Engine trouble - Page 2 - SailNet Community
Advertise Here
Go Back   SailNet Community > General Interest > General Discussion (sailing related)
Like Tree3Likes
Old 02-11-2014
CaptainRahnn's Avatar
OUPV 25 Ton
CaptainRahnn is on a distinguished road
Re: Engine trouble
Originally Posted by mitchbrown View Post
metal fatigue
Would there be any evidence ie chunks of springs, pieces of metal visible when I pull off the cover?
  #12
Old 02-11-2014
OUPV 25 Ton
Re: Engine trouble
metal fatigue
Would it cause any transmission slip?
  #13
Old 02-11-2014
Wulf is on a distinguished road
Re: Engine trouble
Get yourself a stethoscope with metal probe and listen at various points on the engine, transmission etc to isolate where the noise is coming from. You can also use a long screwdriver, broom handle etc instead go a stethoscope; hold the blunt end end tight to your (good if applicable) ear and probe with the other end. Just listening with an open engine cover can be deceiving. Be very careful that you don't get tangled up in anything that's moving ( pulley, belt, shaft etc) while probing.
  #14
Old 02-11-2014
Maine Sail's Avatar
Re: Engine trouble
Originally Posted by CaptainRahnn View Post
So I went out for a sail today up to Lost Isle and caught a great sunset. The San Joaquin Delta has some of the best sunsets in my opinion. The wind died so I decided to fire up the iron jib and motor back. As I approached my Harbor entrance I slowed down and heard an awful rattling sound coming from what seemed like my transmission. I sped back up and the sound was gone. Slowed down again and there was that sound again. I'm thinking Wtf? So I get into my slip and put it in gear again at low idle and it's starts rattling again. Took off the engine cover and it seems to be my tranny making the noise, it goes away out of gear. Anyone have an idea what I'm dealing with? Throw out bearing possibly? It's a westerbeke 30 with a Paragon transmission and Walter V drive and yes the oil lvl is full.
Thanks
Smooth Sailing _/) _/)
Sounds like a damper plate. They run under $200.00 clams but take many hours to replace.... Not difficult, about a 4 on a scale of 10, but can be awkward because the bell housing has to come off to access it..
______
-Maine Sail / CS-36T
  #15
Old 02-11-2014
nauticalrich's Avatar
nauticalrich is on a distinguished road
Re: Engine trouble
Don't want to sound too stupid here but check the prop and shaft for debris.
nauticalrich
1985 31 Oday
Bridgeport, CT
The Following User Says Thank You to nauticalrich For This Useful Post:
CaptainRahnn (02-11-2014)
  #16
Old 02-11-2014
OUPV 25 Ton
Re: Engine trouble
You know I was thinking that too, because I could hear it outside in the cockpit clearly. At first it sounded like it could be under the boat . Shivering thinking about getting into that water though.
I'll try it today.
  #17
Old 02-11-2014
jimgo's Avatar
Asleep at the wheel
jimgo is on a distinguished road
Re: Engine trouble
My damping plate gave way when we first bought the boat. My blog, and the thread Apparently I'm not meant to have a boat... has more information.
- Jim
Home: Western Philly 'burbs
1980 Allmand 31
1975 Albacore 15
  #18
Old 02-11-2014
OUPV 25 Ton
Re: Engine trouble
Were you able to still drive the boat? Just wondering if this will eventually not go into gear. Currently mine shifts and drives it just makes noise at low rmp while in gear. Thanks
  #19
Old 02-11-2014
THEFRENCHA's Avatar
THEFRENCHA is on a distinguished road
Re: Engine trouble
Had the same symptoms with a propeller blade slightly damaged!
Damage was so small that not visible when diving !
A tiny damage on a blade can cause big vibrations at low rpm
  #20
Old 02-11-2014
jimgo's Avatar
Asleep at the wheel
Re: Engine trouble
No. When the damping plate finally lets go, you lose all propulsion. I would strongly recommend checking it BEFORE running too much more (or at least before finding the cause of the problem). When ours blew, the springs sheared into many pieces and really banged around inside the engine. They lodged in the starter and burned out the starter, they tore up the bell housing, and they damaged the rear seal on the engine. It's really not the kind of thing you want to have happen when you're out, especially in bad weather.
While I certainly defer to MainSail's opinion, I'm a bit surprised that the damping plate would let go in the conditions you describe. I guess, once the metal is fatigued, it doesn't take much for it to break. I would have expected more violent conditions (e.g., sheets tangled in your prop, running the prop aground, lots of pounding due to steep chop, etc.) to have occurred at the same time.
I'll also tell you that getting the bell housing off on my engine (Universal M16) wasn't the easiest thing in the world, in part due to the way my engine compartment was laid out. It was easier to disconnect the engine and move it out of the engine compartment than to try to work on it in place. In the end, I chickened out and let the marina do the work.
- Jim
1980 Allmand 31
1975 Albacore 15
Tags
clutch , engine trouble , gears , transmission
You may post attachments
You may edit your posts
New and already in trouble Antoine Antipodes Introduce Yourself 19 01-05-2014 02:36 PM
Diesel Engine trouble-shooting JordanH Diesel 11 08-14-2012 08:20 AM
Aratere barred from sailing over engine trouble NewsReader News Feeds 0 11-02-2011 04:50 AM
engine trouble marinoinPV Gear & Maintenance 8 01-23-2008 06:33 PM
Engine trouble mwrohde Gear & Maintenance 11 05-16-2007 11:46 PM
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
SEO by vBSEO 3.6.1
