New Sails, opinions - SailNet Community
post #1 of 6 Old 03-12-2006 Thread Starter
New Sails, opinions
I am in the market for a new cruising mainsail for my Aloha 27. The quotes I have rec'd vary wildy for what appears to be similar products.
Sail makers have recommended Challenge sailcloth 6.53 ounce to another Dacron product at 7.5 ounces (Victory) and North 4800 7 ounce.
I recently rec'd a quote from Sailseast but nobody at our club has dealt with them. The local lofts are North, Doyle, Victory and Lee but Sailseast is half the price.........
This leads to 2 questions. First is 6.53 ounce Challenge sailcloth heavy enough for coastal cruising a 27 footer? and second what sort of quality can I expect from Sailseast?
Any help is appreciated
Rick
miyagi is offline
post #2 of 6 Old 03-12-2006
can't re Member
captlar's Avatar
I do not know the Challenge name brand, but weight alone means little.
I just ordered new sails and went with a lighter weight HM cross stitch. You want a sail that will hold it's shape longer, not last forever, and the cross stitch achieves it. I put 4 old sails in the dump. Still "servicable" - which means they work, but you can't point as high and the rail is under all the time. Part of the question is how "well" do you want to sail ?
Half price sails - what do you think ? Material and labor costs are close to the same for all on a per yard or hourly basis. What you don't pay for, you won't get. Both North and Doyle will treat you fairly. I don't know the others. Sounds like you are in the area, so you could get a price from my loft, Harding Sails in Marion. Smaller operation run by real sailors.
Larry
captlar is offline
post #3 of 6 Old 03-13-2006
Thumbs up
I would go to several lofts and look at the sails North,Quantum,Doyle,Hood ect.Hood makes some fine sails and have a fine price. The continuous thread heat sealed fibers is quite a piece of work. North makes great sails and uses several Dupont strands which some other companies also use but North does make great sails that are correct usually. Quantum has allot of its sails made in South Africa good sails cheep labor. Lee made in Hong Kong good sails. I think if your in the market it would be to your advantage to shop for quality and learn what the cloth is all about. Some laminate sails are great for two or three seasons then they make good sun shades at the next picnic. I like to look at cloth North will give you samples you can feel and have to give you a good idea of how the Dacron will look and feel. Keep the samples they make great patches. I like Hood made in Ireland and the way they stop the loom if one thread breaks they repair it and then move on thats quality. If your looking at a tight budget Bacons in Annapolis cuts second hand sails to fit your boat. The sail industry is very complex and interesting to learn about you may be surprised at what you will learn. Kevelar ,mylar and the high tech stuff are not for the cruising sailor. Sounds like your a club racerand need some thing in the middle a nice radial cut main by North might be in order. its all riding on what you are doing with the boat and what it is. What is it Tartan,CC, Jboat what you see.
sailnaway is offline
post #4 of 6 Old 03-13-2006
Man, I got a new fully battened main with stack pack from Doyle...and really like it a lot. Call Chris in Marblehead...directly. He's very knowledgeable and a good guy.
Moe
mgiguere is offline
post #5 of 6 Old 03-14-2006
Wandering Aimlessly
PBzeer's Avatar
Using a local loft, where you can talk with the sailmaker and explain what type of sailing you do, and what you expect from your sail, is a good idea for ending up with the best sail for your money. The more input from you, the better choices they can provide you.
John
Ontario 32 - Aria
Free, is the heart, that lives not, in fear.
Full, is the spirit, that thinks not, of falling.
True, is the soul, that hesitates not, to give.
Alive, is the one, that believes, in love.
JCP
- Website & Blog
PBzeer is offline
post #6 of 6 Old 03-15-2006
Challenge is the top, or at worst tied for the top, as far as Dacron fabrics are concerned. They publish detailed info on each of their fabrics on the web.
Fabrics from Challenge that end in x.62 or x.3 are intended for high aspect sails.
There are very large differences in dacron fabrics, so homework is suggested.
http://www.challengesailcloth.com/cloth.htm
paulmcquillan is offline
Windward performance deseely General Discussion (sailing related) 21 04-01-2012 02:42 PM
Sloop, Cutter or Ketch jsgsail Boat Review and Purchase Forum 17 12-26-2008 02:47 PM
Ketch/Yawl Handling svsymphony Seamanship & Navigation 19 07-05-2008 01:19 AM
Yawl Info Needed sailortonyb1 Boat Review and Purchase Forum 5 01-18-2006 04:51 AM
diffrent rigs? (schooner, ketch, cutter, sloop) jbarros Boat Review and Purchase Forum 2 07-09-2003 04:10 PM
