Most Useful Sailing Tool - Page 2 - SailNet Community
 26Likes
post #11 of 39 Old 03-15-2014
bljones's Avatar
Re: Most Useful Sailing Tool
Wait, can we nominate candidates?
I nominate Smacky as The Most Useful Sailing Tool.
zeehag and Minnesail like this.
It's 5 o'clock somewhere:
bljones is offline
post #12 of 39 Old 03-15-2014
Minnesail's Avatar
Originally Posted by benesailor View Post
Seriously; a leatherman. If you don't have one you need one a sailboat.
Wave - Leatherman Multi-Tools
I think a Leatherman Wave is maybe the most useful tool overall, not just for sailing. I always wear one.
Catalina 22
on a starboard tack
Minnesail is online now
post #13 of 39 Old 03-15-2014
The most female moderator
Donna_F's Avatar
Dock
Here are some other opinions on favorite tools:
What is the most used tool on your boat?
favorite tool...?
Donna
Catalina 30 TRBS
Rock Hall, MD
KB3ZCB
Donna_F is online now
post #14 of 39 Old 03-15-2014
bljones's Avatar
Seriously, it seems like the most useful tool for the job is always the one tool you don't have aboard. Based on use, maybe the most useful tool on board is one of the hokey, corny Davis Universal Deck Keys.
i cut off the tangs on one side and put an edge on it, so it is now a wrench, screwdriver, bottle opener, deck plate key, shackle pin key and knife. It was a $9 impulse buy at the local chandlery, and i attached a lanyard and a freebie floating keychain to it. It gets used more often than either of the pocket multitools I have aboard, partly because it is always close at hand.
jrd22 and MarioG like this.
bljones is offline
post #15 of 39 Old 03-15-2014
TQA
Bombay Explorer 44
TQA's Avatar
LEATHERMAN even a cheap knock off will do.
TQA is offline
post #16 of 39 Old 03-15-2014
snake charmer, cat herder
zeehag's Avatar
cell fone to call friends in the anchorage you approach for beers and heat the coals for bbq.....mebbe even conditions at present..lol
or warn them that you are going to be there so they can flee the area....
but that means the loose nut behind the wheel actually functions......mebbe....
could be the wench that maintains the loose nut behind the wheel ... in some boats....rodlmffao.....
formosa 41, cruising tropics
zeehag is offline
post #17 of 39 Old 03-15-2014
A good knowledgeable and cohesive crew..
aa3jy is offline
post #18 of 39 Old 03-15-2014
Mike,
What makes the TTI worth $50 more than the wave? I cannot discern a functional difference and neither mentions one handed blade opening, so how do you do that?
John
ccriders is offline
post #19 of 39 Old 03-15-2014
Minnesail's Avatar
Originally Posted by ccriders View Post
Mike,
John
The Wave is easily opened and closed with one hand.
It also has a ruler along the handle, which I find comes in quite handy.
The Phillips head screwdriver uses a replaceable/reversible bit which I understand could come in handy. If you strip the bit it's easier to replace than the whole unit, but... The one and only time I've been up a mast I was using it to replace the steaming light and naturally before I even had the first screw out the bit came loose and went bouncing all the way down to the deck...
Catalina 22
on a starboard tack
post #20 of 39 Old 03-15-2014
MikeOReilly's Avatar
Mike,
Mine just looks cooler
I'm sure both would be fine. I recall liking the feel in my hand of the TTI over the other options when last I went shopping, but I'm sure the others would be just fine.
The two main blades (both he straight and the serrated) can be flipped out using your thumb. That's what the hole in the blades are for. There are many models that offer this option now, including the Wave.
Why go fast, when you can go slow.
MikeOReilly is offline
I need a tool.... sailak General Discussion (sailing related) 6 08-08-2013 02:29 AM
favorite tool...? mrhoneydew Gear & Maintenance 25 08-04-2008 08:09 PM
What is the most used tool on your boat? kmclarke Gear & Maintenance 50 10-21-2007 11:11 PM
Re: FYI - Freeware Tide Tool V2.2 is now in Tide Tool Beta 2.3 (Run NewsReader Mass Bay Sailors 0 03-04-2007 11:15 AM
FYI - Freeware Tide Tool V2.2 is now in Tide Tool Beta 2.3 (Runs on NewsReader Mass Bay Sailors 0 03-03-2007 04:15 PM
