Painting Your Boat - SailNet Community
post #1 of 5 Old 12-09-2005 Thread Starter
Ronbye's Avatar
Painting Your Boat
I am painting my Rival 32 sailboat in the spring of 2006. My original intent was to have it sprayed, however I am doing this outdoors and the weather window is virtually nil. So I am thinking about using the roll and tip method. Has anyone had any good results using this method. What are the pros and cons of the roll and tip method
Ronbye is offline
post #2 of 5 Old 12-10-2005
catamount's Avatar
Painting Your Boat
I suggest you peruse the following site: http://www.triton381.com/, and maybe join the forum there, as there are quite a few guys hanging out there who have painted their boats by roll and tip.
catamount is offline
post #3 of 5 Old 12-12-2005 Thread Starter
Ronbye's Avatar
Painting Your Boat
Thanks,I did what you suggested and it was perfect. There are a lot of very knowledgable people there.
Ronbye is offline
post #4 of 5 Old 12-16-2005
Painting Your Boat
I npainted my Hull a few years ago using the roll and tip method and it came out great. Make sure you thin using the slowest evaporating thinner you can. Practice on a piece of glass.Too many runs and the mix is too thin. Brush marks mean its too thick add small amounts of thinner. also hull teperature will vary greatly from end to end if your not in full shade or sun. I had to add thinner as I went from the shady end to the sunny end.
When your done make sure to invest in a rubber mooring bouy because the plastic ones will ruin all your hard work.
noscreenname is offline
post #5 of 5 Old 12-16-2005 Thread Starter
Ronbye's Avatar
Painting Your Boat
Thanks for the tip, I intend to use a large tarp over the boat so that I can keep the rain and other stuff off. Sun is a rare item around my area, especially in the spring.
Ronbye is offline
Re-naming the boat pirateofcapeann General Discussion (sailing related) 130 01-07-2014 11:14 AM
New name (I know, I know) owlmtn Boat Review and Purchase Forum 13 12-13-2009 07:46 PM
help with lifes dream kimby Boat Review and Purchase Forum 37 12-02-2009 11:32 PM
What can you tell from the numbers? brazilnut Boat Review and Purchase Forum 10 07-01-2009 04:09 PM
buying first boat jerrycooper14 Boat Review and Purchase Forum 21 04-23-2002 02:15 PM
