Thinking of Losing My Inboard - Page 3 - SailNet Community
 34Likes
post #21 of 59 Old 10-23-2013
Tartan 27' owner
CalebD's Avatar
Re: Thinking of Losing My Inboard
Lin & Larry Pardey: Newsletters & Cruising Tips | Sailing Newsletters & Cruising Tips
Famous cruising authors who favored traveling without an engine.
Everybody has one:
CalebD is online now
The Following User Says Thank You to CalebD For This Useful Post:
Kielanders (10-24-2013)
post #22 of 59 Old 10-23-2013
You really are funny!!
chrisncate's Avatar
Originally Posted by Kielanders View Post
The authors, or members on this forum?
The authors. You been reading them at all?
chrisncate is offline
post #23 of 59 Old 10-24-2013 Thread Starter
Kielanders's Avatar
No, I'll look into their material.
Kielanders is offline
post #24 of 59 Old 10-24-2013
He seems to like it:
Re-powering Jean-du-Sud
Also presents an alternative method regarding placement.
As much as having one less potential leak in the hull around a prop shaft, I'm torn. Nothing like a burly diesel for when things get testy. Also keeps fuel issues down to just keeping it clean. Gas brings about additional fire hazards. It comes down to the individual. You can make it work either way.
seabreeze_97 is offline
The Following User Says Thank You to seabreeze_97 For This Useful Post:
Kielanders (10-26-2013)
post #25 of 59 Old 10-24-2013 Thread Starter
Kielanders's Avatar
No, god no, don't. I was asking as I was just wondering if you had maybe gotten infected by either authors blather and bad advice regarding going motorless.
Forget I mentioned them, these aren't the droids you're looking for.
(Pick up a nice Hal Roth book if you are in the mood for some practical cruising reading/advice)
Okay, I'll skip them. I was very intrigued watching the movie Deep Water, sad and tragic as it was.
About the only person I've followed in print on his blog and videos, though not yet bought his book, is The Simple Sailor (http://www.thesimplesailor.com). He's an older English boatwright who's junk rigged a Westerly Centaur, and sailed up into the Arctic Circle singlehanded.
I'm reregging my small boat very simply for singlehanding, and I approach his age, would like to make similar trips; modest, unique, achieveable, personally memoriable.
chrisncate likes this.
post #26 of 59 Old 10-24-2013
chrisncate's Avatar
Best of luck in your quest Kielanders, maybe keep this thread updated as you progress?
The Following User Says Thank You to chrisncate For This Useful Post:
post #27 of 59 Old 10-24-2013 Thread Starter
Kielanders's Avatar
Thanks to you and others for giving me the benefit of your experience. I will keep you posted.
Best,
Neil
post #28 of 59 Old 10-25-2013
lillia28's Avatar
Location: Central New Jersey, sailing on the Navesink River and Sandy Hook Bay mostly.
If I can chime, Don't do it. I did do it on a 28 foot fin keel. It worked OK, but there are severe limits to its practicality. It was fine in flat water, not so much in choppy. Although the diesel was nearly 300 lbs, the 120lb outboard hung off the stern left her trimmed down at the stern by a few inches, kept my rudder stuffing box under water, and caused a small drip. Having a decent sized crew member walk to the bow to grab a mooring line would raise the prop enough to basically end forward propulsion. My OB has a 10 amp alternator, next to useless given the limited run time. Not to mention above deck fuel tank and wiring was messy. I was saving for a repower and had an OB hanging around, so it didn't cost much, and it let me use the boat, but as a permanent solution the cons outweigh the pros. On a double ender, I don't see an easy way to install a mount, without an expensive engineering project. And just to start another controversy, I found the Beta 14 to be the least expensive diesel option. IIRC, the rebuild on the 1 cyl Yanmar was $5300, and the Beta was $5700 with a 2 year warranty, or some such.
Lou
davidpm likes this.
lillia28 is online now
The Following User Says Thank You to lillia28 For This Useful Post:
Kielanders (10-25-2013)
post #29 of 59 Old 10-25-2013
Markwesti's Avatar
The Laurin Koster seems to have a high pedigree . To put a out board on would be a mistake for all that has been said , plus ruin her good looks .
Markwesti is offline
The Following User Says Thank You to Markwesti For This Useful Post:
post #30 of 59 Old 10-25-2013 Thread Starter
Kielanders's Avatar
Lou
$5300 seems steep. Did you have the rebuild done at a marine shop?
I've done a few automotive engines (gas). I was going to have the Yanmar (head, block, crank, & piston) professionally remachined (w/ new valves seated), doing the breakdown and reassembly myself from a full rebuild kit - replacing other components (impellers, oil pump, etc) as necessary. I haven't reviewed the manual yet to write-up a game plan.
Something I'm missing, is this harder then it seems on a marine engine?
By the way, does anyone know the Kubota equivalent of a Yanmar 1GM10 for parts sourcing?
Losing My Gelcoat lenhubbard Gear & Maintenance 5 10-28-2007 10:18 PM
Losing rudder at sea Zanshin Cruising & Liveaboard Forum 59 04-30-2007 11:23 AM
