need help and advice -mid cruise keel crack - SailNet Community
 31Likes
post #1 of 114 Old 01-18-2014 Thread Starter
Hi
We're headed to honduras in a recently purchased 1969 36' C&C Frigate. She's been a great boat, and took us across from Florida to San Pedro in 6 days! The issue is once we arrived here and took a bit of respite from the norte's causing the gulf current to stack up 8' against 30-40kt winds was after doing a routine dive on the hull we've got a 8" vertical crack in our keel, from the bottom up, about an inch wide in the lead. I'm not sure how to proceed. I don't have photos yet but i'm working on it. it's from the base of the keel vertically up 8" or so, on both sides, and about 3/4" - 1" wide.
I imagine when we got into the interesting weather situation a preexisting crack from a previous grounding must have worked open as the boat flexed in the swell.
I can keep it in calm water and get to rio dulce, or if I can find out this is going to sail I can continue to utila and do the ~80m crossing, and then get to rio dulce later as planned and pull the boat. It made it across the gulf of mexico, the yucatan current, and a series of whuppings so far.
I know this isn't good, I'm trying to find out what I need to do to get it repaired. what is a guy at a yard going to tell me needs to be done? I just bought the boat a week ago, it's officially for sale now, not that it'll be easy to sell after this, but yeah... there's a crack in my keel. not good. all advice is appreciated, we're forced to leave on monday due to our visa limitations, so we're scrambling.
Thank You for any advice,
Best;
-Chance.
chancemiller is offline
post #2 of 114 Old 01-18-2014
Re: need help and advice -mid cruise keel crack
Is it the keel/centerboard version? is the ballast package bolted into a molded cutout?
Wondering if the above is true then you're getting a separation of the ballast plug from the molded part of the hull... any keel/ballast bolts in the bilge area?
Sorry, not sure of how this boat is constructed so it's difficult to guess. But a vertical crack up both sides suggests something like that is going on... The nearly 1" wide is the really worrisome aspect of this.
Do you know for certain it wasn't there when you first left?
Faster is offline
post #3 of 114 Old 01-18-2014
krisscross's Avatar
The first thing I would do is to put some underwater epoxy on that crack - if you have enough, of course. May not help too much in the long run but will make that spot stronger until you fix it properly.
Plato
krisscross is offline
post #4 of 114 Old 01-18-2014 Thread Starter
This is the full keel centerboard version, there are bolts in the bilge and they are good when inspected. I dove on her before we left, I didn't see anything that warranted further inspection, definitely not a huge crack. I feel like we've been sailing with her the whole while.
post #5 of 114 Old 01-18-2014
To stop a crack from getting longer you drill a hole at the end of the crack. A standard procedure for many materials.
I'm not a professional, but I suspect the crack should be filled, as well as the hole, and continue the trip.
Since it is vertical, the crack should not have another consequence. If it was horizontal, there could be an other consequence.
Of most importance, is to drill the hole, to stop the crack from getting longer. The rest is just filler and cosmetic.
sony2000 is offline
post #6 of 114 Old 01-19-2014
Sea Sprite 23 #110 (20)
mad_machine's Avatar
definitely drill a hole, it will round off the top of the crack and keep the stress from finding another weak spot to continue upwards.
Art Haberland
In the end all that matters is how fully you loved, how gently you lived, and how gracefully you let go of things that did not belong to you -Buddha
mad_machine is offline
post #7 of 114 Old 01-19-2014
TQA
Bombay Explorer 44
TQA's Avatar
You need to get it out of the water and have a pro look at the problem. You need to do this before you go back out to sea. That is the bad news.
The good news is assuming it is an encapsulated GRP keel fixing the GRP bit is easy and low tech. GRP guys can work wonders and it does not take long. I might also be tempted to drill through the keel and use some long bolts/studding to hold things together.
Something that is potentially bad news would be finding out that the ballast was iron and that sea water had got in causing rust which expands and that is what caused the split. If that is the case I think you would need to get that rusty iron out somehow and replace with fresh rust free iron or maybe even lead.
Forget about drilling the holes at the end of the crack and going back out to sea. You have a structural failure in a mission critical item. You have to fix it.
Faster and Flybyknight like this.
TQA is offline
post #8 of 114 Old 01-19-2014
billyruffn's Avatar
Exclamation Re: need help and advice -mid cruise keel crack
As a general rule I try to be respectful when I disagree with someone, but IMHO this is very bad, no that's too mild....it is extraordinarily bad advice. Haul the boat, do a proper technical evaluation to determine the cause and fix it properly before going to sea again.
P.S. There's a cautionary tale in the original post for those who dream of buying a boat and sailing off to the tropics. Find it?
Flybyknight likes this.
billyruffn is offline
The Following User Says Thank You to billyruffn For This Useful Post:
rhpaw (01-23-2014)
post #9 of 114 Old 01-19-2014
Delta-T's Avatar
Originally Posted by chancemiller View Post
Hi
Best;
-Chance.
Your boat is very similar to my boat and same year. I also have a full encapsulated lead keel with centerboard. I have some detailed plans of the keel and centerboard setup. This might give you/us an idea of what you are dealing with. Is the crack near the centerboard pivot pin? Can you give us a little better idea of the location of the crack? 1" wide? Is it only one side of the trunk? Or running from the trunk slot up towards the stem, straight up the center?
Here is a link to my photobucket pics and plans. If you want the plans in PDF or AutoCAD I can provide that too. CenterboardB321969plan_zps3cfc0c37.jpg Photo by greatfulldad123 | Photobucket
Eric
Delta-T
1968 Bristol 32 Keel/Crb Hull 26
Narragansett Bay RI USA
Delta-T is offline
post #10 of 114 Old 01-19-2014
christian.hess's Avatar
haul the boat out first...since its a centerboard "full keel" this mught be the cause of the crack...
no reason to get all bent out of shape...advice is advice, take it or leave it
another point is where he is located right now
real easy to say haul the boat and have a proffesional to look at it, on a 69 boat...in honduras or rio dulce
in rio dulce you have options but I would look for a glass repair guy and not a general "proffesional"
if its the stub per se...and only glass then its an easy fix..like mentioned before if you have lead or iron as well as the centerboard you have more work to do...mostly removal of the centerboard first...
its vey common on small keel centerboarders to have cracks like this...sometimes its caused by overcanvassed sail and pressure on the centerboard for too long, or the board is down and you hit something sideways and this cracks or bends the stub or it simply may just be from old age
you can haulout in pt. barrios, rio dulce and or look for a place to dive real well in clear water(roatan) jeje
for now anything anyone says is just a guess...pics first!
good luck I wish you well
ps. the advice to drill a hole to stop further cracking is far from extremely bad advice, if its just glass its a very good fix...again I stress you must know what(material) is actually cracking...
Merit 25 sold...Islander 36 still afloat? who knows...Im still in Columbus, and back...I think...jajajaja!!!!
christian.hess is offline
Crack in front of encapsulated keel FishFinder Gear & Maintenance 19 04-29-2013 12:09 PM
Keel grounded : gelcoat crack advice jinjer Sailboat Design and Construction 9 06-25-2012 12:19 AM
keel shoe crack bvio Announcements and Suggestions Box 16 06-02-2012 05:42 PM
Keel Crack in C&C 30 outerisland C & C 5 08-01-2010 09:17 AM
Keel Bolt Access Crack SailChick20 Gear & Maintenance 21 10-31-2008 12:01 PM
