whats the best way to clean a fouled bootstripe? - Page 2 - SailNet Community
 3Likes
post #11 of 17 Old 10-25-2013 Thread Starter
Re: whats the best way to clean a fouled bootstripe?
You just go however many inches and snap a line or what. My boat has a funky curve the the back end as well. My biggest concern is laying that new line. Maybe I'm over thinking it.
Really what I'm saying is do you just measure up 6 inches from the waterline in several locations and follow those marks, i.e., how do you make sure the line is level?
abrahamx is offline
post #12 of 17 Old 10-26-2013
I use a product called FSP I get it from my local chandler. Its a blue gel product and I find it works great. Just brush it on with an old soft 3" paint brush and let it sit for a few mins and the using the brush to scrub it off while I rinse with fresh water.
Does well for the slime and rust stains and dirt in general.
Anthony
anthony1 is offline
post #13 of 17 Old 10-26-2013
blutoyz's Avatar
I second the toilet bowl cleaner...it is a fraction of the price of a "marine" product and works just fine
blutoyz is offline
post #14 of 17 Old 10-26-2013
Delta-T's Avatar
To mark the new water line location, assuming your boats sits level (port to starboard) use the existing scum line top edge as the existing actual water level. Or use your existing line to measure off of. To raise it 6" up from that point, you can use a pencil and measure up 7" and mark every 12" along the the boot. Or cut a piece of cardboard 7" (make template) use that instead of having to measure 100 times. Then take 1" painters tape and apply the tape. Applying the painters tape is good practice for the vinyl application. The painters tape is easy to apply and very forgiving. Like any tape, don't press in on too hard and it will can be easily lifted off and adjusted. When you have it where you want it, them apply pressure, then use a hard object to press the edges to get the best seal. You can also bend tapes to make a radius, not a tight radius. It depends on the width and type of the tape as to how tight a radius. Vinyl will bend easier that painters tape. Warmer vinyl will bend easier then cold... You will get the idea fast, and if not get help.
Eric
Delta-T
1968 Bristol 32 Keel/Crb Hull 26
Narragansett Bay RI USA
Delta-T is offline
post #15 of 17 Old 10-26-2013
Over Hill Sailing Club
smurphny's Avatar
I've used household cleaner, just water and a scotch pad, sometimes just sanded lightly (which you'll need to do anyway to recoat). It depends on how dirty it is and whether you've been in oily, scummy water for a while. If it's oily residue, some solvent like gas on a rag works or maybe some acetone LIGHTLY applied to a rag so you don't dissolve the existing paint. I need to repaint my waterline this year. Have been using Perfection but I don't like the way it holds up.
smurphny is offline
post #16 of 17 Old 10-26-2013
Siamese's Avatar
My local marina sold me a product called "Zing". Seems to do a nice job, and I use it annually.
Here's a link: Zing Ahead | Boat Hull Cleaner | Marine Cleaner | Aluminum Pontoon Boat Cleaner
Siamese is online now
post #17 of 17 Old 10-26-2013
TQA
Bombay Explorer 44
TQA's Avatar
On Off works for me. This what mine looked like when it came out this year.
ELEPHANTS CHILD: BEST LITTLE BOATYARD IN THE CARIBBEAN
Gahh can't link to the pic you will need to follow the link.
TQA is online now
Restoring bootstripe by wet sanding? TakeFive Gear & Maintenance 13 04-09-2012 08:20 AM
fouled furler QuickMick Gear & Maintenance 4 11-23-2009 09:28 PM
Bootstripe - is it necessary? Finallybuyingaboat Gear & Maintenance 10 05-04-2009 06:09 AM
Fouled halyards... #@&* Help! CLucas Gear & Maintenance 3 06-01-2008 08:23 AM
Surviving a Fouled Prop Tania Aebi Her Sailnet Articles 0 07-21-2003 08:00 PM
