Sleeping preference? - Page 5 - SailNet Community
 8Likes
post #41 of 47 Old 02-04-2014
outbound's Avatar
Re: Sleeping preference?
Thanks I was at work and could not remember the name. Was not happy about the cost but very happy about not having a crabby wife in the morning. Froli it is. Had german lady sell it to us. She was very helpful in figuring out how many we would need. You can control the stiffness of the springs just like those fancy dan air mattresess.
s/v Hippocampus
Outbound 46
outbound is online now
post #42 of 47 Old 02-04-2014
Old enough to know better
Originally Posted by mitchbrown View Post
Ive been looking for a place that could make me a v birth futon. Ive done lots of searching on the web and there are lots of futon places that say custom built, but they dont really make odd shapes. Any ideas???
Most futons are cotton or other fibers, I don't think I would want one on a boat as they would hold moisture.
Sent from my ADR6425LVW using Tapatalk
1976 C&C 33
Project boat, lots of work to be done!
miatapaul is offline
post #43 of 47 Old 02-04-2014
tdw
Super Fuzzy Moderator
tdw's Avatar
While I reckon that with more modern craft the cotton thing is somewhat over blown I'd have to agree with Miata re no Futons. Cotton sheets may well take in more moisture than synthetic but they dry out quickly, a damp futon is not to be imagined.
For mine, a good nights sleep is most important (I'm old, these days beds are for sleeping .... sigh ) and I do plan on having a custom made mattress made and damn the expense.
Regarding the Frolli gizmos ..... how easy are they to pack up if you need to access under the v-berth ? I've been a bit wary of them.
Andrew B (Malö 39 Classic)
― Terry Pratchett.
tdw is online now
post #44 of 47 Old 02-05-2014
outbound's Avatar
You only need to unsnap the ones near the boards edges. For the forward queen a non issue as the whole thing lifts on hydraulic cylinders. For the aft quarter berth just don't snap together where the bundle board goes. Don't see your concern a major issue unless you are going in and out of the lockers under the berths frequently. The cost was a shock for a bunch of pieces of plastic but it's a buy once expense so think its worth it.
s/v Hippocampus
Outbound 46
The Following User Says Thank You to outbound For This Useful Post:
tdw (02-06-2014)
post #45 of 47 Old 02-05-2014
Originally Posted by DRFerron View Post
I read a tip on someone's cruising blog to use the Queen fitted sheet with the corner at the V of the berth.
To make custom sheets:
Take a conventional fitted sheet, sized a little larger than your berth area. Cut the 'boxing' off, about six inches in from the elastic.
Now you have a flat sheet and a strip of elasticized boxing. Take the flat sheet, and bring it to the berth cushion, and trace the cushion's shape onto the sheet. Cut that out, adding seam allowance (I use 1/2 inch).
Now you have a flat sheet in the shape of your berth. Now, sew the elasticized boxing you're cut off back to the shaped flat sheet. The elasticized boxing should hopefully be longer than the new resized sheet needs, just seam and cut the extra off.
Now you have a custom fitted sheet in the shape of your berth. I find that I have to label the ends of my custom sheets so my husband can make the bed without cursing too much
Donna_F and jimgo like this.
Multihullgirl is offline
The Following User Says Thank You to Multihullgirl For This Useful Post:
eherlihy (02-06-2014)
post #46 of 47 Old 02-06-2014
Sailing Guy
Send a message via Skype™ to Sail444
In almost all cases in cruising boats, the preferred location for sleeping is toward the aft. The V-bert is OK for the marina or calm anchorage but in cruising mode, the bow moves up and down more than any part of the vessel which can make sleeping uncomfortable.
Sleep will be one of the most important needs during overnight cruising. Make sure you get the best innerspring or memory foam mattress possible.
Fair Winds,
Steve Szirom
Sail444 is offline
post #47 of 47 Old 02-06-2014
tdw
tdw's Avatar
Fair Winds,
Steve Szirom
OysterYachting.com
Absolutely true but I'm thinking this thread is more about when at anchor or berthed. If just the two of us I sleep in the saloon when overnighting. Makes it quicker and easier to hit the cockpit if needed. When fully crewed I'll go quarter berth though I do admit that on one overnighter in quite nasty conditions I crawled into the forward cabin (which on that particular boat was nowt but a sail locker) and slept like a log cocooned by the sails.
ps - Outbound .... thanks for the info re Frolli.
― Terry Pratchett.
tdw is online now
Slip preference? eherlihy General Discussion (sailing related) 27 03-03-2011 05:46 PM
Bilge pump preference Shortman Gear & Maintenance 16 03-18-2010 12:49 PM
Deck Paint Brand/Preference and Tips brianontheroad Gear & Maintenance 10 07-21-2008 01:31 PM
Main VHF Preference? MedSailor Gear & Maintenance 33 05-06-2008 04:44 PM
Extended Stay in the Keys - What's Your Preference? PBzeer Cruising & Liveaboard Forum 46 12-22-2007 07:15 PM
