Blogs
User Name
Old 03-15-2006
catamarans catamarans is offline
catamarans is on a distinguished road
Length to Beam Ratio
How does length affect stability? If a cat has a 2:1 L/B ratio and
it's 40 feet long, how does its stability change if it's stretched to
50 feet long, yet keeping the beam constant, assuming everything else
remains constant? Better, worse, or no change? Is there a standard
way to calculate that?
Old 03-16-2006
henryvand henryvand is offline
henryvand is on a distinguished road
multihull info
I suggest you check out www.themultihull.com If you search you will probably find existing discussions on your topic in forums.
Display Modes
vB code is On
Windward performance deseely General Discussion (sailing related) 13 01-12-2007 01:09 PM
What can you tell from the numbers? brazilnut Buying a Boat 9 11-18-2004 01:44 AM
when does CSF make a difference? coondogger Buying a Boat 7 10-26-2004 06:37 PM
Boat length and solo sailing maxcontax General Discussion (sailing related) 5 03-21-2003 07:07 AM
beam vs length pmills42255 Buying a Boat 1 08-08-2002 03:12 AM
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
