How big a holding tank vs. camping - Page 12 - SailNet Community
 13Likes
post #111 of 115 Old 04-27-2014
Re: How big a holding tank vs. camping
Originally Posted by jnorten View Post
Pee: Dry bowl (NO lake water intake). After going, fill a cup with fresh water from the sink. Pour water, using quick swirl motion, into bowl. Pump bowl dry. That's it. This eliminates much of the volume going into the tank--pumping lake water into the bowl. Folks don't realize how much water this pushes into the tank.
Poop: Follow same method as above. HOWEVER, add one extra step; before going, be sure to pour a cup of water into the bowl. If necessary, swirl a second cup through the bowl after going.
Using this manner, 3-4 adult males can make a ~25 gallon tank last the better part of a week. When tied up in the evenings, use shore facilities. While at sea, guys can pee off the back of the boat.
While this method will conserve capacity, it also leaves waste in the hoses, which is the number one cause of odor. If your waste lines rise from the head to a vented loop and then return down to the holding tank, it takes a good gallon of clean chase water to flush them out.
We once had a girl at the helm. A guy peed of the back and she had no clue.
I have no problem with peeing over the side in open water, but it is technically a violation of discharge laws and there have been people cited, if witnessed doing so.
Jeanneau 54DS
Minnewaska is offline
post #112 of 115 Old 04-27-2014
"I have no problem with peeing over the side in open water, but it is technically a violation of discharge laws and there have been people cited, if witnessed doing so. "
Runs contrary to everything I've ever read. You are not allowed to discharge waste from any equipment on the boat, or any part of the boat, but AFAIK an animal, human or otherwise, is still allowed to pollute the waters directly.
Pee in a cup and dump it, that's a violation. Pee without the cup, no violation of sanitary or pollution or dumping laws. Local laws about public urination or indecent exposure, are a whole other issue. (Political comment deleted by tdw) . (VBG)
hellosailor is offline
post #113 of 115 Old 04-27-2014
Old enough to know better
Pee in a cup and dump it, that's a violation. Pee without the cup, no violation of sanitary or pollution or dumping laws. Local laws about public urination or indecent exposure, are a whole other issue. Hillary Clinton might have to wear a burqah to avoid that. (VBG)
I have often heard this but have a hard time believing it. They could get you for urinating in public (a misdemeanor in many locals) or indecent exposure.
miatapaul is offline
post #114 of 115 Old 04-27-2014
"I have often heard this but have a hard time believing it."
Heard what, (Off Topic comment deleted)
What's so hard to believe? Most regulations are poorly written and focused on one point. Regulations concerning the discharges from a vessel, are written to regulate the discharges from the vessel and the equipment on the vessel. The souls on board are part of neither, under the laws.
In fact, from the objective viewpoint of a topologist, a sailboat is very much like a donut. It is simply a torus (as the donut) but with multiple holes in it. Two-hole torus, three-hole torus...Still a torus. Now, apply that logically to the regulations, and you can have and use all kinds of aperatures "on" the boat, because if they penetrate the hull, they are not on the boat. They are simply more holes in the torus, and you are still on the outside of the torus, outside of the vessel, even if are belowdeck and pee through a urinal fitting. That's not "on" the boat, that's still on the outside of the torus.
As to the regulations...check the CFR. Its in their somewhere. No mention of toruses (tori?) though.
post #115 of 115 Old 04-28-2014
islander bahama 24
newhaul's Avatar
I posted earlier about the urinating issue if it goes into a comode it must be retained inland any other device as well as peeing over he side comes under the direct discharge exception as I referenced in post 27 of this thread
Illegitimus Non Tatum Carborundum.
newhaul is offline
Convert existing steel freshwater tank to blackwater holding tank? patrickstickler General Discussion (sailing related) 7 09-24-2010 08:55 PM
Holding Tank cvsheppard Pacific Seacraft 1 06-01-2009 11:27 PM
Holding Tank leterip Announcements and Suggestions Box 2 12-23-2008 11:03 AM
Holding tank DLM Gear & Maintenance 11 12-06-2007 07:51 AM
Holding Tank Scubado Gear & Maintenance 14 04-01-2004 12:24 PM
