Rallies Gone Wrong - Page 60 - SailNet Community
Advertise Here
Like Tree352Likes
Old 01-03-2014
svShearwater's Avatar
svShearwater is on a distinguished road
Re: Rallies Gone Wrong
Originally Posted by outbound View Post
S/v shearwater I'm curious about " carry two autopilots". I was under impression once electronics adequately " proofed" carrying another complete drive set up and a rudder angle sensor sufficed. ?do you think this is wrong?
Smack sorry for the hijack.
Certainly step 1 would be to have a second drive unit. That is actually not uncommon for short-handed ocean racers. Step 2 would be just extra insurance carrying a second autopilot computer. Having two completely independent* autopilots that way.
Electronics (autopilot computer) shouldn't fail, but they do. Sometimes it is design or manufacturing defects, sometimes you/we do something stupid like get it wet, connect the wiring wrong and pop something, or drop something on it. None of those are likely, but just in case, other than cost there is no downside to a second autopilot.
*independent except they both need electricity and a working rudder.
There is no perfect solution, just a variety of compromises. My point is that for boats where wind vanes don't make sense. Having a backup autopilot is a reasonable thing to consider and will likely cost less than a new wind vane.
  #592
Old 01-03-2014
Dude, hijack away. It's just a thread.
I'm hoping to meet these guys before they head out for the PacCup.
You going sailing tomorrow? Forecast looks promising. First Icicle race of the year!
  #593
Old 01-03-2014
outbound is on a distinguished road
Thanks - good advice. Have the raymarine with the big arm. Wish. I got the nke. Would you suggest mix or two of the same?
Have had a monitor and a Fleming on prior boats. Actually liked the Fleming better. But agree if the boat's hull speed is >8kts vanes don't work as well as A.P.s especially down wind in seas. Amazing how in the last couple of years A.P. performance has improved.what size nke do you have?
Find in difficult situations going apparent wind rather then course sometimes makes it work less.
s/v Hippocampus
Outbound 46
  #594
Old 01-03-2014
smackdaddy's Avatar
Last Man Standing
smackdaddy is a jewel in the rough smackdaddy is a jewel in the rough smackdaddy is a jewel in the rough
We're looking at coming down the next weekend (just got back from vaca and need to give the boys some down time this weekend). I'll let you know.
Are you guys still staying in Austin?
  #595
Old 01-03-2014
Our L&S drive is a type 40 for about 15k pounds and a semi-balanced rudder. The pilots top speed is about 12 knots so far. I haven't tried to push beyond that yet, because I find steering fun at those speeds.
I'm not sure there is a single answer for carrying two same or different pilots. On the one hand you could argue that carrying same makes it all very plug and play. However, if you fully install both pilots beforehand it may not make much difference. There is the argument that if one pilot has some sort of defect then switching to a completely different system/brand would be a good thing.
Mostly it is just a budget question. If your budget can swing 2 NKE autopilots, then that is a pretty strong setup. If you have a Raymarine and can swing an NKE now, then again a pretty strong setup with the added complication of two different systems. Certainly two identical Raymarine systems is the easiest and least expensive option. Not a bad option either.
For me, I will go with first adding a second L&S (NKE) drive unit, then a second NKE computer and gyro compass because I want everything to be plug & play and work on the same system (NKE instruments) easily. I think that is more a matter of preference than anything else.
  #596
Old 01-04-2014
Thanks.fair winds to you and yours
s/v Hippocampus
Outbound 46
  #597
Old 01-16-2014
JonEisberg will become famous soon enough
Uh-oh... If only they'd performed an ISAF inspection beforehand... :-)
NARC rally organizer Hank Schmitt, and SAIL magazine editor Charlie Doane were among the crew of 4 who abandoned a $500K 42' catamaran 300 miles east of Norfolk on Tuesday...
City man airlifted off disabled sailboat | SeacoastOnline.com
  #598
Old 01-16-2014
smackdaddy's Avatar
Last Man Standing
What makes you think they didn't?
  #599
Old 01-16-2014
smackdaddy's Avatar
Last Man Standing
I think this incident might point more to some design evaluation than anything else...
The first thing you’ll notice about the Alpha 42’s sleek lines is the reverse angle, wave piercing bows – the first on a production cruising cat. “Reverse bows basically extend the waterline without adding weight and they reduce pitch,” said Tarjan. “Other benefits are a much more comfortable motion at sea and reduced windage. Wave-piercers are also easier to steer and maneuver in waves. I collaborated with Pete Melvin of Morrelli & Melvin for the reverse bows on the 110-foot catamaran that I’m building in collaboration with Wally Yachts [the Aeroyacht 110]. The Alpha 42 is the ‘baby version’ of the 110-footer, and we’ve moved the mast further aft to keep the bows buoyant.”
...and/or the timing and passage choice for such a new boat. As someone said over at SA - having Hull #1 (if that's what it was) abandoned due to something like this is not great marketing.
Here's a link to photos of the build.
  #600
Old 01-16-2014
We'll never know but sounds like boat was thrown backward with rudders turned or even hard over. Sounds like bent rudder posts. No amount of inspection or other pre voyage activity would change that. Carrying an emergency rudder system might have been of benefit but if bent hard over even an emergency set up would not allow meaningful steerage.
?are there any more details known?
s/v Hippocampus
Outbound 46
You may post attachments
You may edit your posts
Sailing fraternity rallies for gutted Carrickfergus club NewsReader News Feeds 0 06-25-2012 09:20 AM
Smooth sailing for Fish, Sharapova rallies NewsReader News Feeds 0 08-30-2011 10:10 PM
Smooth sailing for Fish, Sharapova rallies NewsReader News Feeds 0 08-30-2011 10:10 AM
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
SEO by vBSEO 3.6.1
