Voyaging on $500 per month - Page 96 - SailNet Community
 2421Likes
post #951 of 2881 Old 02-12-2014
Cruising at a snail pace
Re: Voyaging on $500 per month
Originally Posted by aeventyr60 View Post
The unwashed masses are purchasing Solar panels in Asia for $125 for an 80 watt panel.. The Mercedes Benz Kyocera 135 watt panels go for about 400 bucks in Thailand....a bit more here with the duty and VAT...
My washed mass in the boonies of the Northeast of the USA got a 290W panel for $280 last year. Cold beer for me!
BTW - if you are a US citizen, paid taxes last, install a solar system on your boat, don't forget to get the credit when you do your income taxes.
Don't blow air up my rear, be useful and blow it at the sails!
Don0190 is offline
post #952 of 2881 Old 02-12-2014
islander bahama 24
newhaul's Avatar
Darn WiFi had long post all typed went poof found working small unit in a travel cooler free by trash will see what it does and costs to convert my ice box over
Illegitimus Non Tatum Carborundum.
newhaul is offline
post #953 of 2881 Old 02-12-2014
travlin-easy's Avatar
Don, the tax credit only applies if you are a live aboard - not a casual, weekend cruiser.
I only wish it were the case.
Gary
travlin-easy is offline
post #954 of 2881 Old 02-12-2014
Gary
I applies if your boat qualifies as a first or second home.
http://www.irs.gov/uac/Newsroom/Get-...ergy-Efficient
Don0190 is offline
post #955 of 2881 Old 02-12-2014
That's pretty much the way I read it - but most boats don't qualify for various reasons. I lived on mine for six months, and it still didn't meet the federal guidelines.
Gary
post #956 of 2881 Old 02-12-2014
I have claimed my boat as a second home for years and boats are specifically listed in the IRS rules as qualifying (has to meet requirements like a head and galley). The link I posted for the energy credit was an IRS link and specifically says it does not need to be your main home.
But I'm not your tax adviser and everyone should look up themselves.
newhaul likes this.
Don0190 is offline
post #957 of 2881 Old 02-12-2014
The requirement that most people fail to meet is the 14-day per year live aboard requirement, mainly because they really have no way of documenting this. In my case I did during my trip to the south, but there really was not much of a tax advantage other than the repairs and new solar panel I installed while in Marathon, FL.
The biggest advantage is deducting loan interest, if you financed the boat. In the eyes of the law, it's no different than interest on your home, therefore, fully deductible. Slip rent, pumpouts, winter storage fees, haul-out feets etc..., are not deductible. Guess I'll have to look into the solar energy credit and see whether it's worth the time and effort when I file this year.
Cheers,
Gary
post #958 of 2881 Old 02-12-2014
guitarguy56's Avatar
Originally Posted by Bene505 View Post
GG,
One could also use a multi-stage peltier setup. Never even heard of one, but it could be done. Of course it would use double the power to get 60 degrees below ambient, or thereabouts.
Regards,
Brad
I imagine it should work no different however many units you use... the idea is efficiency for using them.
My setup would have 2 peltiers for a freezer type compartment (10 deg F) and 1 high efficiency peltier for the refrig compartment (40 deg F) all running with circulating water... if you notice in the photo the originator did not have foam on the back wall, top or bottom of the compartment (wood cabinet) so of course he was not able to maintain the cold environment... but from the peltier unit it is frozen cold and the temp monitor is registering 1.6 deg C... not bad... I would install 3 inch foam insulation on the outside walls and 2 inch insulation on all walls for the interior compartment... the interior would then be a box of aluminum welded together to maintain even distribution and conduction of the cold surface of the peltier.
guitarguy56 is offline
post #959 of 2881 Old 02-12-2014
Cheers,
Gary
Unfortunately only the interest one pays for a second home, boat, RV, etc can be deducted as you mention... but why would anyone want to finance a boat to get a tax deduction? You would have to work to pay it off and that being the case kind of works against one going cruising and getting off the hook right?
Those of us fortunate to own our boats outright stand a far greater chance of cruising and getting away than those stuck with boat payments... no freedom there for sure... but for some the dream is owning the big enchilada boat rather then the real dream of leaving the dock/slip.
post #960 of 2881 Old 02-12-2014
islander bahama 24
newhaul's Avatar
My setup would have 2 peltiers for a freezer type compartment (10 deg F) and 1 high efficiency peltier for the refrig compartment (40 deg F) all running with circulating water... if you notice in the photo the originator did not have foam on the back wall, top or bottom of the compartment (wood cabinet) so of course he was not able to maintain the cold environment... but from the peltier unit is is frozen cold and the temp monitor is registering 1.6 deg C... not bad... I would install 3 inch foam insulation on the outside walls and 2 inch insulation on all walls for the interior compartment... the interior would then be a box of aluminum welded together to maintain even distribution and conduction of the cold surface of the peltier.
How about running the cooling water for the freezer unit thru the bottom of the fridge to increase the overall energy efeciency better heat removal means less cycling of the unit as a whole so instead of 70 deg cooling water say its 40 deg chill water which would get the freezer well below the 32 deg f
Much more and we may as well start our own thread on low buck peltier plate fridges ideas
newhaul is offline
Cruising vs. Voyaging Barquito General Discussion (sailing related) 23 04-24-2014 09:18 PM
An idea for a new voyaging sailboat Irunbird General Discussion (sailing related) 12 04-24-2014 11:34 AM
Looking for dockage month to month elmo2 General Discussion (sailing related) 4 03-19-2011 06:40 PM
Paperwork Needed for Voyaging SailNet Cruising Articles 0 07-31-2002 09:00 PM
Caribbean Voyaging Overview Mark Matthews Cruising Articles 0 07-09-2002 09:00 PM
