Caternary & Chain... - Page 9 - SailNet Community
 17Likes
post #81 of 84 Old 11-13-2013
pdqaltair's Avatar
Re: Caternary & Chain...
Originally Posted by Don0190 View Post
Mine has both a chain and a rope gypsy and the rope would run in the chain section. But it never liked to turn into the hole and drop and this always seemed right about when the anchor would come off the bottom. So it just just to the point that it was better to just have chain.
Same reasoning, same solution.
(when asked how he reached the starting holds on a difficult rock climbing problem that clearly favored taller climbers - he was perhaps 5'5")
"Well, I just climb up to them."
by Joe Brown, English rock climber
pdqaltair is offline
post #82 of 84 Old 11-13-2013
Originally Posted by mitiempo View Post
A riding sail set on the backstay is effective to eliminate sailing at anchor. Need not be very large.
Not completely. I have one on my previous boat just diminish the movement but I am not sure that is detrimental to safety, I mean the movement. If you go forward and look to the chain you can see that in fact the "sailing" diminishes the pressure over the chain and therefore the pulling force on the anchor.
post #83 of 84 Old 11-14-2013
Learning the HARD way...
eherlihy's Avatar
Just read your post as well as the rest of the thread. As far as retrieval goes I think a stainless or galvanized welded ring around the anchor rode makes for the easiest way to pull an anchor up when it will not break free. This is used on the halibut anchoring rigs that we make for fisherman. The ring can stay on the boat with the rode going through it, if large enough it can live around the anchor roller and out of the way. A light line of 1/4" size is attached to the ring. If the anchor gets stuck the ring is allowed to travel down the rode to the anchor and a pull from the opposite direction will unseat the anchor easily.
The Rocna 15 (33 lbs) is my choice for a 27' boat, currently with 80' of 5/16" g30 chain because that is what I have followed by nylon. Were I to replace the chain it would be to 1/4" G43 of 40' or 50' and nylon after that. My rig, like yours is geared for using without a windlass.
If my boat was the size of yours I would certainly have a windlass, manual or electric. I would choose a Rocna 20 (44 lbs) or a Rocna 25 (55 lbs) for a 35' boat.
When I bought the boat it came with a 25lb Delta.
That anchor was a bad joke on the bow of a 35' boat...
eherlihy is offline
post #84 of 84 Old 11-14-2013
Agree that a riding sail doesn't eliminate 'sailing' on the hook, but it can lessen the arc, and more importantly soften the 'turnarounds'.
Our Caribbean cruising friends started using a riding sail that we gave them.. and it's still the first thing that goes up after the hook goes down. Their Bene 36.7 sailed so hard on the hook that the 'fetchup' on one end of the swing actually broke the anchor free in one instance. The boat would spring back after stretching the rode (all chain), then turn and almost sail downwind before being snatched back around.
The riding sail makes those 'fetchups' much more gentle, the bow doesn't blow as far off and they sleep better for it.
Faster is online now
Chain to chain connectors on anchor chain kwaltersmi Gear & Maintenance 12 10-16-2013 10:24 AM
Is he pulling my chain? rbrasi General Discussion (sailing related) 12 09-19-2012 12:52 PM
anchor chain, G70? sapo Gear & Maintenance 0 06-24-2011 12:34 PM
Chain Stopper or Chain Tensioner? 1970Columbia34 Gear & Maintenance 14 03-19-2007 12:43 PM
Chain FritzN Boat Review and Purchase Forum 3 01-07-2007 09:33 PM
