What wood is this cabin sole made off?? - Page 2 - SailNet Community
 1Likes
post #11 of 12 Old 10-16-2013
RichH's Avatar
Re: What wood is this cabin sole made off??
I had similar uh-ohs on a quality built taiwanese boat. The strakes were 1/4 thk teak and 1/4 x 1/4 white meranti (?). I found my meranti at a 'quality' hardwoods dealer and carefully 'routed out' all the old and simply very carefully 'inlaid' the new.
For a wet section of sole that began to rot away from underneath in the supporting ply, I cut out a square section of the sole with a very fine 'cabinet saw blade' (on a fein tool), removed the 1/4 thick teak straking and (probably) white meranti without loosening the strake to strake glue lines by careful chiseling/grinding/sanding away the adhering underdecking and then simply re-glued to the rebuilt 'underdeck'. The only way one can determine that this was a repair was to closely look for those very thin 'cut lines' that were filled with 'saw dust filled resin'.
hope this helps.
RichH is offline
The Following User Says Thank You to RichH For This Useful Post:
Cruxandreams (10-25-2013)
post #12 of 12 Old 10-25-2013 Thread Starter
young salt
Cruxandreams's Avatar
Appreciate all the responses, Ill try to remember to post pics when I finish the job.
Cruxandreams is offline
Putting in new floors and a cabin sole. Also planning a new cabin layout. Advice? sully75 Gear & Maintenance 4 10-02-2013 01:30 PM
Non wood interior sole alternative Petar Gear & Maintenance 22 12-12-2012 11:58 PM
Cabin sole Dmarina Gear & Maintenance 7 04-27-2011 10:12 PM
Cabin sole sandyv38 C & C 3 12-17-2010 12:53 PM
Wood cabin sole/floor saurav16 Gear & Maintenance 5 04-02-2007 10:50 AM
