Old 11-03-2004
ddilman is an unknown quantity at this point
2 blade or 3 blade propeller
I need help deciding between a 2 blade or 3 blade propeller
for a Catalina 36 with a wing keel. Planning to do little
or no racing and I''m non experienced in docking.
How practical is the 3 blade when docking? And is it worth
the extra drag when sailing?
Thank You
Danny
Old 11-04-2004
Jeff_H's Avatar
Super Moderator
You probably do not need a three blade on a boat like the Catalina 36. The extrad drag is not worth it.If you do go three blade I would strongly suggest going with a maxprop, especially if you are not racing.
Old 01-31-2006
joepovey is on a distinguished road
Some have suggested a 4-blade for close work.
Cheers!
Old 02-12-2006
ASA and PSIA Instructor
Danny,
The chocie of two versus three blades is determined by the clearance between your shaft and the hull. Your comination of engine HP and boat displacement calls for a certain blade area to properly load the engine. There's no value to a three blade except the extra cost if a two blade of sufficient blade area fits with adequate hull clearance.
I'd discuss your choice with a propeller specialty shop although there must be plenty of Cat 36 owners available.
Why are you buying a prop - doesn't the boat have one? If you are replacing, it's akin to a crime to not buy a folding/feathering prop for a sailboat. A fixed prop is like dragging a small anchor around. We switched to a three blade MaxProp on our CS 36 a number of years ago and it has served us quite well - well worth the etra $$$. Contact http://www.pyiinc.com/ for advice although I notice Sailnet nows carries the maxProp. A plus of a feathering prop like MaxProp is that the blades work almost as effectively in reverse as forward. Our boat will back up almost like a car, minimal prop walk and great acceleration.
These props are expensive, but like most things you get what you pay for.
Good luck.
2 blade or 3 blade propeller ddilman Gear & Maintenance 14 12-29-2004 07:12 PM
2 blade or 3 blade propeller ddilman Boat Review and Purchase Forum 3 11-07-2004 07:27 AM
propeller - 2 or 3 blade ddilman General Discussion (sailing related) 4 10-31-2004 04:52 PM
propeller - 2 or 3 blade ddilman Gear & Maintenance 1 10-31-2004 04:31 AM
propeller - 2 or 3 blade ddilman Boat Review and Purchase Forum 0 10-31-2004 03:46 AM
