be a good place for a snatch block so you can move your jib sheet from the inboard to the outboard track eaily.
Bob's Blog ....
bobperry is offline
post #3 of 12 Old 10-11-2013 Thread Starter
Dave_E's Avatar
Pictures are worth a thousand words. I have all 3 of these on the outside track and one block on the inside track.
GOD, Family, career
Dave_E is offline
post #4 of 12 Old 10-11-2013
overbored's Avatar
the track on the Allmand does go back far enough to be used for a spinnaker or gennaker sheet. sounds like he is talking about a spring stand up block and a snatch block. the bigger of the two would be for the genoa. the stand up block to be used for a spinnaker because the block will not get a warp on the line and is ready when it is needed. the metal loop is made to attach another block if one is needed. could be slid forward on the track to be used for a boom preventer or vang
"GOLD RUSH" PRINDLE 16
overbored is online now
post #5 of 12 Old 10-11-2013
no longer reading SailNet
Alex W's Avatar
I also use the metal loop for my spring line when tying up the boat (I use a temporary line from the primary winch for controlling the boat while docking). The one that I have is strong enough for that purpose and doesn't catch sheets the way that a track mounted cleat would.
My tracks don't go far enough aft for spinnaker sheets, so I have two blocks attached to dyneema loops that are mounted on the aft docking cleats. On my old Catalina 25 the tracks did go all the way to the far end of the boat and there were two sets of blocks on them, one for jib/genoa sheets and one for spinnaker sheets.
Alex W is offline
post #6 of 12 Old 10-11-2013
Another use for an additional block at the aft end of the track is to ensure a good lead angle to the winch drum regardless of jib car position (ie the sheet runs through both blocks). This is especially helpful on boats with strong sheerlines where forward positions of the jib car create 'too flat' a lead angle to the winch. In addition it can help avoid chafe on the cabin side or coaming on the port winch, which must lead to the inside of the drum.
I run our sheets through a block on the toerail for that reason...
Faster is offline
post #7 of 12 Old 10-11-2013
grumpy old man
I'd keep the stanbd up[ "sping" block for the jib sheet when reaching and I'd keep the pad eye car for a snatch block for whenever you need it. Maybe use it to barber haul your jib sheet when it's on the inner track. The all black block is redundant.
Bob's Blog ....
bobperry is offline
post #8 of 12 Old 10-13-2013
Faster,
I would also add that snatch blocks like you are using there have dramatically lower working loads than fixed blocks, and should not be used for permanent fair leads.
Greg
Stumble is online now
post #9 of 12 Old 10-13-2013
Originally Posted by Stumble View Post
Faster,
I know you've mentioned that before... but these have been doing the job for a long time, and we used similar blocks on our earlier 40 footer without incident..
Faster is offline
post #10 of 12 Old 10-13-2013
overbored's Avatar
Have to agree with Faster. looks like a Ronstan block which is rated at 5000#, which is a way higher rating then most standard blocks with that sheave size.
Modification for adjustable genoa cars patrscoe General Discussion (sailing related) 8 01-29-2013 05:09 PM
genoa cars and travellers rmeador Learning to Sail 6 07-27-2011 12:03 PM
lubricating traveler and genoa cars rmeador Gear & Maintenance 7 09-24-2010 12:27 PM
Replacing Genoa Track Cars. tager Gear & Maintenance 6 01-25-2009 08:50 AM
Harken Lead Cars on 1 Inch Track? mr_lucky Gear & Maintenance 2 10-16-2007 02:46 PM
