How big a holding tank vs. camping - Page 10 - SailNet Community
 13Likes
post #91 of 115 Old 02-03-2014
outbound's Avatar
Re: How big a holding tank vs. camping
Anti siphon on all fluid lines even if not exiting the boat is a good idea.
s/v Hippocampus
Outbound 46
outbound is offline
post #92 of 115 Old 02-03-2014
no longer reading SailNet
Alex W's Avatar
If your head has a sink then it is trivial to do a fresh water flush. Just leave the toilet always turned to "dry" and fill a container from the sink then pour that into the head. We keep an old pot behind the toilet for this purpose. I always do my last flush of the day with fresh water, and when sailing near a constant water supply we also use fresh water.
My old Catalina 25 had an even nicer option. The drain from the head sink went to the same through hull as the water inlet of the toilet. We would close the through hull and then you could fill the sink with fresh water and when you pumped the toilet it would draw that "grey water" into the toilet for flushing.
Alex W is offline
post #93 of 115 Old 02-03-2014
Originally Posted by christian.hess View Post
......if you want to have a clean head use some joy and leave it sud in the bottom.......
Except, this will kill the aerobic bacteria colonies in the tank, when you flush, that are necessary to break down waste in the tank and do not smell. If they are dead, the anaerobic bacteria will multiply and they are ones that stink.
Some "nuke" their tanks with stuff designed to kill everything. However, they always degrade and, when they do, the stinky bacteria have a field day. Not to mention, they are awful to be pumping into the environment, whether overboard or ashore.
There are products that will not kill the good bacteria, such as Raritan CP. One bottle will last a couple of seasons. It isn't really the bowl itself that smells.
christian.hess likes this.
Jeanneau 54DS
Minnewaska is offline
post #94 of 115 Old 04-23-2014
having just purchased a boat with a holding tank,i can now confirm it is permantly disconnected,after seeing paper and liquid run down the deck,after 3 uses and blocked lines it now goes direct to sea.there is enough other toxins going in the water now so whats a bit more biodegradable matter going to do?
tomharry is offline
post #95 of 115 Old 04-23-2014
Let me jump in here with my 2 cents worth. As far as using a bucket; I don't have a problem with that. I do it all the time on my little Windrose. But I avoid carrying it down the dock and past my friends by simply taking the Double Dooty or Wag Bag and putting them into a garbage bag. Have a Porta Pot on the Catalina but have only used it in extreme emergencies. The Hunter has a head and I can't keep the Grandkids and women from using that.
TerryBradley is offline
post #96 of 115 Old 04-23-2014
Don't call me a "senior"!
Puddin'_Tain's Avatar
Originally Posted by TerryBradley View Post
... The Hunter has a head and I can't keep the Grandkids and women from using that.
They do seem to have a "moth to a flame" sort of attraction, don't they?
"If a man must be obsessed by something, I suppose a boat is as good as anything, perhaps a bit better than most." --- E.B. White
Puddin'_Tain is offline
post #97 of 115 Old 04-24-2014
Originally Posted by CarbonSink62 View Post
I've done the porta-potti on my 18; it was ok. At least I could offer my guests something more than a bucket.
I love having a real head on my 25 and I have had no complaints of odor at all.
I leave $10 in an orange key fob hanging from the lifeline and call NH Dept of Evironmental Svcs; they come by in a boat and suck the tank dry. I don't even have to be there. It's a sweet deal.
Funny story about my time in Uncle Sam's Canoe Club:
On a submarine the sanitary tanks are emptied by coming up close to the surface; pressurizing the tank; and opening the overboard valve. There are many amusing stories about people inside the boat not being aware that this was happening and trying to use the head. This isn't one of those stories.
In port, the tanks are emptied the same way, but into a sewer pipe on the pier. The boat behind us had left earlier that day, but the crew failed to replace the blank-off when they disconnected their pump out line (cue sinister music). At some point, we needed to empty our tank and you can guess what happened. The Topside Watch screams into the 1MC "Secure blowing sanitary tanks! Secure blowing sanitary tanks!" That got everyone out of the boat to see what was going on. The sewer line ports are open towards the dock, not the water, I guess so it is easier to connect the hoses, so the 'effluent' was sprayed all over the parked cars on the pier. I maybe should have mentioned earlier that only high ranking officers get to park their cars close to the boat; couldn't have happened to nicer people.
Ken
The bubble head branch of uncle Sam's canoe club always has funny stories about blowing san tanks( not what we called it). My 1st boat we had a RM1 that managed to blow sans back into the galley twice on 2 consecutive duty days. Nothing quite like seeing the ice machine full of poo and little bits of toilet paper.
Roadking Larry is offline
post #98 of 115 Old 04-24-2014
I sympathize with your point, but you just can't have an open outlet in a closed harbor or anchorage. I do agree that the 3nm offshore rule is ridiculous. It has nothing to do with science, its' just the limit of the State's delegated right to regulate their waters.
That said, if you are caught without a closed and secured MSD (let alone disconnected) in a no-discharge area, I understand the fine can be a couple of grand. It is clearly on the checklist for an inspection boarding.
Jeanneau 54DS
post #99 of 115 Old 04-24-2014
Cruising at a snail pace
Head threads always make me happy that I don't visit some people's boats!
Don't blow air up my rear, be useful and blow it at the sails!
Don0190 is offline
post #100 of 115 Old 04-24-2014
I guess this thread just proves how popular "potty talk" is!
Convert existing steel freshwater tank to blackwater holding tank? patrickstickler General Discussion (sailing related) 7 09-24-2010 07:55 PM
Holding Tank cvsheppard Pacific Seacraft 1 06-01-2009 10:27 PM
Holding Tank leterip Announcements and Suggestions Box 2 12-23-2008 10:03 AM
Holding tank DLM Gear & Maintenance 11 12-06-2007 06:51 AM
Holding Tank Scubado Gear & Maintenance 14 04-01-2004 11:24 AM
