  #21
Old 11-01-2010
with Robin Lee dreams
coreywoodworking is on a distinguished road
Dumping Wheel for Tiller - Am I nuts?
I have a Caliber 28. A tight t-shaped cockpit with a bridgedeck, wheel and pedestal. I sail alone 90% of the time, but feel out of control behind the wheel. I can sit on the coaming, wheel in hand, between tacks, but it's the tacks and jibes that worry me. I can reach the genoa winches, have to bound up on the seats to go forward or return aft, and still feel out of touch with cabin-mounted halyards/reef lines/mainsheet.
Grew up on Highlanders / 420s / Flying Scots / catboats, here in Boston. Would prefer to trim mainsheet at a traveler just aft of bridgedeck. Would prefer to jibe the mainsail facing the traveler, with the tiller between my legs. I think I'd feel more in control than I do now and, again, I usually sail solo.
Refitting this winter, finally sailing south in the spring or summer. Have all the dimensions, have worked out the drawings, but still questioning my wisdom (about cockpit changes!).
The great replies in this tiller-vs-wheel thread have helped me to consider many additional POVs. For instance, I hadn't considered your observations on motoring -- and my rudder isn't balanced. One answer: I'd carry two tillerpilots, bungees and would reallty like a windvane.
Still, I'd appreciate anything you have to say...
  #22
Old 11-01-2010
Gate Crasher
SoftJazz is on a distinguished road
I'm glad to see this post because next season I'll be on a tiller boat & it looks like I'll have to learn to drive it. I'm a bit nervous because I have very little tiller experience, but I'm always willing to learn something new.
Thanks for the post & the information/feedback.
I want to be so famous that drag queens will dress up like me in parades after I'm dead.
  #23
Old 11-01-2010
Sublime's Avatar
Quirky
Sublime is on a distinguished road
The mechanical advantage you get with the wheel can be a pro or a con. I'm comfortable with either.
I think the most significant advantage a tiller has is the cockpit space. I've banged my elbow into the wheel while working on something and cursed that thing to death. Or a knee. I think I need to look into that quick disconnect thing.
  #24
Old 11-01-2010
puddinlegs is on a distinguished road
It really depends on the displacement, not the LOA, of the boat you're talking about. TP 52's have tillers. Old 40' One tonners have tillers. If you like lighter boats, particularly those with high aspect spade rudders, you're more than likely going to enjoy the responsiveness of a tiller, and the better it will work with the boat. The greater the displacement, the more sense a wheel makes. Why do most boats in the marina have wheels? Many owners don't come from boat owning families or dingy racing backgrounds. A wheel is easy. It's like your car. For many who come to sailing later in life, a tiller will always feel a little odd unless you're really willing to work at your sailing skills. Personally, I like the mechanical simplicity and feel of a tiller. That said, if I had a 43-44' boat that weighed 25,000k lbs or so and was doing a lot of auto pilot cruising/passage making, a wheel would be fine.
Instrument pods on a wheel? Hate'em. No one can see them except the driver. And what do you do when the self-steering or AP is one? It stinks having to run back in the rain, spray, cold, etc... to catch a glimpse of the holy pod. Drives me nuts... that's just me. You're mileage may vary.
  #25
Old 11-01-2010
chrisncate's Avatar
Sup
chrisncate is on a distinguished road
Tiller.
  #26
Old 11-01-2010
DubeJ's Avatar
DubeJ is on a distinguished road
till till death!
  #27
Old 11-02-2010
mitiempo's Avatar
Better feel for what the boat wants/needs with a tiller. I think it comes down to balance rather than displacement though. A wheel will give you better mechanical advantage and less feel. With a tiller you know when you are over canvassed or trimmed incorrectly - the weather helm is a lot more obvious. With the wheel you are more isolated and less in tune with the boat.
Brian
  #28
Old 11-02-2010
PCP PCP is offline
I like tillers and they have many advantages, but one of the disadvantages I found is that on really bad weather you can not "hold" on to a tiller. That is specially a problem in modern boats that have large transoms. When the boat is bouncing around in waves, up and down with some lateral jerks, I find some support on the wheel (and its pedestal), that I can not find in a tiller boat.
Racing boats have solved this with some metal supports for the feet that unfortunately you don't have on cruising boats.
  #29
Old 11-02-2010
... but you could easily enough. It's just a trip to a fabricator, some holes drilled, bits bolted, bedded, and there you go!
  #30
Old 11-02-2010
BenMP's Avatar
BenMP is on a distinguished road
One other consideration is physical size. My wife is on the slight side and really likes the mechanical advantage of a wheel. She has no problem using a tiller but prefers the wheel.
You may post attachments
You may edit your posts
Tiller to wheel conversion costs? 808state Gear & Maintenance 13 06-30-2012 07:11 PM
KISS? or ... why a wheel? jbarros General Discussion (sailing related) 48 12-15-2008 04:17 PM
Aquarius 23 wheel steer back to tiller woodyr Gear & Maintenance 0 06-24-2004 08:13 PM
What Would You Buy For 70 Grand Dav-O Boat Review and Purchase Forum 22 03-26-2002 09:11 PM
retrofit, tiller --> wheel ryba General Discussion (sailing related) 5 10-18-2000 03:14 PM
SEO by vBSEO 3.6.1
