Two large holes in transom - SailNet Community
 2Likes
post #1 of 14 Old 10-12-2013 Thread Starter
Hey guys...
I just started sailing this year.. and picked up a little dinghy sailboat for a hundred bucks off kijiji....
along with a drain plug.. there are two large 3" holes in the transom with 2 hinged flap doors just above the drain hole... what are they for? they are held shut with a bungie type line on the inside on the floor.... but still kinda leak...
Can I glue them shut... ?
Any incite would be appreciated.
Cheers
@propkulture
propkulture is offline
post #2 of 14 Old 10-12-2013
One of None
deniseO30's Avatar
Re: Two large holes in transom
self draining feature is my guess.
My last project!
deniseO30 is offline
post #3 of 14 Old 10-12-2013
overbored's Avatar
they are self bailers. if they leak a little then sail faster
"GOLD RUSH" PRINDLE 16
overbored is offline
post #4 of 14 Old 10-12-2013 Thread Starter
Bailers? even when pulled shut......they seem to let more water in than out... especially when weight is aft....
I took a sailing course this summer and none of the instructional boats ie 420's... TOPAZ's had these holes on them... the self bailers were in the middle on the floor...
Am I doing something wrong? other than not sailing fast enough? lol
thanx again for any help
Cheers
post #5 of 14 Old 10-12-2013
bljones's Avatar
Prop, what kind of boat are we talking about?
Barring evidence to the contrary, over has it right- self-bailers. aging shock-cords that have lost their tension and worn-out seals will mean that they leak- it's pretty typical. don't glue them shut, just renew them.
It's 5 o'clock somewhere:
bljones is offline
post #6 of 14 Old 10-12-2013
What you got there is actually a fishing dingy made by Master. Paddle over to a school of herring and open the baiter ports. The fish rush in. Close the flaps and go fishing.
Rockhopper likes this.
Capt Len is offline
post #7 of 14 Old 10-12-2013 Thread Starter
Evidently... CAPT len is the resident "funny man" eh?
post #8 of 14 Old 10-12-2013
no longer reading SailNet
Alex W's Avatar
Our 505 has those in addition to self bailers. They sit above the waterline on the transom (normally the whole transom should be above the waterline), so water doesn't come in through them. The shock cord holds them closed, but you can open them to let water out.
Look at almost any photo of a 505 and you'll see them.
They also make it easy to drain the water when putting the boat onto a trailer or up on a dock.
Alex W is offline
post #9 of 14 Old 10-13-2013
One of None
deniseO30's Avatar
you could push your legs through... use your feet to push off the dock.....
kunkwriter likes this.
My last project!
post #10 of 14 Old 10-13-2013
While they may leak a bit now, they'll leak out a whole lot more if you ever manage to swamp/fill the boat, and you'll be glad for it.
Faster is offline
Transom Cover sabre386raven Gear & Maintenance 4 05-23-2008 03:00 PM
XL shaft o/b on low transom merttan Gear & Maintenance 5 04-15-2008 07:29 PM
P-26 Transom Trim Scubado Gear & Maintenance 1 07-01-2005 10:25 PM
large main or large headsail? jbarros Boat Review and Purchase Forum 2 09-29-2003 06:13 PM
