Cleaning brushes? - SailNet Community
 1Likes
  • 1 Post By pdqaltair
post #1 of 6 Old 10-31-2013 Thread Starter
rbyham's Avatar
Cleaning brushes?
Anyone have a good secret/tip for keeping brushes clean while working on an interior painting /staining project and the water is far from the boat in wetslip?
rbyham is offline
post #2 of 6 Old 10-31-2013
pdqaltair's Avatar
Re: Cleaning brushes?
What does water have to do with it? Aren't these solvent based products?
Although there are many cleaning strategies, generally brushes can be kept in a sealed container with solvent for very short periods while working.
If you are using latex paints, the same is true; the brushes will keep for short periods in a container with water.
Squeeze the excesses solvent or water out and get back to painting. A bristle or small wire brush can be very good for combing out any gummy paint.
The real "secret tip" is to have either a plastic cafeteria tray or litter pan to contain the paint cans and messy brushes.
oysterman23 likes this.
Writing full-time since 2014
"Keeping a Cruising Boat for Peanuts"
"Faster Cruising for the Coastal Sailor"
"Singlehanded Sailing for the Coastal Sailor"
pdqaltair is offline
post #3 of 6 Old 10-31-2013
Noah's Bosun
Cap-Couillon's Avatar
Water or Oil based finish?
Water base: 3 gal water in a 5 gal bucket. Paint brushes really shouldn't be loaded more than 3/4 of the way up the bristles. Metal ferule should not be covered in paint. For a good finish on larger jobs, clean your brush every 30-45 minutes. Stick in in the water and "comb" the bristles with a wire brush. until it looks fairly clean. A bronze grill-cleaner wire brush works well, won't rust, and is cheap. Reason to clean so often is build up in upper portions of bristle will start to thicken and dry, reducing ability to evenly load the brush and possibly shedding into your wet edge. If you are not going to use the brush for over a 30 minute period, comb it out in the water bucket, tap it "dry" on the edge of the bucket then wrap tightly in a recycled plastic bag from the supermarket. You can leave a brush like this for a couple of days, but its not good for it. I have "good" brushes ($30-$50) that I have been using for close to a decade with proper care. If you have never used a good brush vs a "big-box" $10 special... Try it. You will be amazed at how much easier it makes the job. You will never go back, as long as you look after your investment.
Oil base finishes is about the same, but use the proper solvent to clean the brush. In either case, when you think the brush is clean, comb it out one more time, then a quick wash with some mild detergent, comb and let dry. Proper cleaning will probably take 10 minutes total plus the walk up the hill to the spigot. You will thank yourself tomorrow.
For staining, I usually use cotton painters rags or muslin for application and wipe off. No cleaning required. Stain rag can be left in the bucket or hung out to dry. Do not store solvent based stain rags that are not dry or in the stain can. Spontaneous combustion is real.
The plastic bag trick can be used for rollers as well on roll and tip jobs. No need to remove roller from frame, just make sure bag is wrapped tight around the handle. Quick and dirty latex jobs good for up to 48 hours with double bag. High end work, stash it in a single bag while you do lunch.
Hope this helps.
Cap' Couillon
"If the wind will not serve, lay to the oars"
Cap-Couillon is online now
post #4 of 6 Old 10-31-2013 Thread Starter
rbyham's Avatar
Thanks folks. Good thoughts. Yes I have latex and oil based cleaning challenges. Had a less than perfect latex paint outcome today as a result of using poorly cleaned brush. Oh well will sand smooth tomorrow and do right.
rbyham is offline
post #5 of 6 Old 10-31-2013
Omatako's Avatar
Cling wrap will keep the brush soft and pliable with most products as long as they are not chemically activated (two-part). With water based products and varnish I have kept brushes and rollers alive for literally months when properly wrapped in cling wrap (all air removed).
Also as long as the brush/roller is not a really expensive one, I've discovered that it is often more expensive to clean than it is to replace.
Arthur C. Clarke
Omatako is offline
post #6 of 6 Old 11-01-2013
Tundra Down
downeast450's Avatar
Foam brushes. Toss em.
Down
Islander-28, Marshall Sandpiper
downeast450 is offline
Varnish brushes Minnewaska Gear & Maintenance 41 04-24-2013 01:23 PM
After brushes with death, sailboat owner takes West Linn grounding in stride - Oregon NewsReader News Feeds 0 08-18-2011 06:10 AM
Dry Cleaning trantor12020 Gear & Maintenance 3 01-30-2009 11:39 AM
Cleaning badger hair brushes JimOppy Gear & Maintenance 9 02-25-2006 08:24 PM
Chip Brushes pirateofcapeann Gear & Maintenance 1 08-26-2003 06:04 PM
