Had the boat two days, two problems already... - Page 3 - SailNet Community
 16Likes
post #21 of 30 Old 10-13-2013
Fortuitous
chip's Avatar
Re: Had the boat two days, two problems already...
Nice. It gets so much worse from here.
Minnesail likes this.
My Boat Log, or "blog" if you will:
chip is offline
post #22 of 30 Old 10-13-2013
Daniel - Norsea 27
Rhapsody-NS27's Avatar
that's nothing.
You should see what happened to me on day one of ownership when I towed the boat home. Tire tread pealed off and took part of the trailer fender with it.
Rhapsody: Traveling To New Home
There will be plenty of days where things don't seem to go right. Just keep at it.
Daniel
1981 Nor'sea 27,
“Who is staring at the sea is already sailing a little.”
-Paul Carvel
Rhapsody-NS27 is offline
post #23 of 30 Old 10-13-2013
no longer reading SailNet
Alex W's Avatar
Originally Posted by whroeder View Post
BOAT - Better Open Another Thousand
One good thing about the OP's Catalina 22 is that it is more like "another hundred".
Smaller boats in the 22-25' range are a great starting point for that reason. It's hard to even come up with items on them that cost $1000. New sails for a Catalina 22 can easily be acquired from major lofts (like North Sails) at well under $500 ea, a 4hp outboard is barely over $1000, they don't soak up much bottom paint, etc.
They are also tons of fun to sail and very forgiving.
The downside is that they are quite compact when it is time to go cruising. A friend did a 2 week trip on his Catalina 22 last summer, half of it with his girlfriend, but the experience just made him want a bigger boat. I had the same realization when doing a 12 day trip on a Catalina 25 with my wife.
Whenever I see brand new site members asking about buying 51' boats for their first boat I wonder if they realize that BOAT in that case stands for "break out another tenThousand".
Alex W is offline
post #24 of 30 Old 10-13-2013 Thread Starter
Minnesail's Avatar
Originally Posted by Alex W View Post
One good thing about the OP's Catalina 22 is that it is more like "another hundred". Smaller boats in the 22-25' range are a great starting point for that reason.
That's my hope with this boat. At some point I think I would like to own a larger boat, but a 22' should get me used to some big boat issues except that my mistakes will cost $300 instead of $3000.
That being said, Catalina Direct wants $500 for a spinnaker pole? For a freaking 8' bit of aluminum with plastic at each end? And how can roller furlers be so expensive, it's just a spool!!!!! (I know, I know, I realize how this sounds.)
Minnesail is offline
post #25 of 30 Old 10-13-2013
Alex W's Avatar
I wouldn't put roller furling on a Catalina 22. Get two foresails, a jib in the 135-150% size range and another in the 100-110% size range. A hank-on headsail is really easy to manage on this size of boat, and the 100% headsail will sail a whole lot better than a 135% rolled down to 100%. Since storage space is tight on a 22' boat it's worth getting a jib-bag that can cover a hank-on sail while it is still hanked on. Save that investment for the next boat (or don't...I often wonder why I put roller furling on my Pearson).
Spinnaker pole expense is in the ends, not the aluminum. The best way to get these cheaply is to find a used one.
The expensive part of roller furling isn't the spool, it is the two sets of bearings (at the tack and head) that need to be very smooth even under very high loads, and the upper bearing has to slide up and down the roller furling extrusions nicely too. The systems aren't that different on a 22' vs a 35', so this is one case where smaller doesn't save you too much. That said Harken does make a nicer small system called the 00AL that is a lot cheaper than the Mark IV while being similar in performance.
Avoid being drawn in by an inexpensive CDI or Alado furler. Halyard tension is a useful sail shape control, and those furlers make it very hard to adjust. The simpler design allows them to be less expensive, but I think you are giving up too much.
Alex W is offline
The Following User Says Thank You to Alex W For This Useful Post:
Minnesail (10-13-2013)
post #26 of 30 Old 10-13-2013
I could see cheaping out and using a regular trailer tire, instead of a proper marine-grade tire, for the front of the trailer or just as a spare. But honest, using coat hanger wire instead of the proper marine-grade bronze or stainless scupper drain cleaning wires? What's next, sneakers instead of proper deck shoes?
hellosailor is offline
post #27 of 30 Old 10-13-2013 Thread Starter
Minnesail's Avatar
That's good to know, thank you. The boat came with four headsails, from a storm jib to a 170 drifter. Roller furling is very handy, but very expensive.... I may well stay with the hank on.
I do want a main cover though. The previous owner kept the main below and rigged it all up every time he sailed. I would like to make it easier than that.
post #28 of 30 Old 10-13-2013
daddyhobbit's Avatar
Minnesail,
Yes, this sometimes is what owning a sailboat is about, but the other times make up for it. The problems that you have encountered do not make the boat un-seaworthy. Pump the tire up, clear the clog in the drain and go sailing. Every time I have a problem with Osprey I fix it and then go for a sail, at times I forgo the fix and just sail then fix the issue.
Hang in there, once you have addressed all the issues the next sail will be spectacular considering you repaired and made your way out into the waters.
Jim
SV Osprey
Saint Thomas VI
daddyhobbit is offline
post #29 of 30 Old 10-13-2013
Alex W's Avatar
Main sail cover is very useful. Luckily they are also pretty cheap. There are a couple of people on eBay who are making them out of Sunbrella for around $100.
I don't think the storm jib was ever used on our Catalina 25. We didn't have a double reefing main that would keep the boat balanced with that little foresail. If space below is a concern then I'd keep that and the drifter at home, keep the working jib and genoa onboard.
Alex W is offline
Minnesail (10-14-2013)
post #30 of 30 Old 10-13-2013
Fortuitous
chip's Avatar
I have a furler, and it's ok. I got it second hand, and they made me an offer I couldn't refuse. Managing the foil when taking the mast up or down is pain, and the sail shape is probably marginally worse with a furler, but it is pretty convenient.
If I had it to do over again, I probably would have stuck with hank-ons, but would have rigged a downhaul so that I could get the headsail down in a hurry from the cockpit if anything weird happened. I thought I broke my furler at the end of last season, and was fully prepared to just rip it off and go back to hanks, but it didn't die, so eh...
I'd try it without a furler for a while and see if you really need it.
chip is offline
The Following User Says Thank You to chip For This Useful Post:
Approximately how many days a year are you on your boat? administrator Sailnet.com Polls 43 03-18-2015 06:23 PM
Trapped in a sunk boat at 100 feet for 3 days davidpm General Discussion (sailing related) 16 06-20-2013 01:02 PM
For the days I can't take the big boat out ChuckBuck General Discussion (sailing related) 6 11-25-2012 08:54 PM
building a boat in 7 days dylanwinter1 General Discussion (sailing related) 11 01-20-2012 04:52 AM
I built a boat in 2 days... eMKay Sailboat Design and Construction 4 07-07-2008 08:35 PM
