How to Replace Cutlass Bearing? - SailNet Community
Blogs
Old 12-05-2004
kcoffey is on a distinguished road
How can I replace the cutlass bearing on my 1985 Najad 343? There is a bronze fitting on the external end of the tube through which the prop shaft passes. No doubt, the cutlass bearing is inside this bronze fitting, but I cannot see any apparent way to remove the fitting or otherwise gain access to the bearing! Also, from where can I get the rpope new bearing part. Thank for your advice!
Old 12-05-2004
WHOOSH is on a distinguished road
K:
Your shaft is probably metric and so your challenge is two-fold: how to remove the old bearing and then sourcing a correct bearing re: both OD and ID measurements.
The Najad folks are relatively small-volume builders and many of them have been with that yard for decades. Their sales & commissioning yard is in the tidy little harbor in Henan, on the island of Orust in Sweden. Were I you, I''d fetch their phone # (www.najad.com) and give them a call to get their recommendation on how to proceed. Even if I were being advised by my local yard, I''d like to hear Najad''s view of the task ahead of me. They may also be able to offer you a current source for a proper new bearing.
Jack
cutlass bearing ruined? grumol Gear & Maintenance 3 07-09-2004 11:07 AM
Mariner 39 Cutlass Bearing ABullard Gear & Maintenance 0 06-26-2003 08:57 AM
Cutlass Bearing parvenu Gear & Maintenance 6 04-15-2003 02:11 PM
Site for cutlass bearing dscottl Gear & Maintenance 0 09-16-2002 02:58 PM
Rudder Bearing Replacement animaashi Gear & Maintenance 1 11-10-2001 11:48 AM
SEO by vBSEO 3.6.0
(c) Sailnet 2000-2006
