Filling Holes - SailNet Community
post #1 of 15 Old 11-19-2013 Thread Starter
azguy's Avatar
Filling Holes
I want to replace some cam cleats and one rope clutch on my boat, assuming the same holes can't be used what's the best way to fill the old holes and not have any leaks or issues....
Also, any reason I can use a cam cleat behind a winch instead of the traditional dock style cleat
Thanks
1988 C22 Owner
azguy is offline
post #2 of 15 Old 11-19-2013
Asleep at the wheel
jimgo's Avatar
Re: Filling Holes
The horn cleats spread the load over a larger footprint, which can be advantageous, and horn cleats don't really care about the line's angle. Also, cam cleats sometimes have issues if they aren't designed for the size line that you're using. Otherwise, yes they can be behind the winch. Personally, though, I'd look at a clutch in front of the winch, depending on which winch/line we're talking about. If it's for a few lines that won't be tweaked too often (e.g., halyards, outhaul, etc.), you can use a single winch to adjust multiple lines if a multi-line clutch is sitting in front of the winch.
To fill the old holes, I'd check to make sure you don't have water intrusion into them. If you do, try to dry them out as much as possible (there are threads here on that). Dig out as much of the rotten core as possible, too. Assuming the old holes/components were through bolted, put some tape across the bottom of the hole to form a temporary "floor". Then inject expoxy resin into the hole, filling it as much as possible. That resin is thinner than it will be once activated, so it will tend to seep into the core around the hole. Suck the excess resin out of the hole and add activator, then inject it again (add silica thickener if the holes are big). Then sit back and wait for it to cure.
- Jim
Home: Western Philly 'burbs
1980 Allmand 31
1975 Albacore 15
jimgo is offline
post #3 of 15 Old 11-19-2013
chucklesR's Avatar
Re: Filling Holes
Take a slightly (1/32) over sized drill bit and slightly bevel the top edge - this relieves the stresses and helps prevent later crazing in the gel coat.
Tape the underside, fill with epoxy to almost the top, allow to cure.
The tape is so it doesn't just pour through. If you can't get to the bottom, no sweat, it won't pour through. You can also use thicken epoxy. It's not structural, and won't be visible so wood saw dust works as a filler.
Once cured use either gel coat (with color match) or Marinetex - put a touch on a regular old fashioned razor blade and use the blade like a putty knife to fill the hole completely.
The smooth edge of the razor will make a smooth surface - you might not even have to sand.
chucklesR is offline
post #4 of 15 Old 11-19-2013 Thread Starter
azguy's Avatar
Re: Filling Holes
Ok, I get the idea behind the horn cleat, that makes sense. I was thinking of putting the cam cleats behind the winches used for the jib sheets, It seems it would be easier, single handed, to release the sheet from the cam cleat than to unravel the horn cleat. They can be position straight back of the winch...IDK
I'm sure the hole I was referring to will have no water intrusion. Over the last 9 years the boat was sailed twice a month and kept on a trailer and we get almost zero rain in Arizona followed up by extremely dry weather. I just needed to inquire if the new cam cleat holes do not line up with the old ones how to seal up the old ones, Any reason I could fill the whole hole with Marinetex or some caulking and then Marinetex.
I do want to put a two line rope clutch in front of the winch used for the main and spinnaker halyards since there is some cheapo plastic clutch there...
1988 C22 Owner
azguy is offline
post #5 of 15 Old 11-19-2013
deltaten's Avatar
Send a message via Yahoo to deltaten
Re: Filling Holes
I have used MarineTex with a skosh of universal colorant to match closely. The MT is putty-like enuff to fill un-backed holes pretty well. Strictly cosmetic? Bevel, clean with acetone and fill away!
S/V Chrysalis
'80 Watkins 27
North East, MD
deltaten is offline
The Following User Says Thank You to deltaten For This Useful Post:
Markwesti (11-19-2013)
post #6 of 15 Old 11-19-2013
Asleep at the wheel
jimgo's Avatar
Re: Filling Holes
On the dinghy-sized boats I sailed, we had cam cleats on the sheets. I really liked them, and had a hard time switching to a horn cleat when we got our C25. For some reason, on the Allmand, it really isn't as big of a problem. I can winch in and then cleat pretty quickly. If you do 2-3 figure 8's, you can release quickly while still getting a good "bite" on the line. In the end, it's a personal preference thing.
I can't speak to the sufficiency of filling with Marinetex or caulk. I think an issue might be the differences in expansion/contraction rates (coefficients of expansion).
- Jim
1980 Allmand 31
1975 Albacore 15
jimgo is offline
post #7 of 15 Old 11-19-2013
Delta-T's Avatar
Re: Filling Holes
I installed Jam Cleats just behind the horn cleats and wrap the sheet once around the horn cleat then to the jam cleat.
For fixing the holes...if you can't if it, enhance it. You could use flat head screw with finish washer. Seal with some kind of sealer. You never know, you might want to reuse and add better jam cleat or horn cleat in that original position in the future.
Eric
Delta-T
1968 Bristol 32 Keel/Crb Hull 26
Narragansett Bay RI USA
Delta-T is offline
post #8 of 15 Old 11-19-2013
no longer reading SailNet
Alex W's Avatar
Re: Filling Holes
The line clutch should be forward of the winch, not aft of it. This allows you to use the same winch for both lines on the clutch.
You might want to think about how you'll use the spinnaker when short handed before settling on a halyard location. My spinnaker is in a sock (easier for small crews) and the sock control lines hang down from the masthead. Having the spinnaker halyard in the cockpit means that I need to run back and forth multiple times to deploy the spinnaker single handed. Having it at the mast means I go forward only once.
I've filled with MarineTex, but don't think that it bonds to the core as well as epoxy and it is hard to know if you are filling the hole 100%. Epoxy isn't much more work and is a better solution. Caulk is not a good solution. Getting water into the core is the best way to ruin a nice boat, and once it is in there it won't dry out.
Alex W is offline
post #9 of 15 Old 11-19-2013 Thread Starter
azguy's Avatar
Re: Filling Holes
I said in front...
ad the cheapo plastic clutch I was referring to I just learned is a jam cleat, thanks for teach me one more thing
I hate that little thing will replace with double rope clutch...I'm 99% sure would never try and fly spinnaker by myself, at least for quiet some time as I still pucker up when I roll out the job and pick up speed
1988 C22 Owner
azguy is offline
post #10 of 15 Old 11-19-2013
Alex W's Avatar
Re: Filling Holes
Even with a crew of 2 or 3 I think that the spinnaker halyard belongs at the mast. Without some advanced rigging you aren't going to end up flying a spinnaker without someone going to the foredeck at some point to launch or retrieve. Since someone is already up there you might as well have the halyard there.
Alex W is offline
Filling holes in deck old-sailer C & C 2 10-19-2011 08:54 AM
Filling in holes in the deck dave6330 Gear & Maintenance 28 03-20-2010 04:53 AM
Filling small holes. ceol Gear & Maintenance 10 01-13-2008 10:03 AM
Filling holes in the deck GBurton Gear & Maintenance 9 11-06-2007 01:48 PM
Filling Holes with Epoxy Sue & Larry Gear and Maintenance Articles 0 09-25-2000 09:00 PM
