09-23-2004
Super Moderator
Small Boat/laminated ribs?
Generally exterior grade plywood will not hold up very well, even if coated with epoxy. While the glues are similar, exterior grade plywood generally is allowed to have a larger number of voids and uses poorer grade veneers and lower heat and pressure. As a result even when coated moisture will permiate deep into the wood by way of the voids causing the boat to rot or delaminate. That said, I have built a number of disposable prototypes over the years using AC grade exterior plywood and coated them with epoxy.
