Replacing Engine Driven Water pump with electric - SailNet Community
 2Likes
post #1 of 18 Old 10-12-2013 Thread Starter
Has anyone documented the variation in water flow from 2000 RPM to 4000 RPM on a Sailboat engine? If i replace the mechanically driven pump with an electrically driven pump tied directly to alternator (only running when the engine is) What flow should i be looking for? Yamnar 2QM15 in the new motor I am looking at dropping into my 30 hunter
Thank you in advance for your assistance
Sean
seanreid71 is offline
post #2 of 18 Old 10-12-2013
One of None
deniseO30's Avatar
Re: Replacing Engine Driven Water pump with electric
I thnk most people will say "DON"T!" My own thoughts are that 12 volt motors can't run continuously for hours and hours. The water flow varies with the heat increase as the engine speed increases. I think it's around 5 gals a min, don't know actually. The Yanmar will have it's own pump, so I wonder why your thinking you want electric for the pump. Is it for the engine coolant, or the sea water?
My last project!
deniseO30 is offline
post #3 of 18 Old 10-12-2013 Thread Starter
When I got the engine, the water pump pulley is not there. so I need to find either a new pump or a pulley that will work. New Pump is $400, Electric Pump is $125 Was just trying to think outside of the Yanmar Box
Raw Water (salt)
post #4 of 18 Old 10-12-2013
I've seen it done especially on gensets or where there were originally multiple pumps. There's no reason it won't work in theory. Most electric pumps are not designed to be run continuously. Those that are can be expensive. Only an example. The little Johnson pump on my refrigerator pumps 1.6L minute and costs about $250.
svinshallah is offline
post #5 of 18 Old 10-12-2013
azguy's Avatar
a mechanical pump is simple and will last for a decade, it should be the 1st choice IMHO..
azguy is offline
post #6 of 18 Old 10-12-2013
Agree with above...If you have an electrical problem you now also have an engine problem...most diesel engines will run without electricity but not without cooling...
CalebD likes this.
Bob142
Desolation Sound
Maple Leaf 48
Any storm in a port...
Bob142 is offline
post #7 of 18 Old 10-12-2013
Sea Sprite 23 #110 (20)
mad_machine's Avatar
if you can get the dimensions of the pulley, you can probably have one made for less than 400
Art Haberland
In the end all that matters is how fully you loved, how gently you lived, and how gracefully you let go of things that did not belong to you -Buddha
mad_machine is offline
post #8 of 18 Old 10-12-2013
One of None
deniseO30's Avatar
Find out what tractor that engine goes in. for example.
John Deere 332 Tractor Yanmar 3TN66UJ 18HP Diesel Engine Water Pump Pulley | eBay
My last project!
post #9 of 18 Old 10-12-2013
Dirt Free
boatpoker's Avatar
I think I'll call my next boat "In Theory" .... cause' "in theory" everything works.
bristol299bob likes this.
Be the man Sharon thinks I am - wg
I can do that
- wg
Be the master of your own disaster - wg
If you're not laughing, you're not doing it right. - wg
if you can live with the consequences, go for it. - wg
I yam what I yam an' thats all that I yam. - Popeye
boatpoker is offline
post #10 of 18 Old 10-12-2013
Ask around boat yards they may have one used off a blown engine.
ctl411 is offline
Replacing IC engine with electric motor WilliamsRDan Electrical Systems 13 10-11-2012 06:27 AM
Engine Driven Bilge Pump TwoD83 Gear & Maintenance 13 06-27-2012 05:22 PM
Volvo MD2 electric water pump papaalhawaii Diesel 1 10-12-2011 12:02 PM
Alternator RPMs after replacing an engine driven Refrigeration system fputman Gear & Maintenance 3 04-11-2010 09:13 PM
Replacing water pump impeller tip Gear & Maintenance 8 04-06-2010 02:03 PM
