painting bilge? why not? - SailNet Community
 4Likes
  • 4 Post By tommays
post #1 of 7 Old 10-22-2013 Thread Starter
Cool painting bilge? why not?
I have no boat, just a compelling curiosity.
Would painting a bilge and or engine compartment have any bad results?
Would epoxy(two part), deck paint, or gelcoat be best or worst.
Hopefully it would make the bilge easier to clean even it it did make all the
mess stand out. Would it encourage or discourage water in hull fiberglass?
Zen is a matter of recognizing reality.
desert rat is offline
post #2 of 7 Old 10-22-2013
overbored's Avatar
Re: painting bilge? why not?
best to use a bilge coating a special paint for the bilge
"GOLD RUSH" PRINDLE 16
overbored is online now
post #3 of 7 Old 10-22-2013 Thread Starter
Thanks exactly the information I needed.
post #4 of 7 Old 10-22-2013
TQA
Bombay Explorer 44
TQA's Avatar
Danboline has been covering up grot and grime for many a year including my bilges and locker interiors.
International peddle it Danboline Bilge Paint | International
TQA is online now
post #5 of 7 Old 10-22-2013
Master Mariner
capta's Avatar
The biggest problem with painting an engine room (compartment) is getting it clean enough for the paint to adhere. Especially if using a 2 part, if it doesn't adhere, it may come up in pieces that can clog pumps and limber holes.
But nothing looks nicer than clean, painted bilges and engine room.
facebook.com/svskippingstone
Our Videos;
capta is online now
post #6 of 7 Old 10-22-2013
tommays's Avatar
You can clean anything if you scrub long enough
T37Chef, miatapaul, jimgo and 1 others like this.
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
post #7 of 7 Old 10-22-2013
T37Chef's Avatar
I have been painting and cleaning up the bilge and engine room areas for a while now and still not done. I can tell you that just like painting a room in the house, it can have a very satisfying result. Not only is it clean and pretty to look at, but you're more likely to spot a problem, whether it be an oil/fuel leak, water leak, etc. when its clean.
When I re-powered this Spring I painted everything I could while the old engine was out, including sanding and painting the engine bed. To a somewhat obsessive degree that I even painted where it would be covered by sound/heat insulation
Its true you need to be sure to prep well first. Because the boat was on the hard, I placed a bucket on the ground to catch and harmful chemicals that the bilge pump discharged when I rinsed it down, then discarded of it properly. I don't think this would be as easily done if on the water? Everything was wiped down with acetone IIRCC prior to paint.
As far as paints and application; I used Interlux Bilgekote (grey) and rolled it on for most of it using a 4" roller, cutting in areas with a brush first. In areas low in the bilge where water may settle I used Interlux 2 part Barrier Coat (grey)(yup, I always have about 1 cup of water in the bilge/pump area for several reasons). For the engine bed I think I used a heat resistant spray paint (white) from a local hardware store that would adhere to FG.
I have pictures somewhere but cant find the before and after shots, sorry.
Shawn
T37Chef is online now
Adding automatic bilge pump to manual bilge pump FirstCandC Gear & Maintenance 13 04-03-2013 08:59 AM
Installing automatic bilge pump in series with diaphram bilge pump... sweetdreamyamaha Gear & Maintenance 6 11-07-2009 11:36 AM
Shallow Bilge, Bilge Pump Switch labestia Gear & Maintenance 1 07-10-2009 02:40 PM
Bilge painting navis92 Gear & Maintenance 12 04-06-2009 11:11 PM
Painting the Bilge, What Paint Though??? Sapperwhite Gear & Maintenance 18 05-22-2008 02:39 PM
