General HULL TYPES - Pros/Cons? - SailNet Community
Blogs
Old 10-08-2004
oceanmaui is on a distinguished road
Curiously browsing the markets, just trying to get some basic knowledge.
(thinking mostly of coastal and cross-ocean cruising)
Does anyone have opinions/facts on the pros/cons of the different hull types?
Wood?
Fiberglass?
Steel?
Aluminum?
Composite?
Ferro-Cement?
Others?
Any input would be helpful.
Thanks
:O)
-D-
Old 10-09-2004
capttb is on a distinguished road
Wood? Great "feel", too labor intensive
Fiberglass? Most suitable for recreational use due to cost and repairability.
Steel? Generally hard chine designs, may be great or bad.
Aluminum? Hard skill level required to do it right
Composite? You mean cored hulls ? opinion divided due to repair difficulty if water infiltrates foam (or Balsa) core material.
Ferro-Cement? Run away, low cost method popular in the 70''s for homebuilt hulls, what happens when you soak cement and re-bar in saltwater for 30 years?
Others?
Old 10-09-2004
Jeff_H's Avatar
Super Moderator
I think that you mean hull materials and not hull type. Each of these posible boat building materials has its advantages and disadvantages and each has purposes and boat types for which they make a logical choice and a totally illogical choice. Most of these materials can be used in a range of construction systems that can produce a range of results; some good, some terrible depending on the projected use. To answer your question comprehensively you could fill a book or two.
So I guess I would like to find out more about your goals such as how big a boat you have in mind? Are you talking about building a boat or buying one? How would you see yourself really using this boat? And perhaps we can provide a more specific answer to suit your goals.
Respectfully,
Old 10-11-2004
Er...yes, hull materials. Thanks. :O)
The dream, of course, is to buy a boat (possibly between 35'' and 55'') and live upon it (till the end of days? hehe), sailing the coastal waters of every continent.
We''ve just started looking into this dream, and are in the process of gathering as much information as possible.
I''ve seen references to different hull materials, but not much specific info on their strengths and weaknesses.
Just curious as to peoples opinions, wether from hearsay or personal preference.
PS. Thanks CAPTTB for the info as well. :O)
-D-
Old 10-11-2004
paulk's Avatar
paulk is on a distinguished road
The best resources for you may be at the library under the authors Dashew, Pardey, Moitissier, Knox-Johnson, Abei, etc. Each of them has insights that may be helpful in developing your own reasoned opinion. Each of them has taken the trouble to actualy do some heavy-duty sailing as well, before considering and writing up their stories. Their opinions may be worth more than people''s who jus happen to come across your query on the web.
Old 10-11-2004
ct ct is offline
ct is on a distinguished road
Frankly I went with aluminum. I believe it''s the best choice for hulls.
Wood
Wood is rapidly disappearing as the number of highly skilled carpenters willing to work for relatively low wages declines, but modern incarnations such as West system cold-molded construction still have advantages where low weight and moderate cost are considered more important than ability to sail safely in the rougher parts of the World''s oceans, and take the knocks on coral, ice or granite that are inevitable in extensive cruising.
Fiberglass
Fiberglass boats make extensive use of balsa wood or foam sandwiched between two layers of glass reinforced plastic. The structural engineer and the racing sailor, like the superior strength and stiffness to weight ratio attainable with this sandwich construction. However, if not very carefully built and maintained, the boat will have a short life, or require considerable maintenance, since water will find its way in between the laminations.
Poor workmanship when adding or replacing deck equipment after launching is a major cause of failures. It can be very expensive to do a good job or installing a new winch on the coachroof, or a sail track on the deck, if the necessary structural reinforcements were not foreseen when the glass was laid up.
If you want good fiberglass, then stick with a hull produced in reasonable quantities, so that the builder can minimize his mold costs, leaving enough money for good quality labor. Epoxy resins and vinyl-ester are normally best, and are used in the better hulls. As usual, the best is expensive. If you want the boat to last through extensive cruising, insist on foam in preference over balsa wood.
Ferro-cement
The negatives of ferro are high weight, and relatively low reserve strength in event of collision. It is not feasible to take advantage of modern hydrodynamics in ferro-cement, so performance suffers relative to the better modern cruising designs. Resale value is low, although this is attractive if you are a buyer.
The status value is ferro is rock bottom, and ferro is rarely seen around the exotic marinas.
Ferro must be insulated, and this can be accomplished easily with blown polyurethane foam. Exterior paint often falls off, but this can be avoided by using the right paints and painting the inside as well as the outside. This latter point cannot be overemphasized.
Ferro is most attractive to the amateur, and most ferro boats are amateur built. If buying one, the only effective quality control is to know the building technique well, or to buy a boat that has crossed oceans, and has NOT been recently painted.
Aluminum
The strength to weight ratio of aluminum is excellent, particularly when considering the ability to withstand accidental impact loads. Aluminum yachts are more resistant to grounding, collision and similar abuse than plastic, they are immune from osmotic blistering, they can be left unpainted if desired, and are extremely resistant to corrosion.
The old bugaboos of electrolytic corrosion are easily controlled with to-day''s know-how.
The correct grade of marine alloy is essential, with 5086 and 5083 being preferred by most experienced builders for the wetted parts. This alloy is not quite so strong as the 6000 series alloys normally used for masts, but is much more corrosion resistant.
Welding skills play a part in making the most of aluminum. Rigorous attention to preparation and the welding alloy used is essential, and it is easier to maintain quality in a shop that builds only aluminum structures for marine use than in a shop that also works with steel and other alloys.
A highly skilled yard can build aluminum hulls so fair that they can be left unpainted, except for antifouling. Apart from the aesthetics, this has the advantage of guaranteeing welds free of pin-holes which can lead to corrosion problems. If painted, a good aluminum hull will not require any filler, and the paint will last much longer than on a steel or wooden hull.
Since the metal is inherently resistant to sea water, the inside can be sprayed with two to four inches polyurethane foam; keeping the crew cool in the tropics, while keeping warm and eliminating condensation in cold waters.
Aluminum hulls are much stiffer than fiberglass or wood, so leaks at any bolted on fittings are much less likely than with fiberglass. The interior carpentry can be made to fit well without any problems from doors jamming or opening unexpectedly in a seaway.
Steel
The greatest advantage of steel is that it is very strong. However, as discussed by Michael Kasten, aluminum yachts are normaly somewhat more robust than steel ones in practice. Particularly in the first half dozen years of their life, steel yachts often have considerable reserves of strength because they are normally designed with a margin on the thickness of the metal to allow for expected corrosion.Cost will be similar to aluminum, for equal quality.
If well designed, with fabrication details well thought out to minimize corrosion, and if the paint is applied perfectly, corrosion is not uncontrollable in steel, although maintenance costs will normally exceed those for aluminum.
Virtually any hull form can be built without any compromise in strength. However, I have not yet seen any steel yachts that are so fair that they look good with paint only on the hull. Filling is required, and this is liable to have to be sandblasted off and redone every five to ten years.
Insulation is a problem. If uninsulated, a steel boat will run with condensation in the cold water, and cook the occupants in the tropics. If insulated, there will always be the worry of corrosion under the insulation.
Take your choice but all in all, I voted for aluminum.
Old 10-13-2004
Wow! That''s exactly the kind of info i was looking for.
Thank you, and everyone else who replied!
:O)
-D-
Glassing hull GreenEarth General Discussion (sailing related) 18 06-20-2009 12:52 AM
High Tech vs traditional-Comments? Pangaea General Discussion (sailing related) 38 08-07-2007 02:07 AM
Thru Hull Replacement Stormer_2003 Gear & Maintenance 1 09-13-2004 12:22 PM
Thru Hull Replacement Stormer Gear & Maintenance 4 08-03-2004 09:21 AM
hull construction cgha33 Boat Review and Purchase Forum 4 05-23-2003 08:11 PM
SEO by vBSEO 3.6.0
(c) Sailnet 2000-2006
