higher speed then the wind - SailNet Community
post #1 of 2 Old 03-13-2006 Thread Starter
someone could explain by theorical means and math relations ,that we can sail at a superior speed than the wind (real or apparent) ?
jruisa is offline
post #2 of 2 Old 03-14-2006
Can't tell you the math, but it is possible for some low-drag sailboats (like light displacement planing hulls when planing, catamarans, iceboats, and some wheeled land "boats" to sail faster than the true (but not apparent) wind.
They do this by using their speed too pull the apparent wind forward, which also increases its strength by a factor (vector) almost equal to the boat's own speed. So, an iceboat beam-reaching on smooth ice in a 10-knot true wind may end up close-reaching or close hauled doing about 20 knots in an apparent wind of close to 30 knots. It's said that iceboats can go at 3 to 7 times the true wind speed, by ''creating" their own wind this way. In water, catamarans, windsurfers, and some planing dinghys can do the same, though not nearly as fast as an iceboat.
Mathematically, it's basically a vector problem, but I don't know the lift and drag coefficient factors you'd use to turn it into a windspeed/direction-boatspeed diagram, sometimes called a "polar" diagram.
nolatom is offline
Windward performance deseely General Discussion (sailing related) 21 04-01-2012 02:42 PM
Wind speed vs safe learning? Jonathan316 Learning to Sail 4 04-29-2004 03:40 AM
Ayrodynamics of Sailing ZachW. Learning to Sail 9 05-30-2002 10:41 AM
Wind speed detectors BiscuitBandit General Discussion (sailing related) 3 11-05-2001 04:05 AM
ideal wind speed? brucemcald Learning to Sail 9 07-21-2001 05:30 PM
