Bomar Hatch Plexiglass Replacement - SailNet Community
 1Likes
  • 1 Post By capta
post #1 of 8 Old 10-21-2013 Thread Starter
Master Mariner
capta's Avatar
Unfortunately we broke the plexiglass on one of our Bomar hatches, We can replace the plexi here in Trinidad, but I have no idea what glue should be used to secure the plexi to the aluminum. What is presently in there is definitely not contact cement, nor does it seem to be a silicone.
Does anyone know what Bomar recommends?
Thanks.
facebook.com/svskippingstone
Our Videos;
capta is offline
post #2 of 8 Old 10-21-2013
Re: Bomar Hatch Plexiglass Replacement
Pompanette (Bomar's parent company) has their own adhesive, I ordered some seals from them once and they would only ship overnight, which would have cost more than the seals if they hadn't been grossly overpriced to begin with.
Bomar - Useful Sealants - Gasket Glue; Lens Glazing Sealant.
Select Plastics has something else they recommend
ADHESIVES, SEALANTS AND LUBRICANTS - Hatchmasters - Norwalk, CT - Lewmar Hatch Repair Specialists
"Just call me TB"
capttb is offline
post #3 of 8 Old 10-21-2013
Capnblu's Avatar
Use Dow 795.
Why, why, why?
I Don't Know! I Don't Know!
Capnblu is offline
post #4 of 8 Old 10-21-2013 Thread Starter
Master Mariner
capta's Avatar
Thanks a lot.
I hope I can find one or the other here in Trinidad. Did a search, but couldn't find a distributor, here.
Our Videos;
capta is offline
post #5 of 8 Old 10-22-2013
I just did a hatch with Sika 295UV. Good stuff and UV resistant.
Vindö 50
copacabana is offline
post #6 of 8 Old 10-22-2013 Thread Starter
Master Mariner
capta's Avatar
For the believe it or not file;
I found Lexan and the retailer cut it to size, and beveled the corners while we waited, here in Trinidad. He even had the Corning 795! All for the paltry sum of tt$477.00 (around us$70.00). Amazing.
So thanks all; we're water tight once again.
Faster likes this.
Our Videos;
capta is offline
post #7 of 8 Old 10-22-2013
Maine Sail's Avatar
Capta,
Just be sure your Bomars have the supporting cross bars under the lens. These are the hatches designed for polycarbonate. If they are Bomars initially designed for cast acrylic then you DO NOT want to step on the polycarb or you will likely wind up in the cabin. Green water can do the same. Polycarb is much less brittle but a LOT more flexible...
Seeing as you cracked your lens my guess would be the hatches were designed for cast acrylic not polycarbonate.
______
-Maine Sail / CS-36T
Maine Sail is offline
post #8 of 8 Old 10-22-2013 Thread Starter
Master Mariner
capta's Avatar
The hatches do indeed have the two bars. I also doubled the thickness and had it beveled so it won't be a toe killer. It cracked because the Zodiac transom hit it just right. The old piece was just plexi, not Lexan, so we should be fine. 30 years in the sun and three years of the dink on top when sailing, I'm surprised it lasted as long as it did.
Thanks.
Our Videos;
capta is offline
bomar hatch repair argofred Gear & Maintenance 13 03-21-2016 10:06 AM
Bomar hatch hinge Sabre 30 1986 MK III nepple Sabre 0 08-22-2011 11:09 PM
Plexiglass hatch question Parclan Gear & Maintenance 2 06-30-2010 01:36 PM
Bomar 100 series hatch? EdHouston General Discussion (sailing related) 1 05-02-2008 12:25 PM
leaky bomar deck hatch on 29 mk 2 hiatus C & C 1 09-24-2006 01:45 PM
