Alternative to Solar - Page 7 - SailNet Community
 28Likes
post #61 of 63 Old 03-21-2014 Thread Starter
Re: Alternative to Solar
Thanks a lot for the different Ideas! I am actually consulting two inventors from the technical university of catalunia (UPC - Universitat Politècnica de Catalunya), who are also part of the company SMALLE. They are very tech savvy and passionated about their product but don't really know if their product could be useful for sailors, so I am trying to find out how the product . The company itself is researching a lot in the field of renewable energy.
It would be very interesting to design a boat from scratch with the intend of being as green as possible. There is a German company, which is focusing on electric motors and they are working on a project which is called Deep Blue Hybrid. Check out the video, I really like the idea!
I am not able to post the link here but the company is called Torqeedo and under products you will find the deep blue hybrid!
Allmayer-Beck is offline
post #62 of 63 Old 03-21-2014
guitarguy56's Avatar
Maximillian... took some time on reading some of your proposal and that of the SMALLE technical ideas from the inventors/researchers... what it looks like is the classic magnetic ball oscillating inside a tube surrounded by electrical coils picking up the EMF of the magnetized ball... this has been tried and the voltages are quite small (0.5v @ very low currents)... in fact one American inventor has patented such an invention using a toroid with the magnetic ball inside/coils outside which uses kinetic energy to produce an electric current... it works no different than the kinetic action of my mechanical watch.
See invention here:
HOLLOW RING TORUS MAGNET GENERATOR - Patent application
Basically your inventors are trying to do the same thing (based on the pictures I saw) but in a linear motion which would work if you have about 24 of these devices to produce 12v total @ whatever current (efficiencies). The device would work by using the forward/stern and port/starboard motion of the boat... but this would produce far less electricity than a 12v 200 watt solar panel... many of these devices pop up with energy claims where the gas motor is to be shelved but in reality it produces far less efficiency and or claims are not what they really are.
Most of these use setups no different than this (there is no spring as shown... it is just showing the movement of the magnet oscillations graphically):
or more elaborate such as this:
Frankly I prefer the toroid coil generator as it makes energy is all axises.
guitarguy56 is offline
The Following User Says Thank You to guitarguy56 For This Useful Post:
Allmayer-Beck (03-25-2014)
post #63 of 63 Old 03-25-2014
In order to understand the market needs one would need to first define the market. If that is recreational sail (not power) boaters, have your friends yet found out how many boats in each size range there are? How many existing, how many added each year?
Then since the "box" can't be a miracle, one would need to define the size, weight, and output of "the box" or a range of boxes, to ask the boaters if that device would be of any interest to them.
Tell me a shoebox that weighs 20 kilos will reliably give me 50AH at 14 volts over the course of 24 hours at anchor in a calm anchorage and I will be interested. Tell me it will be four times the size, twice the weight, and product only 10AH at 14V over the course of 24 hours in rough water, and I won't be interested.
But unless I missed something so far you are only asking "Would you like a box that makes electricity?" and I was promised that around 1960. They promised us home nuclear generators, each the size of a home hot water heater (about 2' in diameter and 5' tall) that would provide all the power a hungry American single-family home would need.
I'm still waiting.
hellosailor is offline
The Following User Says Thank You to hellosailor For This Useful Post:
Allmayer-Beck (03-31-2014)
Tags
battery charger , renewable energy , solar panel
SOLAR JACK solar panels? christian.hess Electrical Systems 14 08-24-2016 10:55 AM
Looking for an alternative waterwks4me Gear & Maintenance 1 08-12-2013 07:40 PM
Solar deck instead of solar panels ulferlingsson Gear & Maintenance 34 01-31-2013 05:03 AM
Anyone bought solar panels from Sun Solar? justonemoreproject Electrical Systems 1 04-18-2012 05:08 PM
