Converting a Catboat to a sloop - SailNet Community
 2Likes
  • 1 Post By RobertKWFL
  • 1 Post By fallard
post #1 of 10 Old 02-12-2014 Thread Starter
Sea Sprite 23 #110 (20)
mad_machine's Avatar
While the History of the Cat Rigged boat is a short but tumultuous one, one thing that stands out is that some Cats had jibs, technically making them a sloop. I have also seen pics of modern Herrshoffs and Sanderlings with small sprits and jibs.. so I am wondering, what does it take to do that to a cat?
I imagine you need to beef up the bows to handle the sprit and it's support, but what about stays? most cats only have a forstay, do they need side stays to support the stress of the jib as well?
While I have no real urge to sloop/cat, it is an interesting thought as it would allow one to hove to in a cat and let you sail closer to the wind
Art Haberland
In the end all that matters is how fully you loved, how gently you lived, and how gracefully you let go of things that did not belong to you -Buddha
mad_machine is offline
post #2 of 10 Old 02-13-2014
Bristol 45.5 - AiniA
Re: Converting a Catboat to a sloop
Cats are designed to be cats from the ground up and retro-fitting makes no sense at all. One of the best features of a cat is the flexibility of the mast. Not sure how such a massive would like the loads of shrouds. I imagine you would get something of a spaghetti effect. Your point seems like saying that a sailboat would be better if it had a much bigger engine since it would be more like a power boat then. Some things are just as they are, and messing around with them makes no sense.
Finishing our major refit. Our trip to Newfoundland is off because it is too late. Hoping to go to the North Channel instead.
killarney_sailor is offline
post #3 of 10 Old 02-13-2014
An example of a catboat sloop is Halsey Herreshoff's 1970s-era Eagle, which I own. It is based on the Herreshoff America catboat hull. The mast is moved aft to just in front of the daggerboard trunk. A bowsprit is added to support a self-tacking jib. A topsail completes the rig. The Eagle is just one of six different boats Herreshoff designed out of the same catboat hull. The variations are easy to make at the time of production but I imagine quite difficult and probably impractical to retrofit after the fact.
broadfoot likes this.
RobertKWFL is offline
post #4 of 10 Old 02-13-2014
Jiminri's Avatar
Robert, seems to me that once you move the mast the result is a sloop, not a cat.
Mad, is this what you mean? I'm not sure what the tiny jib adds. (You did notice the jib, right? )
Photo above is of the Pocket Cruiser from the Stevenson Project.
Nonsuch 30 Ultra #343 1986
West River, MD
Jiminri is offline
post #5 of 10 Old 02-13-2014 Thread Starter
That is exactly what I meant.. (and I like the picture). I am not looking for a "driving" sale, but something to help balance when going to windward..
Do not get me wrong, I will 99% most likely never do it... but it is a fun to pick people's brains on things
Art Haberland
post #6 of 10 Old 02-13-2014
If the catboat is properly designed it should NOT need help with balance. I once left the helm of my Nonsuch untouched for more than hour on a close-reach (catboats typically don't try to pinch too high, better to lay off a bit and go for speed) without the lock on. My sense is if you want a sloop buy a sloop. This discussion seems similar to me to someone saying they want to make their sloop into a catboat by just not using the job. You can do it, but why would you want to.
post #7 of 10 Old 02-13-2014
Originally Posted by killarney_sailor View Post
If the catboat is properly designed it should need help with balance. I once left the helm of my Nonsuch untouched for more than hour on a close-reach (catboats typically don't try to pinch too high, better to lay off a bit and go for speed) without the lock on. My sense is if you want a sloop buy a sloop. This discussion seems similar to me to someone saying they want to make their sloop into a catboat by just not using the job. You can do it, but why would you want to.
You probably want to edit that first sentence (should vs. shouldn't).
Loki9 is offline
post #8 of 10 Old 02-13-2014 Thread Starter
nonsuches are hardly traditional catboats.. but I get your point. Like I said, this was all thoughts. Coming from NJ where they used to race some outrageous catboats 100 years ago, it is easy to get carried away
Art Haberland
post #9 of 10 Old 02-14-2014
I'd agree with those who say a boat is probably at it's best as it was originally designed, but the addition of a sprit and a jib on a catboat to make it point a little better is intriguing. Might be best to enlist the advice of a naval architect before proceeding. I used to have a Catboat; now I have a sloop and occasionally harbor thoughts of making it a cutter. Maybe we're always in search of one more headsail......
For what it's worth, to me, the Hereshoff Eagle looks more like a Friendship Sloop than a Catboat, but whatever you call it it sure is pretty.
Quickstep192 is offline
post #10 of 10 Old 02-14-2014
fallard's Avatar
The only way I could balance my Herreshoff America catboat (traditional single, gaff-rigged sail) was to reef it deeply. By that I mean adding one more reef than appropriate. Only then would the boat stay on course without a hand on the tiller. (I owned that boat for about 16 years and raced in Catboat Association Race-Rendezvous for at least a dozen years, where I learned a lot about sailing traditional catboat rigs.)
Otherwise, a traditional catboat--not a Nonesuch--with a "barn door" rudder and centerboard would normally have noticeable weather helm as a consequence of the design. You could reduce weather helm by raising the pivoting centerboard, but that involved other compromises if you were sailing close to the wind. Another way to reduce weather helm is to shorten the foot on the sail, but that involves a sailmaker.
Halsey Herreshoff did exactly that to the Herreshoff America. I had hull #18, which was manufactured before Halsey actually went on a builder's trial with that design (according to the late sailmaker, Ed Thurston). I bought a new sail, based on "cut #2" and it made a noticeably difference in reducing--but not eliminating--weather helm. That cut involved shorting the foot by a foot and lengthening the luff by a foot to maintain approximately the same sail area. When all was said and done, the gaff was almost vertical, with the appearance of a near Marconi rig!
The bottom line here is that a traditional catboat will always have some weather helm. You can tweak centerboard and sail shape to mitigate it, but it will always be there.
fallard is offline
converting sloop to cutter orion 27 reed1v Pacific Seacraft 4 03-02-2012 12:26 PM
converting a sloop to a schooner rig robwilk37 General Discussion (sailing related) 16 04-16-2010 11:48 AM
Converting a yawl to a sloop? nemier Sailboat Design and Construction 17 02-12-2010 01:30 PM
Catboat? P8dawg General Discussion (sailing related) 13 03-29-2007 10:05 PM
From Catboat to 192 Iconoclat General Discussion (sailing related) 0 11-08-2002 03:49 PM
