-   -   Lake Ontario vs Lake Michigan (http://www.sailnet.com/forums/general-discussion-sailing-related/12271-lake-ontario-vs-lake-michigan.html)
Irwin32 12-29-2005 03:10 PM
As I said in another topic, I am considering a move to Lake Ontario. It would seem to me that Ontario, being smaller, would also be smoother. I know on Mich we often have to battle a steep chop. With 300 miles of fetch out of the NE, and a relatively shallow bottom, we can get some very steep 8 footers, which are tough to beat into. I have heard the sailing on Mich is comparable to the Gulf Stream.
Also, can one get from Ontario to New York City harbor for a shot down to Bermuda? And another also, can one get to the great circle - down thru Tenn. and to Mobile, AL?
Moving to L Ontario would give me the opportunity to live minutes from my boat ( now it is 70 minutes away).
PaulBl 12-30-2005 12:23 PM
Living close to the boat would be a plus. It''s the best way to go. Living far away sucks.
Sorry for the news but having lived near Ontario I can tell you the eastern shore can be quite wild. I have seen 25 ft breakers crash ashore in heavy weather. The shallow depth kicks up some real weather from time to time. Ontario is every bit the danger as Michigan. The only lake that really has much of a difference is Superior -it''s very dangerous and the cold water deadly. Clearly the most serious of the great lakes. The Great Lakes deserve all the respect of a great ocean - even the smaller ones.
From Ontario you can get to Albany via the NYS Barge Canal entering at Oswego or Buffalo. You''ll need to step the mast to get there (21 ft clearence) howvever there can be assitance at both ends as it is done quite a bit. Very pretty trip! The great circle can be accessed via Chicago so you can''t really get there without going back though the other lakes.
Allan C&C Less 03-02-2006 04:25 PM
Ahoy from Ontario!
I second that notion!!!!!! I have sailed the great Lakes and spent months on the caribbean and gues what?????
Ask me where I encountered the worst weather.....................answer..Lake Ontario at least so far!
Remember so can encounter a terrible storm anywhere. I'm sure when I head to Antigua next time I see worse sea!!!!!
:D Shiver me timbers!!!
Allan
The Regatta Queen 03-03-2006 09:47 AM
Tee hee!!! Like have fun!!!
Johnrb 03-06-2006 11:59 AM
Irwin:
Lake Ontario is known for it's steep chop when the wind picks up but I expect it's more noticeable in the east end given the prevailng winds. I believe Lake Ontario is of a somewhat comparable depth to Lake Michigan.
sailortjk1 03-06-2006 04:01 PM
Have you planned your route?
Through Erie and the Welland or Georgian Bay and the Trent?
Catsailor07 03-16-2008 03:03 AM
Erie Canal to Erie
I'm planning on a transit to Georgian Bay and wondering if exiting at Oswego, puting the mast up and doing the Welland Canal would be better than sticking with the Eire Canal to Buffalo?
John
BreakingWind2 03-16-2008 08:46 AM
Having done the Welland Canal in a sailboat, I will chime in.
Remember, as a pleasure craft, you are low man on the totem pole on when you get to be locked through, the freighters take priority.
We arrived at the Port Colborne (top of the canal) at 7:00 in the morning and called to let them know we would like to come through. We were told to go have a loooooooooong breakfast because there were several freighters due in. He told us it would be about 1:00 pm before we would likely start. Turned out to be about 3:15 before we started. But, because the freighters were still in the lock system, we had to keep waiting for them to clear the locks. We finally came out the bottom end at 1:30 in the morning!
Another thing to remember is, if you are heading up the lock system (from Ontario to Erie) you are required to have 3 persons on board.
Catsailor07 03-17-2008 11:59 PM
Welland Canal
Thanks Dave,
How did you find the actual locking conditions? Did you use fender boards? I 'm going to be doing it in a 6,500lb 30' cat with a 13'-6" beam and also wondering what your boat weighs.
Cheers,
John
sailingdog 03-18-2008 03:24 AM
John-
What catamaran do you have?
Originally Posted by Catsailor07 (Post 284337)
Thanks Dave,
Cheers,
John
