Heaving-To - Page 2 - SailNet Community
 19Likes
post #11 of 42 Old 12-06-2013
no longer reading SailNet
Alex W's Avatar
Re: Heaving-To
Originally Posted by capttb View Post
I don't understand how you could heave to with a single sail without fore reaching, it's the balance of jib against rudder and main.
You can also balance the rudder against the main without the jib and heave-to.
Alex W is offline
post #12 of 42 Old 12-06-2013
Courtney the Dancer
jrd22's Avatar
Re: Heaving-To
In our current boat the best combination I've come up with is a fully furled genoa, full staysail and reefed main. This works well in 15-20 knots, haven't tried it in anything stronger. I think if I double reefed the main with the staysail she would hove to in stronger winds, each boat is different. Our boat has a long fin and skeg hung rudder and is a cutter rigged sloop.
John
SV Laurie Anne
1988 Brewer 40 Pilothouse
jrd22 is offline
post #13 of 42 Old 12-06-2013
Barquito
Barquito's Avatar
Re: Heaving-To
OK. I am motivated. I need to heave-to more! I am going to make a list in my log book. It will start with 5 kt, and go up to 35 kt by 5 kt increments. I am going to try to heave-to in as many conditions as possible next season, making note of what configuration worked.
Valiant 32
Barquito is offline
post #14 of 42 Old 12-06-2013
Alex W's Avatar
Re: Heaving-To
It is one of the first things that I like to play with on an unknown boat. It is useful to know and is helping me get a better understanding of how to heave-to as well.
I'm going out in my boat tomorrow and want to try to see if I can get it to heave-to without fore reaching.
christian.hess likes this.
Alex W is offline
post #15 of 42 Old 12-06-2013
Re: Heaving-To
Just a quick note, if the boat is for-reaching you are not hove to you are sailing very poorly. As a storm tactic for-reaching defeats the whole point of being hove to. Main only, my full keeler will heave to very nicely.
barefootnavigator is offline
post #16 of 42 Old 12-06-2013
Re: Heaving-To
It is my understanding when heaving to ...there is some forward motion. The idea is to limit this motion as much as possible to remain in the slick produced, however, I don't think it's possible to completely eliminate it.
lancelot9898 is offline
post #17 of 42 Old 12-07-2013
Re: Heaving-To
If you are properly hove to there is Zero forward motion. Most sailors have no idea how to properly heave to and very fer boats will do it.
post #18 of 42 Old 12-07-2013
Re: Heaving-To
I have a full keel with a cutaway forefoot and when I "heave to" I tack and back wind the yankee, lock the wheel to steer upwind and adjust the main. No matter what I try I am close to being beam on to the wind whereas I want to be around 50 degrees from the wind. Because of the cutaway forefoot I can probably get closer to the wind with the main only with the rudder over hard and not worry about tacking through. I single hand a lot and heaving to is what I use when putting a reef in the main.
post #19 of 42 Old 12-07-2013
Re: Heaving-To
It might be more effective to just spill the air from the main and keep the boat sailing under jib alone. I find most boats with a cutaway forefoot wont heave to.
post #20 of 42 Old 12-07-2013
aeventyr60's Avatar
Re: Heaving-To
Heaving to works better for me with the stay sail and a deep reefed main, either the 2nd or 3rd reef, depending on wind and wave action. Adjustments to both rudder and mainsail to keep from fore reaching.
"Your dreams minus your doubts equals your net worth"
Life is a short journey, filled with emptiness and pain. Get all the sailing and booty you can.
aeventyr60 is offline
Heaving to MITBeta Seamanship & Navigation 33 07-28-2011 10:01 PM
Heaving to.....what gives. deadchest General Discussion (sailing related) 21 05-14-2011 06:43 PM
Heaving to StarJourney Learning to Sail 10 06-06-2010 01:27 PM
Heaving To sailak Seamanship & Navigation 5 06-19-2009 10:50 AM
heaving to snoreky Learning to Sail 7 03-13-2004 11:28 AM
