why so long? - Page 10 - SailNet Community
 19Likes
post #91 of 121 Old 02-03-2014
manatee's Avatar
Re: why so long?
Jack,
Try using the front of a bike for an example: handlebars are your 'T' on top of rudderpost, fork & front wheel are your rudder, attach steering cables at handgrips.
"The skipper should be the calmest person on board. It is good for the morale of those around you. However, if everyone around you is frightened then be aware of the possibility that they know something you donít."
~~Dylan Winter,
manatee is offline
post #92 of 121 Old 02-03-2014
Barquito
Barquito's Avatar
Re: why so long?
no. it wouldn't. no harder than adding a tiller extension to a shorter tiller. but, if the boat needs a long tiller for leverage, that would end up being a useless modification. you'd always have to have it extended.
Just to clarify my idea: This would be a ridgid extension. It wouldn't have a joint at the end of the tiller like a hiking stick. The extension could be installed for conditions that require more leverage. And removed when not needed.
Valiant 32
Barquito is offline
post #93 of 121 Old 02-03-2014 Thread Starter
captain jack's Avatar
Re: why so long?
Originally Posted by manatee View Post
Jack,
ja! das stimmt! that's exactly what i am getting at. so, what do you think?
The only rules that really matter are these: what a man can do and what a man can't do.---Captain Jack Sparrow
1971 Cal 27
captain jack is offline
post #94 of 121 Old 02-03-2014 Thread Starter
Re: why so long?
yeah. my sailing dinghy used to sort of be that way. it had a smaller tube inside of a bigger tube, for the tiller. you could move the inside tube in or out, as long as you twisted while pushing or pulling, to get more or less tiller. i don't think the PO intended it that way. i just think they wanted a longer tiller and i 'discovered' you could do that with their solution to get one.
1971 Cal 27
post #95 of 121 Old 02-03-2014
manatee's Avatar
Re: why so long?
Should work. Some thoughts: How much distance between pillar and rudder? (Worried about a tripping hazard some dark night.) Change drum diameter inside pillar to change "gear ratio" --> how many turns of wheel for full rudder displacement. Turnbuckles to adjust tension? Any real-life examples? Maybe make a model to work out kinks? For my part, I think I would miss the feel of the conversation between water and rudder that the tiller gives.
~~Dylan Winter,
manatee is offline
post #96 of 121 Old 02-03-2014 Thread Starter
Re: why so long?
i am still planning on trying a shorter tiller before i go the wheel route but it really would make a lot better space in the cockpit.
not a lot of space between the rudder post and pedestal. i want it as close to the rudder post as functionally possible, since i won't be standing behind it to steer. i would probably have tension adjusters on the ends of the T.
1971 Cal 27
post #97 of 121 Old 02-03-2014 Thread Starter
Re: why so long?
another method i have been considering would be a chain drive method. no cables.
there would be a sprocket on the rudder post. in the pedistal would be a vertical shaft. at the bottom, a sprocket. at it's top, a bevel gear or mitre gear. the wheel shaft would have a bevel or mitre gear to mesh with the one on the vertical shaft and a chain would link the pedestal sprocket with the rudder post sprocket. you would have to have an adjustable idler sprocket between the rudder post and pedestal to maintain proper tension. you would have to have 2 bearings for each shaft.
the components would need greased from time to time.
in either system, i'd be looking for 1.5 turns lock to lock.
1971 Cal 27
post #98 of 121 Old 02-03-2014
manatee's Avatar
Re: why so long?
One good thing about the tiller and a fully-stocked cockpit,- you shouldn't be doing anything hasty. It could even be fun playing musical chairs. When the weather goes dodgy, you'll send the passengers below and have all the room you need.
~~Dylan Winter,
manatee is offline
post #99 of 121 Old 02-03-2014
TakeFive's Avatar
Re: why so long?
IIRC, you still haven't sailed this boat yet. I'd suggest sailing her first before modifying the tiller length. You need to see how the helm is balanced. You might need the long tiller for leverage.
I know people who get sore shoulders from fighting weather helm with their tiller.
You can't assume that other boats of similar length should have a similar tiller - all boat sail differently. Even sister ships of the same design could sail differently due to different sail age/shape, rudder design and/or custom modifications, mast rake, boat pitch, etc. You need to learn about these things first, and the only way to know for sure is to sail her first.
Rick S., Swarthmore, PA
TakeFive is offline
post #100 of 121 Old 02-03-2014 Thread Starter
Re: why so long?
what i was going to do was to sail the boat and steer with my hand at different points on the tiller. first, decide how short is too short. then, decide how long is comfortable. then, i will make a new tiller based on my findings.
as you say, it's no good just wacking off random lengths, without some idea of what i am doing.
1971 Cal 27
Missing Sierra Madre man's sailboat found in Long Beach - Long Beach Press-Telegram NewsReader News Feeds 0 07-25-2013 07:30 AM
Strictly Sail Long Beach boat show comes to Rainbow Harbor - Long Beach Press-Telegra NewsReader News Feeds 0 10-18-2012 06:20 AM
epoxy barrier coat sun exposure how long is too long? johnnyandjebus Gear & Maintenance 18 06-02-2012 03:39 PM
Owning a boat long/cruising from long distance? utchuckd Cruising & Liveaboard Forum 5 04-21-2010 11:39 AM
good boat for the long run with eventual very long trips in mind AmeriCdn Boat Review and Purchase Forum 2 07-24-2007 01:05 PM
