2 part epoxy - SailNet Community
post #1 of 4 Old 10-23-2013 Thread Starter
trantor12020's Avatar
2 part epoxy
I've this epoxy where you cut the required amount and kneading it to get a good mix before applying. Problem is there is this green crusty part forming the outer layer of the epoxy like a tube. Not sure if the crust is part of the epoxy. I always inculded it in the mix but finds it tough to knead as the crust breaks into small pieces and is sharp! If I'm not careful the pieces would poke my hands. Am I doing this right?
Ken
2002 Hunter 326, SV Millennium 2
1999 Macgregor 26X, SV Millennium
trantor12020 is offline
post #2 of 4 Old 10-23-2013
Old as Dirt!
svHyLyte's Avatar
Re: 2 part epoxy
Trantor--I think the epoxy putty stick is well past it's use-by date. Once the air-tight seal from the maker is opened, the putty stick will only last a few (4-5) months, BTDT...
svHyLyte is offline
post #3 of 4 Old 10-23-2013
Delta-T's Avatar
Re: 2 part epoxy
I have used many. I found the Oatey works the best. Can be found in the plumbing dept at Lowes. I have never had a crusting issue. Kept wrapped up it lasts for at least a year. Epoxy Putty
Eric
Delta-T
1968 Bristol 32 Keel/Crb Hull 26
Narragansett Bay RI USA
Delta-T is offline
The Following User Says Thank You to Delta-T For This Useful Post:
svHyLyte (10-23-2013)
post #4 of 4 Old 10-23-2013
krisscross's Avatar
Re: 2 part epoxy
Your epoxy stick is probably quite old. I have used a piece of wood to knead one of those. If you can get it to mix well (become softer) and start getting warm, it will probably do the job.
Plato
krisscross is offline
Tanasi - A Mossy Topped Glander (part project, part dream) tanasi Introduce Yourself 2 03-04-2012 09:37 PM
1 part areosol spray epoxy huguley3 Gear & Maintenance 3 09-15-2009 12:31 PM
Anyone heard of Progressive Epoxy? also 2 Part Polyurethane Spencer28 Gear & Maintenance 0 06-22-2007 10:24 PM
