Installing Outboard - SailNet Community
 2Likes
post #1 of 13 Old 11-14-2013 Thread Starter
Installing Outboard
Hello All!
After months and months and months of research, searching, looking, poking and prodding...I have finally found the boat I'm going to purchase. It's a 1978 Newport MKII. There's good points and bad points to the boat, but all in all, it's in good shape. (Volvo MD7A low compression issues, which I'll be posting about soon). In the meantime, I've got to buy and install an outboard. Bear with me, I am a total newbie here and I just have some general questions. I know I can pop down to West Marine and probably have them answered, but you guys are all here and fairly friendly.
With an outboard bracket...is there any type of mount I can use temporarily without drilling into the transom?
If no and I have to drill holes, can this be done at the dock with a drill and the proper caulk, parts, etc?
The inboard MD7A runs, but rough and I must get the boat from San Francisco up to Suisun. I have a friend who will let me borrow his outboard, but I'll need to purchase a bracket. Or the other option is to find an outboard on craigslist, which I've seen several already....Any input would be great!
rob_d is offline
post #2 of 13 Old 11-15-2013
CaptainForce's Avatar
Re: Installing Outboard
I think this is an acceptable idea for the protected waters inside the bay and there should be no problem with the installation of the bracket while the boat is in the water. Just be careful with your stability and the electrical cords an connections over the water. I like to tie the cord in a way that it can not reach the water.
Take Care and Joy, Aythya Crew
CaptainForce is offline
post #3 of 13 Old 11-15-2013
Remember you're a womble
PaulinVictoria's Avatar
Is there not a mechanic near where the boat is now that could at least look at the inboard and try to get it running smoother before you go drilling holes in your new boat?
Orange Crush
1974 C&C27 MkII
PaulinVictoria is offline
post #4 of 13 Old 11-15-2013
overbored's Avatar
if the inboard runs and will power the boat to get it docked then sail it there
"GOLD RUSH" PRINDLE 16
overbored is online now
post #5 of 13 Old 11-15-2013
Just low compression! Give it a Seafoam treatment in the oil and fuel. You maybe pleasantly surprised.
christian.hess likes this.
sony2000 is offline
post #6 of 13 Old 11-15-2013
christian.hess's Avatar
yup! a thourogh cleaning of the fuel system, a couple of flushes wuth marvel mystery oil and seafoam in the fuel for a full tank will do wonders in the meantime...
christian.hess is offline
post #7 of 13 Old 11-15-2013
san fran to suisun is a nice sail any day...not too much wind now...just time it on the flood and youll be golden
post #8 of 13 Old 11-15-2013
azguy's Avatar
Originally Posted by christian.hess View Post
.......a couple of flushes wuth marvel mystery oil and seafoam in the fuel for a full tank will do wonders in the meantime...
I agree, do this and motor sail to your destination, it maybe running fine by the time you get there.....
1988 C22 Owner
azguy is offline
post #9 of 13 Old 11-15-2013
Owned by Velcro
Ferretchaser's Avatar
I would go with the sea foam and oil treatment as well before putting holes in the boat.
"Political correctness is a doctrine, fostered by a delusional, illogical minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end."
Light travels faster than sound. That is why some people appear bright until you hear them speak!.
Ferretchaser is offline
post #10 of 13 Old 11-15-2013
Perhaps you could get your friend to tow you. If you get the tides right with no nasty weather it should be OK.
Paul T
dabnis is offline
Tags
bracket , outboard
Installing an outboard Lappy Laz Gear & Maintenance 7 06-25-2013 07:31 PM
Installing an ammeter rikhall Electrical Systems 28 09-24-2010 08:42 AM
Installing a Cleat... Need Help BlueWaterMD Gear & Maintenance 11 08-09-2010 04:27 AM
Installing a topsail ChefRobert Gear & Maintenance 0 02-25-2006 02:43 PM
