Who uses a Larkshead on their jib sheets? - Page 2 - SailNet Community
 5Likes
post #11 of 24 Old 10-15-2013
Irrationally Exuberant
Re: Who uses a Larkshead on their jib sheets?
The larkshead has worked fine on our jib. Definitely tough to unknot at the end of the season, but a little coaxing and an assist from a pair of needle nose pliers always did the trick.
Tom K
2000 Beneteau 331
Northern Chesapeake Bay
arf145 is offline
post #12 of 24 Old 10-15-2013
Tartan 27' owner
CalebD's Avatar
Fid ~ 2. A large tapering pin used to open the strands of a rope before splicing.
A tool like this will help you undo your Larkshead or Cow Hitch more betterly.
Everybody has one:
CalebD is offline
post #13 of 24 Old 10-16-2013
use larkshead on my 465 sq ft genua, removes the sheets now and then, never any problems.
Works fine. Somewhat heavy.
/J
Jaramaz is offline
post #14 of 24 Old 10-16-2013
We find we minimize hanging up the bowlines on the rigging by insuring plenty of slack on the released sheet and not aggressively pulling the new working sheet until the clew gets to the mast. Wind will do the work for you, if you don't create opposing tension on the two sheets, which drags the clew across the standing rigging.
Faster likes this.
Jeanneau 54DS
Minnewaska is offline
post #15 of 24 Old 10-16-2013
JimMcGee's Avatar
We use a larks head.
I have a fid on my sailing knife. A few minutes working the knot with the fid at the end of the season loosens the knot for storage. Really not a big deal...
95 Catalina 30 Island Time
The sail, the play of its pulse so like our own lives: so thin and yet so full of life, so noiseless when it labors hardest, so noisy and impatient when least effective." - Henry David Thoreau
JimMcGee is offline
post #16 of 24 Old 10-16-2013
Junior member, rest old
msmith10's Avatar
I use a larkshead but I place a short piece of 1/8" line with stopper knots on each end under the looped section. That makes it easier to undo the knot after it tightens up. I rarely leave sheets on for more than a couple days at a time, though. I have hank-ons, and I'm either changing sails or sheets (light/heavy) frequently.
Mark Smith
1977 C&C 30 Mk 1 hailing from Port Clinton, Ohio
msmith10 is offline
post #17 of 24 Old 10-16-2013
travlin-easy's Avatar
When I used a bowline the hangups were constant. The larkshead never seems to hang.
Cheers,
Gary
travlin-easy is offline
post #18 of 24 Old 10-16-2013
no longer reading SailNet
Alex W's Avatar
Once you get to the point of changing sheets for different wind conditions you might as well start using tapered sheets as well. Then a Larks Head doesn't work as well though, and switching to some form of soft shackle is best.
I like splicing projects, so I got a bit overboard here and have 3 sets of sheets (light, normal, heavy), the lightest two of which are tapered. They are tapered by splicing dyneema to double braid, though next time I'll probably just look into using a stripable line.
Alex W is offline
post #19 of 24 Old 10-16-2013
I don't discuss my member
zz4gta's Avatar
Larkshead for one sheet. If using two, then go with splices and a soft shackle.
Merit 25 # 764 "Audrey"
zz4gta is offline
post #20 of 24 Old 10-16-2013
Alex W's Avatar
Originally Posted by Stumble View Post
I prefer to minimize knots on the headsail... I use two part soft shackles. Where the diamond knot stays on the sail and the sheets can be easily detached.
This is what I'd do if I was starting over. I made these for my spinnaker pole topping lift and downhaul and like how they work.
For everyone else: http://l-36.com has the best documentation on this stuff that I've found. Look at the "better soft shackle", "halyard soft shackle" and also how he splices amsteel to double braid for halyards.
I'm using the amsteel to double braid splice on my jib sheets, but the splice doesn't like all of the twisting that you get from using the winch. This is why I'd just use a strippable line next time.
DJR351 likes this.
Alex W is offline
Jib Bag and sheets rhr1956 Gear & Maintenance 19 02-12-2012 10:19 AM
Jib sheets, In or Out?? Cope44 General Discussion (sailing related) 27 09-22-2008 03:11 PM
My new Jib Sheets US27inKS Gear & Maintenance 2 09-03-2008 03:22 PM
Jib sheets - two versus one KiddSpinn Gear & Maintenance 8 05-28-2008 04:12 PM
Jib Sheets PBzeer Gear & Maintenance 15 10-07-2007 03:35 PM
