Voyaging on $500 per month - Page 103 - SailNet Community
 2421Likes
post #1021 of 2881 Old 02-13-2014
outbound's Avatar
Re: Voyaging on $500 per month
Dumb question.Have two frigiboat units both with keel coolers. How significant is ambient water temperature to ampH used? In short is it significant enough to be a major confounder to my energy budget?
s/v Hippocampus
Outbound 46
outbound is offline
post #1022 of 2881 Old 02-13-2014
guitarguy56's Avatar
Originally Posted by Bene505 View Post
Looks like there's a similar type compressor in there.
See page 10 of the manual, here: http://www.f3images.com/IMD/UserManuals/JB1113.pdf
But the fan is big and there's a water pump maybe. Stick a pen into the fan (to quiet it) and see if all the noise goes away... except for the pump noise. Not sure if you can turn the water pump off.
Best to just find a water cooler -- note that it needs to be a household cooler, not some industrial version that has a fan. Either way, you see it's the fan that make the noise. The compressor is really quiet.
Regards,
Brad
The smallest unit is the one I have, I've opened it up before so see the insides (engineer in me), there is no pump, the fan is I'm sure the noisy part since it's an induction motor, It could be replaced with one of the brush-less PC fans but that would void the warranty of the unit... you are right it does have a small compressor and the chiller is the cold unit with titanium tubes wrapped around the chiller... it's quite a simple setup if not for the electronics controller. I could try to find a used water cooler and cannibalize one but these run on 120 V so I'll have to stick to getting a 12 V version somewhere. Have you installed yours yet, any pics to show your installation?
guitarguy56 is offline
post #1023 of 2881 Old 02-13-2014
Originally Posted by newhaul View Post
Could always use a keel cooler like closed loop dry exhaust systems on powerboats may work well with antifreeze filled system
Marine Power Solutions - Marine diesel Engines
This would work and it does for cooling engines... and I'm sure it'll work for cooling the peltier... it's just complicating a simple solution of tapping raw seawater from a thru hull fitting and running it though the cooler and dumping the heated water... a small pump and several hoses are all that's needed.
post #1024 of 2881 Old 02-13-2014
sunfish?junior?
Go deep ? Need to cool the peltier plate ? I am not sure how fast the water temperatures drop in large bodies of water the ocean or the tropics ? I know it is huge in most freshwater lakes. The surface temps might be around 75* and 30 foot down it might be 50*
I know on the runway in a small plane you can be cooking and if you climb you will cool off and can even chill.
Changing your altitude or depth changes the temp. It should be even more pronounced in water than the air.
What if your flexible cooling intake line was held deep by a weight say 30-40 feet Could an arrangement be made to make this siphon so a pump would only need to prime or start the cooling water circulation ? This would save power an have less pump noise. You could only use this at anchor
When a sail boat starts to move it's potential to generate power is on the rise and typical power demands should be lower than when at anchor.
More thoughts ?
Kind Regards, Lou
Lou452 is offline
post #1025 of 2881 Old 02-13-2014
sunfish?junior?
Looks like one will not see much of a water temp/depth drop in the tropics. Hot is hot and some like it hot.
Peace, Lou
Lou452 is offline
post #1026 of 2881 Old 02-13-2014
Glad I found Sailnet
Bene505's Avatar
Yes mine is installed. I ran the pipes a loooog ways to keep the noise down and the heat where I wanted to put it. Then I found out how quite these things are and the reason most people just use a bit if tubing to put the heat, say, under the galley sink.
I also ran tubing for a separate fridge compressor, but it turns out I don't need a separate compressor for the fridge.
The connectors were quite straightforward. SeaFrost sells them Staylok I think they are called.
Note sure if I have any pictures. I bought a couple TradeWinds systems off eBay. One of them had been submerged. (Couldn't tell which one.) I replaced the compressor after I ran it overcharged. (They need very little refrigerant.)
Regards,
Brad
Great minds discuss ideas;
Average minds discuss events;
Small minds discuss people.
The best minds discuss sailing (and a little bit of politics). I don't know why. It's a mystery!
Bene505 is offline
post #1027 of 2881 Old 02-14-2014
islander bahama 24
newhaul's Avatar
Yes it would but somewhere someone was looking for a way to do the cooling with a closed loop with antifreeze and wanted a way to get rid o the heat thru a fan and radiator this would be simple to do and lower on power used vice a radiator and fan
The engineer in me showing again
Illegitimus Non Tatum Carborundum.
newhaul is offline
post #1028 of 2881 Old 02-14-2014
Sure that would work... problem is when it's a 90 Deg day and you are in the cabin the last thing you want is a radiator w/fan distributing hot air into the cabin anywhere... the idea is to take the heat from the unit out of the boat...
christian.hess likes this.
post #1029 of 2881 Old 02-14-2014
islander bahama 24
newhaul's Avatar
The keel cooler idea would take the place of the radiator and fan
Discussing these ideas is harder over the forum than in person I may have not been as clear in some of my posts as would be in person
newhaul is offline
post #1030 of 2881 Old 02-14-2014
It's just more thru hull fittings and or more complicated to add the plumbing and dialing in the correct temperature at the peltier... as I said earlier tap into an existing raw water intake and run through the unit and exit thru either the sink drain or one of the other drains... nothing complicated.... and I really don't think a closed loop system will remove as much heat as a flow thru system. Just my guess here...
Lou452 and christian.hess like this.
Cruising vs. Voyaging Barquito General Discussion (sailing related) 23 04-24-2014 08:18 PM
An idea for a new voyaging sailboat Irunbird General Discussion (sailing related) 12 04-24-2014 10:34 AM
Looking for dockage month to month elmo2 General Discussion (sailing related) 4 03-19-2011 05:40 PM
Paperwork Needed for Voyaging SailNet Cruising Articles 0 07-31-2002 08:00 PM
Caribbean Voyaging Overview Mark Matthews Cruising Articles 0 07-09-2002 08:00 PM
