Replacing interior cushions/upholstery - SailNet Community
post #1 of 8 Old 02-18-2006 Thread Starter
Question Replacing interior cushions/upholstery
Soon I'll be taking possession of my first sailboat, a Catalina 34. Will be in Long beach, CA. Need to change the original cushions and upholstery. Has anyone had any experience in going down to Mexico and getting them made there? Any leads about where to go, costs, and how it all turned out would be appreciated.
Thanks in advance
heliraf is offline
post #2 of 8 Old 02-18-2006
for quality and price ive had good experience with defender in ct. www.defender.com
hamiam is offline
post #3 of 8 Old 02-19-2006
This month's
Good Old Boat has an aricle on a DIY that looks pretty good.
Irwin32 is offline
post #4 of 8 Old 02-20-2006
paulk's Avatar
Despite the price being cheaper in Mexico, it may be easier to simply deal with a local uphoslterer. You can take him your old cushions and he can make new ones that will fit on the first try. If the Mexican ones don't fit...? What's the hassle worth to you?
paulk is offline
post #5 of 8 Old 02-22-2006
It use to be that you could get it done but you needed to supply the thread because they had cheep thread that broke. I don't know today that was several years back it could be you would have to see some ones work to tell if it was worth BEANS.
sailnaway is offline
post #6 of 8 Old 03-20-2006
sailandoar's Avatar
Reticulated Foam
Be sure to check out the OPEN CELL Reticulated Foam. It does not hold water. Nothing worse than wet soggy foam cushions that have to be removed from the covers and still take a week to dry. Use the ventilated fabric Phifertex on bottom or side of the cushion cover and things stay dry and mildew free.
sailandoar is offline
post #7 of 8 Old 03-21-2006
RichH's Avatar
Most upholsteery foam of 'good' and better quality and above is 'open cell'. The best way to prevent water, vapor and 'stink' permeation is to apply/glue a latex membrane on the top and all sides (the same latex used in condoms, etc. .... the sealed bottom usually face a vinyl bottom facing of the fabric covering. The latex sheet is available from most upholsterer supply sources.
RichH is offline
post #8 of 8 Old 04-09-2006
Check out c.cushions.com. They are located in Texas and have cockpit cushions for every make and model.
Jack Ryan
CSY 37
Jack Ryan is offline
Replacing a headliner bayme Gear & Maintenance 6 02-13-2003 04:56 AM
replacing deck non-skid gto2 Gear & Maintenance 4 08-22-2002 03:47 PM
Replacing Holding Tank ABullard Gear & Maintenance 1 08-15-2002 09:11 AM
replacing my rubrail Sailmale Gear & Maintenance 0 05-30-2002 11:28 AM
replacing inboard engines rjk Gear & Maintenance 2 05-09-2001 07:29 AM
