Sailors beware - Page 2 - SailNet Community
post #11 of 15 Old 02-24-2014 Thread Starter
rbyham's Avatar
Re: Sailors beware
It would seem fairly easy and affordable to develop a tie down system at least...
rbyham is offline
post #12 of 15 Old 02-24-2014
arrgh!
titustiger27's Avatar
Dock
Re: Sailors beware
This seems like it is ripe for a 'reality show'
Sea Storage Wars
Vector X Y
titustiger27 is online now
post #13 of 15 Old 02-24-2014
Re: Sailors beware
What, you think they're just stacking them up there, and letting them be?
From wiki:
Numerous systems are used to secure containers aboard ships, depending on factors such as the type of ship, the type of container, and the location of the container.[33][34] Stowage inside the holds of fully cellular (FC) ships is simplest, typically using simple metal forms called container guides, locating cones, and anti-rack spacers to lock the containers together.[35] Above-decks, without the extra support of the cell guides, more complicated equipment is used.[33] Three types of systems are currently in wide use: lashing systems, locking systems, and buttress systems.[33] Lashing systems secure containers to the ship using devices made from wire rope, rigid rods, or chains and devices to tension the lashings, such as turnbuckles.[33] The effectiveness of lashings is increased by securing containers to each other, either by simple metal forms (such as stacking cones) or more complicated devices such as twist-lock stackers.[33] A typical twist-lock is inserted into the casting hole of one container and rotated to hold it in place, then another container is lowered on top of it.[36] The two containers are locked together by twisting the device's handle.[36] A typical twist-lock is constructed of forged steel and ductile iron and has a shear strength of 48 metric tons.[37]
The buttress system, used on some large container ships, uses a system of large towers attached to the ship at both ends of each cargo hold.[38] As the ship is loaded, a rigid, removable stacking frame is added, structurally securing each tier of containers together.[38]
JonEisberg is offline
post #14 of 15 Old 02-25-2014
Re: Sailors beware
Given the increased frequency and voracity of storms brought on by last century's 'anything goes' business model, what ever they're doing obviously isn't going to be enough.
If cargo was falling out of airplanes at the same frequency would we be placated by them saying "yes, we make sure we shut the hatch every time.........."
Joel H. is offline
post #15 of 15 Old 02-25-2014
Re: Sailors beware
Perhaps the containers should be equipped with holes and plugs at the base and on top that would allow sinking after exposure to sea water?
endoit is offline
Beware Annapolis YS... PalmettoSailor General Discussion (sailing related) 17 09-11-2007 08:41 PM
Beware of Sailrite sailingbob Gear & Maintenance 5 07-23-2003 08:10 AM
Beware ....Toplac toplacsucks Gear & Maintenance 3 06-10-2002 09:24 PM
Beware October 20 Michael Carr Seamanship Articles 0 10-08-2001 08:00 PM
