-   -   What is the best way to Tarp a sailboat for winter (http://www.sailnet.com/forums/general-discussion-sailing-related/105167-what-best-way-tarp-sailboat-winter.html)
Grampian1989 10-30-2013 11:12 AM
Hello, First time sailor here, looking for advice w/pictures of how to properly Tarp my 30ft sailboat for the winter.....
Im assuming throwing one over the boom and another somehow over the bow. Ive heard of others taking one long tarp and cutting it, sliding it stern to bow... That didn't seem like a good idea because of the weight of snow... Im open to any ideas!!
Cheers,
J
caberg 10-30-2013 11:22 AM
Re: What is the best way to Tarp a sailboat for winter
One in the front, one in the back. The front one is supported by a 2x4, the back one goes over the boom. Use lines where necessary to add structure underneath. Some people build some pretty nifty PVC frames, but I found this to work great. Sorry I don't have a better picture but you get an idea of the front end. It's definitely not rocket science.
http://i638.photobucket.com/albums/u...c1f9c9052b.jpg
Grampian1989 10-30-2013 11:30 AM
Im in Upstate NY, and thank you for the pictures!! That is exactly what i was thinking. But would the snow on the deck of the boat be an issue?? if i use two tarps one on the bow, one on the stern... there is a space near the mast.. is that an issue?
caberg 10-30-2013 11:37 AM
Where the two tarps came together at the mast, I used short lengths of twine to tie the gromets together. There is a little space around the mast, I guess, but I had it pretty tight.
There are openings at both the back and front, a good thing in my view to let air flow through. The only idea is to keep snow/rain/ice/leaves from dropping directly down onto the boat and building up around the hardware, etc. Snow/rain slid right off my tarps all winter. Let's not forget these are boats, not some antique furniture, a little weather will not hurt them.
Also, I am in Vermont (this is in the Islands, actually, between VT and NY). Probably similar to your winters.
Grampian1989 10-30-2013 11:39 AM
Thank you for the advice!! Time to Winterize, Tarp and wait........Spring can't come soon enough!
caberg 10-30-2013 11:44 AM
Here's one other picture which shows the beginning of installing the front tarp. You may be able to see how I rigged the 2x4. I basically went up with a couple pieces of wood, some twine, some duct tape, 2 tarps, and had at it....
http://i638.photobucket.com/albums/u...psb71c27ca.jpg
Delta-T 10-30-2013 12:27 PM
It makes me cringe when someone near me on dry dock does their own tarp. 9 times out of 10 there will be more damage to their own boats and adjacent boats then it is worth, if you don't know what you are doing. Most of those tarps, the grommets are useless and will rip out, and the string I have seen used. Any movement of the tarp can cause wear and tear.
tommays 10-30-2013 12:34 PM
http://i565.photobucket.com/albums/s...r/PB152597.jpg
http://i565.photobucket.com/albums/s...1_11200046.jpg
The only downside of tarps is there hell on a hull with a good finish as the flapping during a winter blow can beat the carp out of the shine
http://i565.photobucket.com/albums/s...s/PC202623.jpg
http://i565.photobucket.com/albums/s...s/PC202624.jpg
Never under estimate the weight of one good snow storm when building the frame as we had 36" last winter on long Island in about 19 hours and even with that much pitch it was hard to stay ahead
caberg 10-30-2013 12:44 PM
9 out of 10? Is that a scientific study?
What kind of specialized knowledge do you need to tarp your boat? Is there a degree, trade school, certification?
Mine looked the same in spring as it did in fall, and I'm certainly no boat-tarp expert.
jimgo 10-30-2013 01:11 PM
Tom, I'm confused. Did you tarp over shrinkwrap?
