Raymarine ST60 - SailNet Community
post #1 of 3 Old 11-03-2005 Thread Starter
Raymarine ST60
Anyone have experience w/ the Rotavecta option on the ST60? Any idea why it is recommended for powerboats and not sailboats?
I am looking at buying one used and have some reservations.
thanks
johnbarry is offline
post #2 of 3 Old 11-03-2005
Raymarine ST60
Looks like a shorter transducer cable and with a powerboat you don''t need it to be mounted offset from the mast but probably need added height.
You really don''t need extra heigth to mount a wind indicator on top of an already high mast. It''s just a modified mounting system more than an fundemental transducer design difference. You would do better with a sailboat designed transducer mounting so it is out in front of the mast.
PaulBl is offline
post #3 of 3 Old 11-07-2005
CEO - SailNet.com
marinedtcomRob's Avatar
Raymarine ST60
The issue with a Rotavecta is that it''s not going to give you the same accuracy in terms of wind direction that the vane transducer will. So for powerboaters the Rotavecta is considered good enough, but generally it is thought sailboaters want as close as they can come to dead on accuracy regarding wind direction. For more information you might want to touch base with a Raymarine tech at 800-539-5539.
marinedtcomRob is offline
ST60 Multi NMEA Interface dave8976 Gear & Maintenance 20 07-23-2010 04:14 PM
raymarine c70 xtal Gear & Maintenance 1 02-12-2005 04:05 PM
MaxSea to Raymarine GPS MCamp63 Gear & Maintenance 1 10-17-2003 07:29 AM
New Auto pilot Raymarine vs simarad obiec Gear & Maintenance 7 01-14-2003 02:08 AM
Raymarine Autopilot gmaurer Gear & Maintenance 5 06-28-2002 12:50 PM
