what did I do wrong?! - SailNet Community
 1Likes
post #1 of 11 Old 10-22-2013 Thread Starter
I normally sail dinghy racers/ centerboard daysailers, so I'm used to doing things a certain way. I have at times sailed keelboats, and always found them more forgiving.
However, this past weekend I was out on a 22' keelboat and had an "issue".
Port tack Furling Full genoa out. 16-22 knots
Boat heeled excessively and was over powered . Helm eased Mainsheet quite a bit. At that time headsail caught a gust. Boat now had lee helm because of eased
Mainsheet , fell off wind (to stbd)and then jibed (spun). Wild.
As is typical in the Midwest, wind direction was changing up to 60 degrees or so.
What did I do wrong ?
FlyingJunior is offline
post #2 of 11 Old 10-22-2013
One of None
deniseO30's Avatar
Re: what did I do wrong?!
too much head sail.
harmonic likes this.
My last project!
deniseO30 is offline
post #3 of 11 Old 10-22-2013
Not sure what you did wrong. I assume if you were healed hard you were close hauled? I have trouble imagining going from close hauled to an accidental gybe, except for falling off and a wind shift simultaneously?
For future sails, I would furl a portion of the jib before I would be spilling the mainsail. First step furl the jib, it is so easy why not? If you are still overpowered then reef the main. I don't know when I would spill the main so much as to have lee helm, I like weather helm so I can feel what is happening and the boat rounds up if it gets overpowered.
Jordan
West Wight Potter 14 "Lemon Drop"
Oceanside CA
jephotog is offline
post #4 of 11 Old 10-22-2013
grumpy old man
Yeah, Denise is right. Way too much headsail.
16-20 knots?
You shoud have had a blade jib up. Max.
Bob's Blog ....
bobperry is offline
post #5 of 11 Old 10-22-2013 Thread Starter
Yes, we had reefed/furled headsail earlier, but then winds settled down a bit, so we let more out. I agree, too much headsail. I think it must have been that plus a shift in wind position. If we had been in a centerboard dinghy, we'd had been swimming.
I feel I'm fairly knowledgable and careful, so this upset me a bit. I guess I should have put one reef in the main at the dock (was calmer then, and only forecast up to 15 knots a little later) and reefed the headsail. Still kinda perplexing.
post #6 of 11 Old 10-23-2013
Tartan 27' owner
CalebD's Avatar
You didn't do anything wrong per se. You just had too much sail up, likely.
"Reef early, reef often."
and
"it is easier to shake out a reef than tuck one in".
Sometimes it is not so easy to figure out how much to reef.
Everybody has one:
CalebD is offline
post #7 of 11 Old 10-23-2013
Put whatever reef in pretty much the moment you find yourself wondering if you should...
Faster is offline
post #8 of 11 Old 10-23-2013
the pointy end is the bow
erps's Avatar
agreed, it's easier to shake it out if you don't really need it than it is to put it in when it's too late.
Ray
S.V. Nikko
1983 Fraser 41
La Conner, WA
erps is offline
post #9 of 11 Old 10-23-2013
SoOkay's Avatar
I agree with everyone that you went into the situation with too much sail out.
When the helmsperson (See i can be politically correct) eased the mainsheet, I think I would have eased the jib sheet instead. I feel that would have done a better job of depowering the boat and easing up on that excessive heeling.
It may also have avoided the boat jibing round the way it did.
But hey, that's my opinion. Ultimately the best solution would have been to reef earlier.
S/V Shangri La
Jeanneau 50DS
"Besides, if we get lost, we pull in somewhere and ask directions." --Captain Ron
SoOkay is offline
post #10 of 11 Old 10-23-2013
4KSB driver.
SHNOOL's Avatar
Full genoa 155? or 135? definitely too much headsail, sadly if the main wasn't eased, the boat would have griped and rounded UP not down.
Better to flatten the heck out of the main dump traveler, and if that isn't enough, vang on, and dump mainsheet... but also move genoa cars aft , and allow the genoa to twist off, but surely a smaller headsail or even a partially reefed headsail (furler after all) would have been better.
Or fly it all and stack up 4 or 5 200lb crewmates on the rail!
1983 WD Schock Wavelength 24. Production boat limit tester, blue-water bucket owner, with wine taste on a beer budget.
SHNOOL is offline
What is wrong here?? RandyBC Seamanship & Navigation 8 05-02-2010 11:47 PM
What went wrong? vabuckeye Learning to Sail 18 11-25-2007 06:56 AM
wrong way around CaptainHaddock Crew Wanted/Available 0 04-13-2007 06:20 AM
Sometimes, when everything goes wrong... CharlieCobra General Discussion (sailing related) 18 08-23-2006 05:08 PM
