outboard well in a 26 footer - - SailNet Community
 1Likes
post #1 of 27 Old 11-04-2013 Thread Starter
dylanwinter1's Avatar
I am working up a plan to cut an engine well in a 26 foot twin keeler.
I understand that such wells in biggish boats are far from uncommon in NZ and Aus. Noelex for instance
At the moment the well is planned for the back end of the cockpit under the rudder and the water line will be just over eight inches below the false transom(top of the plate where the outboard clamps go)
I would love some first hand experience of cruisers who have who have experience of wells in largish boats.
Is eight inches enough (fnaa fnaa)
I am planning on using a 10hp - because that is the biggest engine one man can lift and they are cheap on ebay.
the design will put the outboard prop exactly where the old inboard prop was.
The reason I am doing this is that my family have decided that they want to join me for the bit of my slow UK circumnavigation that takes me over the the top to Orkney (maybe Shetland) and round Cape wrath. The current 22 footer is a bit of a squeeze for four adults.
Scotland is absolutely rank with badly marked lobster pots so a prop you can lift out of the water to clear the fisherman;s floating gubbins would be most useful
I will be buying an old Centaur with a seized engine - they go for around 2,000 with a seized inboard and 8,000 for one with a working inboard.
They built 2,500 of them so there are quite a few moldering at the back of boatyards with broken engines. A good one with a seized MD11 in it changed hands last week for 800. The boats were built in the 70,s so the engines are dropping like flies
All the details and images of wells, old boats, outboards and Centaurs are on my website but....
to save you looking
this is a Centaur
this is the underside
this is the back of the cockpit
this is the sort of installation I am planning
this is a Centaur at full chat
and this is what my fellow brits think of the idea of cutting a hole in a British Icon - however, I think that for some of the objectors their grasp of basic physics is based primarily on Popeye cartoons
and one bloke who does a lot of cartoons came up with this
Dylan
fred1diver likes this.
dylanwinter1 is offline
post #2 of 27 Old 11-04-2013
JimsCAL's Avatar
Re: outboard well in a 26 footer -
An outboard well like that was common on boats of that size in the 1960s. The Pearson Ariel comes to mind. Available with either outboard or inboard Atomic 4. A Google search will turn of lots of info on it. One disadvantage is that you can't kick up the outboard like you can with on mounted on the stern and growth is an issue. I would be concerned about cockpit flooding on a DIY installation like you are proposing.
JimsCAL is offline
post #3 of 27 Old 11-04-2013
fryewe's Avatar
Dylan -
I am not one who is experienced with such arrangements.
However I will add my "tuppence"…
Will you pull the motor out of the well and close the well with a watertight door when you are in a bit of a sea? Or will you simply close a watertight door over the motor when not in use?
If not:
When the cockpit well fills with water from a wave hitting you from abaft the beam (as it surely will in the waters you want to use it) the motor will be submerged as the well will drain slower than the sea can fill it.
When the boat is surging in a sea the surging action will cause water to pump up thru the motor well into the cockpit well. Will it cover the motor or flood it?
Your idea may work but it seems to me better suited for more sheltered waters than rounding the top of Britain and visiting the Shetlands.
You know that a good inboard installation will cost you six thousand pounds. What will the modifications you envision and the outboard and its fuel system cost? Will your arrangement include the need for exhaust blower and vent system for the boat because of fuel storage below decks or will you need to build a suitable storage area topsides for a portable fuel tank? Once you cost out the outboard motor and support systems/boat mods and compare the cost to renovation or replacement of the inboard is the cost difference worth the hassle/reduced reliability/peace of mind?
Good luck.
The web makes everywhere the same place. - Fred Reed, from "Fred on Everything"
fryewe is offline
post #4 of 27 Old 11-04-2013
Sea Sprite 23 #110 (20)
mad_machine's Avatar
agreed.. a well does make it hard to "pop up" an outboard.. why not just hang it off the stern on an adjustable mount?
Also, while there is a huge price difference in working engined centaurs and non.. can you repower it yourself? when you go to sell, you can make most if not all of it back
Art Haberland
In the end all that matters is how fully you loved, how gently you lived, and how gracefully you let go of things that did not belong to you -Buddha
mad_machine is offline
post #5 of 27 Old 11-04-2013 Thread Starter
thanks for that
lots to add to my collection of engine wellshots
I have lived for the past 18 months with an outboard in a well
the advantages outweigh the turbulance
I have done trials and the outboard costs me between half and a quarter of a knot
on a 22 footer - so I can live with that
I am worried that 8 inches is not enough
hence the post
although I am told that the water never comes back up centaur cockpit drains - so I am taking that as good news
I have two fallback positions
the first is to fit doors that are snug around the outboard - seen some very neat ones on yourtube
the next option is to go for an ultra long shaft outboard
and have a higher well transom
that will mean re-laminating the tiller
not the end of the world of course
D
post #6 of 27 Old 11-04-2013 Thread Starter
Originally Posted by fryewe View Post
Dylan -
If not:
Good luck.
thanks for your thoughts -
I have a well at the back of my Hunter - it is a canoe stern so is very close to the back of the boat
the water has never threatened to engulf the boat nor rise in the well
I am assuming that a well closer to the centre of the boat will get even less movement in water line
I am not entirely sure that the physics of waves means that it will pump up through a hole in the way you describe
after all the only time water comes up a centre plate case is when the boat starts to plane
As for the economics
I have looked long and hard
the job will cost me two days plus a sheet of ply plus the free epoxy from West Systems
I have built several boats so I am very happy with that side of the job
I spent the previous five years (pior to Katie L) propping up an old diesel engine - no spares, no mechanics, diesel bug, no replacement engine mounts, no friggin cutlass gland
I have also twice got caught up in fishermans debris and lobster pots so for Scotland I am now going back to an inboard - far too dangerous with the sort of sailing I do
I have never seen such apalling pot markers
they all have GPS - they never stray into each other territory so they never use flags - just blooming 1 litre milk bottles and some strong floating string.
you would be amazed at how little there is to look at on a boat if you take the engine, electrics, fuel system and most of the plumbing out of the equation . As long as the hull does not leak, the rudder steers and the mast stays up everything else is non mission critical
post #7 of 27 Old 11-04-2013 Thread Starter
I have played the outboard on the stern game on three boats now
we get these nasty short chops around our coasts and outboards on sterns spend some time stirring air just when you need it
if you look at the cockpit on the images it is a long walk from the tiller to the stern of the boat
so that means possibly remote controls and maybe electric start.
you also need one heck of a good sized mount to take a big outboard
one chap I spoke to said that the outb oard was fine for pushing his 27 foot sabre along - but he had to make a bracket tough enough to take it. he also had to cut a notch out of the stern to get to the controls.
as for resale value - if I buy a decent boat for 8 to 10,000 I would have to borrow the money as I am keeping Katie L for the Irish Sea and the Scottish West Coast' She is ideal for single handing
I could sell a good Centaur at the end butt it is going to get two winters and a summer of hard sailing - so it will depreciate - I could lose 2,000 on the value of the boat fairly easily
- this summer is a one off - after this my wife and kids will not want to sail with me
- my dad always told me not to borrow money for sailing
finally - to be able to film and appreciate scotland will mean staying in scottish harbours
they have unbelievably rough walls
again not somewhere I want to park my nice boat
I will not be that bothered about a few extra scratches on a 1500 centaur - it would break my heart to do the same to Katie L
so it is a well or nowt
with the well option I have much less skin in the game - 2,500 - as opposed to 8,000
the great unknown is whether eight inches is enough
any snaps or URLs of wells will be gratefully received and minutely scrutinised
post #8 of 27 Old 11-04-2013
I have a sea Sprite 23. This boat came in 4 engine configurations. The very rare inboard (never seen one) no engine, and two engine wells. One was Port side and one was centred.
Mine is the no engine configuration, so I cannot show you any pics that will help..
Here is a centred:
This site, the blog for "froonie" might also help:
FROONIE: Engine Well Access Hatch
Art Haberland
post #9 of 27 Old 11-04-2013 Thread Starter
Here is a centred:
very good indeed - perfecto
more snaps for my burgeoning collection of outboard wells
first of all that well is so close to the waterline
feeling better about my eight to nine inches already
I assume that the water does not come surging in from a following sea
or does it?
does anyone use blanking plates?
behind the rudder is good in that you can tip the thing out of the way.
and finally - a sprite 23 - what a little cracker of a yacht
I bet they sail like a dream
well done dude
-man I love the web
post #10 of 27 Old 11-04-2013
Dylan, We had a Coronado 25 on San Francisco Bay and outside ocean waters for 10 years, lots of rough conditions. The link shows the well configuration, but with some modifications, which ours did not have. The well worked fine, with a 20" shaft there was no problem with the prop coming out of the water. We had a 15 HP Evinrude 2 stroke which we could tip up out of the water. Not quite sure what your 8" figure relates to?
Not being able to tip the motor up would be not much better than an inboard prop/shaft setup?
Sounds like you have pretty much made up your mind on the outboard, so I will spare you the lecture on why I think an inboard is better, having owned both. Best of luck on a complex conversion.
http://knbpromotions.com/sailing/coronado16.php
CORONADO 25 sailboat specifications and details on sailboatdata.com
Paul T
dabnis is offline
Which 27 footer to buy. gjbrnhll Boat Review and Purchase Forum 37 11-04-2013 01:56 PM
Help ID'ing 19(?) Footer nuffoftexas General Discussion (sailing related) 14 10-09-2009 02:01 PM
I bought a 30 footer for 500.00..... john232 Gear & Maintenance 14 11-03-2003 12:27 AM
Friend is looking to buy 30 footer exogordoso Boat Review and Purchase Forum 1 06-15-2002 06:03 PM
Help identify this 23 footer dewok007 General Discussion (sailing related) 1 05-14-2001 05:30 PM
